SOURCE: Fisher paykel DD603 top drawer starts cycle then
When it stops and beeps can you tell me all lights that are on when you open the drawer cheers. also check to see if the water in the tub is hot if not you have a heating issue. either a faulty element or Mtr Controller module. try swapping the Mtr Controller module (computer board) from the top drawer to the bottom drawer and see if that moves the fault. cheers
SOURCE: Fisher & Paykel DD601 top drawer won't start.
Most likely the micro-switch that tells the controller that the drawer is closed is broken. Its a tiny little black switch at the back of the left drawer slide, it had a metal actuator that is prone to breaking.
SOURCE: i need to know how to take the drawer out of a 2
When you pull out the drawer, pay attention to the bottom near the bottom front panel, you will see a little tab. this tab is at both sides of the drawer, press these tabs in and pull the drawer further a bit, you can see the tub move out a little further. Now lift the tube up and out ot the rails. Push the rail inside the dishwasher, then you will be able to put the drawer down on the floor. Don't try to pull the tube out so much since hoses are under the tube has a limited length.
Testimonial: "great. thx"
SOURCE: fisher paykel dishwasher DD603 drawer is open but locked
i think you have to press the key/ lock button until the symbol disappears. You will find the exact button for your model in your owners manual.
SOURCE: FISHER PAYKEL DD603 DISHWASHER AND TOP DRAWER HAS
I know you did this but check your breaker. The other thing I would ask is has there been any storms dishwashers are the worst for power surges I see it all the time sucks but it normaly a 250 fix for a new control board
