Question about RCA HD52W66 Projection Television
My HD52W67 has concaved picture
When I turn it on the picture is concaved, the color is shifted slightly to one side, and there are 3 skinny lines across the top. I went to convergence menu and clicked it but all it did was turn the tv off then it came back on with no convergence option. Its a 2005 I bought it new.
WILL SOMEONE PLEASE HELP.
  • admpeek Sep 05, 2008
    im not sure were these convergence ICs or heatsink are. im absolutly 100% clueless as to what they look like or were they are. any help would be great. Thank You, Adam
  • bubblehead29 Oct 21, 2008
    I have the same problem with the picture slighty to one side and the three lines across the top.
  • 4,234 Answers
This is a convergence problem and can be repaired relatively easily. If you can solder, you can fix this yourself. First try resoldering the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. These are large black ICs attached to a heat sink and should be marked STKxxx.
Keep us posted.
Dan
Posted on Jun 25, 2008
  • ABRsvcs Sep 05, 2008
    If you can not solder or don't feel comfortable working inside the set, call for service. If the problem is only poor solder joints, this can be easily fixed in the home in less than an hour. Call around to your local service shops for an estmate.
    Dan
The picture on our Sony TV Model KP-43HT20 recently became distorted, concaving at top and bottom. If I use reset the Flash Focus, the picture will return to full screen side for awhile but the colors do...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergene board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 15, 2011 | Sony KP-43HT20 43" Rear Projection...
By admpeek on Jun 25, 2008 When I turn it on the picture is concaved, the color is shifted slightly to one side, and there are 3 skinny lines across the top. I went to convergence menu and clicked it...
You have a blown fuse on the Deflection board FL231 it will be on the righthand side of the flyback Transfomer there are 3 of them in a row they will look like small brown retrangler caps, it will be the one in the middle. I had this problem myself just several months ago, replacing this fuse fixed the problem. That fuse controls the convergance of the 3 CRT's, without it the tv can't converge so you don't get the option in the menu.
Sep 17, 2010 | RCA HD52W66 Projection Television
The picture and colors went out of focus.
Blowed Fuse there is 3 of them on the right hand side of the FBT flyback Transfomer they Look like small brown rectrangler caps But are Fuses .06amps
it will be the one in the Middle FL231
PartStore.com has them 1-866-925-7278
May 01, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA HD52W67 and it just started to have
I'm having the same problem with my RCA HD52W67 rear projection TV and I've notice this problem is listed with my other owners of this product. I have no experience with fixing electronics. Sould I try this myself or take it to an expert? Has anyone fixed this problem? What is an estimated cost involved, if I take my set to an expert? Any advice with the HD52W67 is great appreciated.
Mar 19, 2010 | RCA HD52W59 HDTV Projection Television
The colors are distorted and it seems like the only colors that really show are blue, green, and red. When you turn the TV on you can see blue, green, and red lines across the screen. The picture also...
Hi there, this is what we call in the industry convergence board failure. this board regulate the rgb and keeps everything in order so the picture looks nice and clean. when this board starts to malfunction, what you are witnessing is usually the result. I suggest repairing this convergence board. this will fix the 3-d effect.
Mar 08, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Rca p56927 colors out of line
This is a convergence oroblem. First question is do you have the convergence option in under setup in the customer main menu?... if you dont you may have the very common fl231 fuse problem; i have wrote a article on this under the tips and tricks section. this is a very simple inexpesive repair. If you do have the "convergence option" then you may have to replace one of three cuircit boards
Oct 25, 2008 | RCA R56WH76 Projection Television
HD52W67 RCA YR.2005 The picture is concaved the color is shifted slightly to one side. When I went to menu convergence it shut tv off then came back on without the convergence menu there. I was told to...
Look on the board next to the flyback you will see three small brown plastic rectangles. Those are fuses the center one is FL231 that fuse and possibly diode D231 and capacitor C231 is blown thats why the convergence option is no longer on the menu. If you need more info please respond to this sme post so I have access to the info again.
Jun 26, 2008 | Televison & Video
Red Blue and Green colors are not aligned and looks concave
replace fuse looks like cap next to flyback transfomer FL231 it will be the one in the middle.there are 3 of them next to FBT.
May 28, 2008 | RCA D52W19 52" Rear Projection Television
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
RCA HD52W66 Projection Television Logo
183 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
