Question about Philips 42PF9630A 42 in. Plasma Television
Warranty is over
I do not have a problem taking the set apart if you have a solution.
thanks
    Sergeant:
  • 260 Answers
Make sure the set is unplugged, find the screws for the cover nearest the electric input cord. You will need to take a look at the power supply that it plugs in to and all the wires coming out of the power supply. make sure you are still comfortable with this job. If you feel you are, then we will need to get a part number and see how much the part will cost. While you have the set open make sure you look carefully at the inside of the television to make sure nothing appears to be burned or damaged. Let me know when you get this far. Remember, we are not responsible for any damage you do to your own tv. Please be careful.
Posted on Jun 25, 2008
Hlamilton beach hand mixer. One beater doesn't turn. Does this mean that a worm gear needs to be replaced? If so, can I do that myself? Thanks
You can take it apart and check, but if a cog has stripped you won't find a replacement for it. Hand mixers and termed as disposables when they break down. Could it still be in warranty? The warranty is 5 years!
http://www.hamiltonbeach.ca/warranty.html
Nov 30, 2016 | Food Mixers
Purchase a Panasonic TC-42Px24. The problem it does not not turn on, really click nothing more.
Better take it back to the dealer where you bot it. This is a warranty problem and will require the makers assistance since it is a new set and should still be under warranty.
Nov 28, 2014 | Panasonic Televison & Video
This is so retarded I have written whats wrong 8000 times and all I get is bs!!! The flippen disc wont eject on my 2 mnth old dp26670 tv/dvd combo. What is wrong???????
I am not sure what others have told you, but I can only guess as they did. There can be many issues that can cause this and without having it in my hands I can only guess.
It could be a bad ejector motor that activated the eject mechanism, a bad mother board that does not tell the system to eject the disc, or something could be physically jammed in the unit! A belt to the mechanism could have come off as well. The eject button may not be working. If this is only 2 months old, why havent you contacted the place of purchase or at least the manufacture for warranty on this. If you take it apart and attempt a repair, then this will void any warranty you have.
I can only suggest you do a reset on the set and its memory. Unplug the unit and let it set for several hours, maybe over night and the plug it back in and see if there was something in the memory locking up the player. If this does not work, then you can take it in for warranty work, or get back with us on how to take it apart and look for causes.
Thanks
Feb 28, 2011 | Televison & Video
Panasonic dmc-fh22 camera when turned on displays a system error (zoom) message on the LCD
First off how long have you owned the camera if it is less then 12 months old then go through the warranty repair process on panasonic's web page:
http://panasonic.net/support/gscn/
If you need any other assistance let me know.
Thank you,
Lee
Aug 23, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
TAKING APART
if its under warranty, i suggest you call garmin to have it fixed for free....if its out of warranty, use a hair drier to heat up the sticker on the bottom of the gps and remove the sticker.
then youll see two screws that were hidden by the sticker...remove those two screws, then use your fingernail and slide it around the seam that seperate the front case from the back case to un snap the locking tabs.
becareful, because the speaker and the battery wires are attached to the rear.
split the two halfs and desconnect the wires before pulling the two halfs completely apart.
bill
Apr 16, 2010 | Garmin nuvi 205W GPS Receiver
My canon pixma mp160 printer has an error code of "e3".
Try the Canon support site. Type Canon support into your search engine.
Jun 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Keyboard strokes repeated on their own
Hi there.
You can go to the control panel and select keyboard from the list to adjust the keyboard settings, if this does not resolve your problem then chances are the keyboard is defective so take advantage of the manufacturers warranty and send it in for repair.
Don't try to remove or take apart the keyboard as doing that will void the warranty.
Good luck and thanks for choosing FixYa!!
Jun 09, 2009 | Acer Aspire 2930-4661 Notebook
Trying to take apart to find the leak
Turn off water supply, if its a single handle there should be only 1 set screw then diverter is screwed down. After you remove the diverter there is a small rubber washer or o-ring ..let me know which it has.Thankyou.
All Price Pfister Parisa Collections products are backed by the Pforever Warranty, which guarantees both finish and function for the life of the product.
Dec 14, 2008 | Plumbing
Brada ef2401 door won't close
We actually had the same problem with our Brada dishwasher. There is a plastic clip inside the door that latches on to the dishwasher to keep the door closed. In our case this clip had flipped inside the door (periodically continues to happen to this day). To resolve we took the door apart - carefully - and flipped the clip back into proper position. You can only do this if the dishwasher is not under warranty as once you take it apart you will likely void the warranty on it.
Aug 12, 2008 | Dishwashers
How do you disassemble a compact ps2?
Don't Take It Apart!!! You'll ruin the warranty, you could probably still send it in it the warranty is still active. besides don't take it apart the chip is probably fried,
Aug 24, 2007 | Sony PlayStation 2 (PS2) Compact System...
Philips 42PF9630A 42 in. Plasma Television Logo
24 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
