Question about Euro-Pro Easy Sewlution 385 Mechanical Sewing Machine
Euro pro 385w problems
I have a euro pro 385w sewing machine and when I try to sew it tangles my thread up at the bobbin and it pulls the material in there to. My feed lever doesn't move up and down like it is suppose to. I think it is broke and I need a diagram to see if one of my srings is broke. Please help if you can. I have searched the internet and I can't find anything on this type of sewing machine.
If your machine is like mine the bobbin is not filling right. My bobbin thread is very loose when it should be tight. I am also looking for bobbin solutions. If I wind the thread around the thread tension guide 2 or three times it keeps the thread tight going to the bobbin winder. I hope this helps
Posted on May 31, 2009
Bobbin keeps tangling with to thread
Have you checked your tension? And is your needle an old one, or bent or blunt? Are you sure it is threaded correctly? Is it the same thread in the bobbin as well as top> Is the needle the thickness used for the material you are sewing>
Best wishes.
Dec 23, 2014 | Euro-Pro Sewing Machines
Help with Euro Pro 9000, the thread keeps getting tangled up in the bobbin area..
When I had this problem, even though I have been sewing for years, I was just not threading the needle properly. Make sure the presser foot is raised when you thread the needle. Another reason is that the thread is too old, the needle is not the correct size or type for the material, neither is the thread. Hope this helps. It's usually nothing to do with the bobbin, but the upper thread.
Jul 11, 2014 | Euro-Pro 9000 Mechanical Sewing Machine
Install bobbin in euro-pro X 464XC
Either your machine was not threaded with the presser foot wasn't up when you threaded the upper thread... or your upper tension isn't tight enough.
Good luck.
Sep 14, 2012 | Euro-Pro Fast and Easy 420 Mechanical...
Bobbin will not stay in bobbin case. No stitches top or bottom. EP 382
have you tried another bobbin? when was the last time the machine was
serviced?
Apr 16, 2012 | Euro-Pro 382 Mechanical Sewing Machine
The needle will not go down all the way, so it dosent sew on my euro pro, 7133 sewing machina
Check the manual to be sure the needle is installed correctly, this is usually with the flat side of the shank facing the back of the sewing machine.
Make sure the needle is not bent.
Also, there may be thread tangled in the bobbin area. Open the needle plate and bobbin; clean away any lint or thread that has accumulated there.
If this does not resolve the issue, the machine will need to be serviced/repaired by a sewing machine tech.
Mar 18, 2010 | Euro-Pro Shark 80 - 7133
I have euro pro 9106 sewing machine. When I try to sew the
Make sure your needle is in the down position in the material and hold on to the tails of the top and bobbin thread when you begin sewing.
Dec 24, 2008 | Euro-Pro 9000 Mechanical Sewing Machine
Upper thread getting tangled in the bobbin
Always remember T-N-T. Thread, Needle, Tension. Assuming its threaded properly, is the needle all the way in and facing the right direction? These symptoms also suggest the bobbin may be in the bobbincase upside down thus turning in the wrong direction. Hope this helps.
Aug 21, 2007 | Euro-Pro 416 Mechanical Sewing Machine
Needle Thread and Bobbin Thread
This is a timing problem and will have to be repaired by authorized dealer.
Jun 18, 2007 | Euro-Pro 373 Mechanical Sewing Machine
Bobbin won't thread
Sounds like the bottom tension is to slack.
Look at the side of your bobbin case, when you thread the bobbin thread part of the route it runs is under a flat leaf spring. There is usually 2 very small scews on this leaf spring one screw holds the spring onto the casing and will be tight. The other is the tension adjuster screw, turn this screw clockwise half a turn at a time. After each half turn pull the bobbin thread until slight resistance is felt. Then try sewing if bunching/tangles still occur more tension is required, this is trial and error until the tension is corrert.
If you want a new manual try this website if your machine is not listed email them and they will try to help.
www.sewusa.com
Oct 09, 2006 | Euro-Pro 373 Mechanical Sewing Machine
Euro-Pro Easy Sewlution 385 Mechanical Sewing Machine Logo
322 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Greg Cann
Greg Cann
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
