Question about Bissell 9400 ProHeat Upright Wet/Dry Vacuum
Cleaning mixture why is there nothing coming out of the machine?
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=433384&thid=704416
Cleaning mixture
posted by wrangler4 on Jun 25, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Bissell 9400 ProHeat Upright Wet/Dry Vacuum. The problem is that you may have a bad switch or pump in the vacuum or a release valve could be stuck or broken. Please check your owner’s manual for the trouble shooting page to see what they suggest or contact your local vacuum cleaner dealer in your area or then contact the Bissell Factory cust serv line listed below: So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 25, 2008
The nozzle on my machine needs to be cleaned. there is lint in it
If its just the nozzle, soak it in a mixture of Dawn, baking soda & hot water apprx 5-10 min. After soaking take an old paint brush, sponge applicator or several pipe cleaners and just start to work it, The gunk should start to break up. If not, you may need to enlist the help of a butter knife to help your cause.
Apr 20, 2016 | Bissell Little Green Machine 2X Ultra...
Bissell lift-off deep cleaner pet will not spray solution either mounted or lifted out for upholstery use.
Sounds like either the pump quit or plugged, or if you here pump nozzles clogged. Try 2 cups of vinegar and water to help clean out
pump and nozzles. Let stand 1/2 hour, then shake it up with mixture in it, do this a few times then try and run mixture through machine
press the helpful button and follow me on Fixya for more good tips
Jan 27, 2016 | Bissell Vacuums
My hoover steam vac has developed a musty smell. Any ideas to remove this odor?
i often use vinegar and water to clean my steam cleaners. I use a 3:1 ratio of 3parts water to 1part vinegar. using 8oz's as a part. hope this helps good luck. whoops btw use mixture to run through machine and soak dirty water tank in.
Mar 06, 2013 | Vacuums
Water and cleaner not coming out, The machine is only 6m old and was working fine, I have cleaned every where I can to see if there was a blockage but nothing is working. The heater is working, there is a...
Check the complede length of the hose. You may find a crimp in the most inconvenient place. You say you cleaned everything ... can you blow through the hose where the cleaner comes out? (don't drink anything!)
Sep 07, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
The purple cylinder on my Dyson 14 Animal vacuum smells terrible
Make sure that the filter is completely dry before you reinsert it. If not, it will mildew, emitting a horrible smell. When you clean your cylinder, you must wait for at least three to four days to make sure that it is completely dry.
May 17, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Having trouble shampooing
I found this on a website. Hope it helps others...
by Mainelyvacs in: Kirby
  • First a short explanation of how the Kirby shampoo system works: Kirby uses a “Dry Foam” type of shampoo. Basically, it spreads a shampoo foam solution on the surface of your carpet. This foam needs to stay on the surface of the carpet until it is completely dry (usually 1 to 2 hours depending on temperature and humidity) As the foam dries, it soaks up grease and dirt. You then vacuum the carpet and up comes the shampoo residue along with the absorbed dirt and grease. It does a very good job on the surface but will not extract stains from the bottom of the carpet or carpet pad. Several other brands such as Electrolux, Hoover and Koblenz make Carpet Cleaning machines that use the same system.
    So, you’ve read your manual, you’ve removed the carpet cleaning nozzle and the bag assembly from your Kirby, you’ve installed your shampoo tank and carpet shampooing nozzle tray and you start to shampoo but all you get on your carpet is a puddle of soapy water and no foam. Here’s a few things to look for:
  • Make sure you are using a Dry Foam Shampoo(preferably Kirby) and NOT an extraction shampoo, the Rug Doctor shampoo you had left over from your last rental will not work.
  • Make sure you have the correct mixture. If you are using Kirby Dry foam shampoo you simply fill the tank with water and put a tank cap full of shampoo in with the water. You can use other brands of “Dry Foam” shampoo, but the mixture ratio may be different, so read the label first.
  • Don’t reuse last year’s leftover mixture, it’s probably no good.
  • Make sure a family member didn’t pour any leftover mixture back into the empty shampoo bottle - further diluting a mixture will not produce any foam.
  • Don’t use shampoo that’s seen extreme temperatures.
  • Check the tank and make sure that the sponge filter is in place and if it is in place that it is not deteriorated. The sponge filter is located under the tank at the point where you attach the tank to the hole that you removed the bag assembly from.
  • Check the hose that runs from the tank to the nozzle. It should have a screen in the end that attaches to the tank (older models had a cloth screen with a metal retainer, models after 1989 have a 1 piece metal and plastic screen.
Apr 13, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Bissel 1770 Quicksteamer II Upright vacuum
Here is a picture breakdown, maybe that will help. Sometimes tho you can run a mixture of vinegar and hot water thru it, it may clean it out ok.
Mar 25, 2008 | Bissell 1770 Quicksteamer II Upright...
Bissell 9400 ProHeat Upright Wet/Dry Vacuum Logo
244 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
