Question about Mitsubishi WD-52525 52" Rear Projection HDTV
WD52525 Picture is scrambled
The picture suddently went scrambled and a yellow message appeared suggesting power or YbPpr cable invalid. Any suggestions?
  • brian46 Jun 26, 2008
    Turned the tv on after previously working fine. Picture is scrambled, horizontal lines. Partially black with white dots (like looking into space) other parts multi-colored. I did the cap replacements about 8 months ago and it has been working fine since. Different symptoms here. Any suggestions?
  • Anonymous Jun 26, 2008
    Same Problem as Dave's WD52525 with picture scrambled. TV repair friend said it was the power box section in the TV and not uncommon for this TV. Cost would be about $1400 and take about three weeks - has to be sent to Mitsubishi.
  • 927 Answers
Good Day,
You all;
This problem is on the 'formatter' board. This is NLA, so it has to repaired, theses parts are surface mounted
Tile or block pattern with no video or OSD. Check D8F00 and D8F01 part # 264P828010, also check C8F26 and C8F29 part # 141P148000 (1 uFD, 25 V) on the FMT PCB (part # 930B924002). I hope this helpful and not too late. Good luck, big IRISH.
Posted on Jul 20, 2008
Sony videoscope xbr
would think you need to replace the cable board etc. the signal is not getting in and out right. can also be a fault on the power board giving the wrong volts so would check this to. it will tell you on the board what volts is supposed to be. the 5v and 12v should be spot on other volts will vary a little. also check the capacitors for the caps to be bowed up and a brown/ yellow gunk around them and under the board this can be a sign they are failing.
Feb 25, 2014 | Televison & Video
Picture scrambled / multiple pictures
Nov 11, 2013 | Sony KP-61S70 61" Rear Projection...
Westinghouse Flat Screen Goes Blurry/has Scrambled Picture
tried first with re seating the lvds cable in the t-con board, the t-con board is mounted covered with metal shield. if can get with fixing the cable, then your t-con board has defective component parts.
Aug 13, 2012 | Westinghouse Televison & Video
Get sound and "invalid format" message displayed instead of picture
Could have still been hit by a surge. Take the back off of the TV and look at the main board were you connect your HDMI. See if it is scorched or components that blackened. Also check your DVD player on another set. Your DVD player could be the problem.
Apr 11, 2012 | LG Televison & Video
Picture is scrambled after power surge. Have a
Check if it has a scrambled image on all sources ie - DVD- VCR - cable/satellite box. Since the PIP is normal it sounds like the signal source is bad.
Post back with more info about your set up (what's hooked to your TV) if you need more info
Nov 28, 2009 | Samsung HL-R4667W Rear Projection...
No picture when on for approx 15 minutes
It sounds like you are saying the "video looks scrambled but the audio keeps playing OK"
Normally this is a Video Processor Problem that requires a Board to be replaced.
When the problem happens, can you see the TV menu or the TV's On Screen Display clearly.
I suggest checking to see if the problem happens with the video inputs like, Composite(yellow/red/black), component(RGB/yellow and black), HDMI and S-video. If it happens to all inputs then you need to replace a board.
May 21, 2009 | Vizio VW37L 37 in. LCD HDTV
Mitsubishi WS-55809 Upconvert Stopped working
your problem is the 2hdw board is located in the signal board.
Feb 02, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Why does my picture occasionally appear scrambled?
This may be a problem with your cable provider and not your TV!
hope this helps
Dec 13, 2008 | Televison & Video
Vizio 37in lcd yellowed picture
Mine turned red. Had a bad HDMI cable. TV is missing part of the video feed. Try a new cable but first make sure old cable is in all the way.
Dec 24, 2007 | Vizio L32 32 in. LCD HDTV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
79 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
