My sansa e 260 is frozen on refresh data - Audio Players & Recorders
  • 8,596 Answers
Reset the player by holding in the volume button for 15 seconds. If that fails: These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jun 25, 2008
3 Suggested Answers
SOURCE: Sansa e250 has Refresh Database Frozen
Look at this site:
http://www.expansys-usa.com/ft.aspx?k=89682
follow the steps showed by MrSinister27
It worked for me!!
Posted on Jul 23, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: My sansa e270 6gb is frozen
I'm always hesitant to give this answer, because if it's done wrong, you can do more damage to your player, but the answer is: you need to format your player. I would format the player from inside the player's settings menu - but if it's stuck on Refresh database, you may not be able to do this. Follow these steps in order:
-Tha Mp3 Doctor
Posted on Feb 15, 2009
Refresh data
If your Sansa MP3 player becomes frozen or unresponsive, you may need to reset the unit.
To do so, simply slide and hold the Power button on the side of the unit. Hold it for about 10 seconds and the player should reset.
You can also use the video at the link below ::
youtube.com/watch?v=Wh6Is3th1Vs
Have a nice day..
Feb 19, 2011 | SanDisk Sansa e250 MP3 Player
Help with my Sansa 260
Remove battery and put it back after few minutes
Mar 28, 2008 | SanDisk Sansa e260 MP3 Player
It is getting stuck while refreshing the database.
Depending on the amount of the data or music files you have on your device, "Refreshing Database" may take a while to finish. But if you feel it's frozen you may try the following steps:
Reset the device 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player. NOTE: Resetting will turn the player off while it is frozen.
Delete recently loaded files 1. Connect the device to the PC in MSC mode using force MSC. 2. Locate and delete recently added files. 3. Disconnect the device from the PC.
If this resolves the issue, proceed to STEP 3. Otherwise, format the device, update to the latest firmware, and reload the songs to the device.
Update to the latest firmware You may need to upload the firmware manually, there are instructions on the links below on how to manually update your firmware Sansa c200 series firmware update Sansa Clip firmware update Sansa e200 series firmware update Sansa Fuze firmware update Sansa View firmware update
Click on any of the links you need more info on.
Oct 16, 2010 | SanDisk Sansa e250 MP3 Player
Frozen on the sansa screen
try to reset it by pushing and holding the power button down for at leaset 30 seconds or remove the back of the machine via 4 small screws and remove the battery and replace it and see what happens
Mar 26, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Frozen sansa at refresh database
This is from the Sansa Website at http://www.sansa.com/support/sansa_e200/faqs
My e200 freezes on the “Refreshing Database” screen
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
I this helps please dont forget to rate my answer.
Mar 07, 2009 | SanDisk Sansa c240 MP3 Player
Sansa e260 firmware
Mine was a bit more FUBAR I guess. I have a Sansa e260. I had rockbox on it, went to switch back to the firmware. Uninstalled rockbox and on reboot... the e260 was refreshing the database and then came to a frozen green screen.
My e260 was already in MSC mode. I did the steps above but was still stuck.
The solution that worked was one posted by "Slaughter" on anythingbutipod.
The ultimate fix for all e2xx v1 problems - Format, enter recovery mode, downgrade firmware Link (you'll need to format the drive), reinstall newest firmware via newest Sansa Updater, reload tunes.
Dec 01, 2008 | SanDisk Sansa e260 MP3 Player
Snasae270r
Hi, try connect to pc computer and scan with anti virus /heal and clean so that the mp player can move. the data.
Jan 22, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e200r
my Sansa M200 has a frozen screen, tried removing battery but comes back screen frozen
Jan 04, 2007 | SanDisk Sansa e200 MP3 Player
156 people viewed this question
 Grubhead
Grubhead
