Question about Kenmore 98702 Stacked Washer/Dryer
Kenmore washer model 417
My washer will not go into the rinse cycle. I reset the circuits and still nothing. I wait a lil' bit and the wash cycle will reset but it still stops before the rinse cycle. Please help me!!!!
  • hdelawder30 Feb 06, 2009
    My stacked kenmore will not drain or spin. I suspect the lid switch is bad. How do i bypass that?
  • Anonymous Mar 29, 2014
    the only cycle that works is Custom Cycle 1. Can I reset it to the factory settings to solve the problem, and if so, how do I do it?
    Genius:
  • 1,122 Answers
Most time on kenmore washers any of them the lid switch goes bad you can replace it or bypass it,let me know-mike
Posted on Jun 25, 2008
Kenmore 110-88752793 washer dryer. Tub filled up for the rinse cycle and then stopped. Tried turning on the dryer and that has no power either. Cycled the circuit breaker. Still nothing. Any ideas?
The circuit that supplies your washer and dryer may also have an in-line GFI outlet which may have tripped. Even though you have cycled the circuit breaker you would also have to reset the GFI outlet as well. Good luck.
Nov 26, 2016 | Kenmore Washing Machines
Kenmore Oasis HE 27082 Front Load Washer
ohm the release solenoid. could be shorted or open. check for voltage to the circuit
Sep 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore front load washer model number 417. It's been smelling after use.
The rubber seal /boot can be replaced If it's really bad but you will need to clean soap dispenser pull it out all the way buy washer magic to clean rubber seal and door also buy afresh put two tables in tub run longest and hottest cycle with extra rinse once cycle finishes than take half bottle of washer magic and pour into soap dispenser run another cycle if still bad do it all again
Apr 23, 2016 | Kenmore Washing Machines
My Kenmore front load washer will not fill--it sounds like it is draining instead. The last load washed did not spin correctly and the clothes were very wet when cycle completed.
Washer Not Filling:
  • Door Not Closed and Locked
    • Front load washers won't fill if the door is not closed and locked. Listen for the door locking when starting a cycle, then pull on the door to make sure the door is closed and locked.
  • Delayed Start Feature
    • Some washers have a delay prior to filling, where the electronic control is checking the dispenser function. This is Normal.
  • Flashing Lights or Error Code on Display
    • When there is a filling issue, the washer may shut off and display one of the following codes: LF, LE, nF, IE, FH, E10 or F20.
    • If the washer is displaying one of the above error codes, then do the hard reset procedure listed below.
If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
  1. Unplug or turn the circuit breaker off for 30 seconds.
  2. Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
  3. Press the Pause / Cancel / Stop button twice to clear the display.
  4. Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Oct 15, 2012 | Kenmore Washing Machines
Kenmore front load washer, model 417
Washer dryers often have cold water valves with 3 separate solenoids. One for the main wash and rinses (which is clearly ok) and one for the condition rinse (to take the fabric conditioner down) which is probably ok too, and the 3rd one is for the dryer. It's possible this 3rd solenoid has failed.
Washer dryers need on a steady trickle of cold water running into the condenser chamber to convert the steam into water, which then gets pumped down the drain.
e10 means that there is a problem with the water supply.
a condenser dryer needs cold water to operate properly. the e10 code will appear if:
1. the water is turned off
2.the water pressure is too low.
3.the solenoid valve is open circuit
4.there is a problem with the pressure switch (least likely)
Cold valve is at the end of blue inlet pipe remove lid and you will see it.
f E10 is only appearing when trying to dry, the problem almost certainly is the condenser valve solenoid open circuit. The green solenoid on the inlet valve. Should read about 4000 ohms.
My money would be on the solenoid coil being open circuit. The coil can be canabalised from most valves although you may have to modify the connections. For simpler repairs - contact Zanussi and get the entire triple inlet water valve to swap out.
http://www.zanussi-electrolux.co.uk/files/unitedkingdom_english/0-999/zanussi%20error%20codes.swf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 15, 2009 | Kenmore Washing Machines
Washer does not fill quickly for rinse cyle
check your water pressure if its good check the valve on the back of the washer to see if anything is stopping it up . you may have to replace the water valve
Mar 29, 2009 | GE WBSE2090A Top Load Washer
Front load kenmore washer model 417 will not enter any wash cycle. It will do the rinse and spin cycle but not a wash
will it fill with water? if not listen by the water hose when you press start to wash and see if you hear a faint buzz/humming sound. If so you need to replace the water inlet valve. cheers
Mar 25, 2009 | Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer will not do a spin cycle for rinse or end of cycle
you can check two things,. One is, is the belt broken or stretched, the other is the motor, is the motor turning if the motor is turning then replace the belt. If the motor is not turning replace the motor.
Feb 08, 2009 | Kenmore 44102 Front Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
850 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
