Question about Sharp AR-M160 Laser Printer
Ar-m 160 copier with code L3
My copier comes up with this code. What can I do to fix it
  • 32 Answers
L3 Error Code - Mirror Return Fault.
I would suggest checking for broken belt to mirror, and mirror alignment.
Posted on Mar 25, 2009
Fegarefhtasrjtsyijyt
Posted on Jul 09, 2008
Sharp m355n error L3-00
Sharp m355n error code L3 00
Strange that you have placed the same question that was apparently placed in 2014. Solution provided at that time was:
"L3-00 means that the scanner (the light under the glass) isnt moving correctly. You can reset it by pressing clear, interupt,0, interupt, 14,1, start button. Good luck"
Feb 16, 2018 | Sharp AR-M355N Grayscale Copier
Sharp m355n error code L3-00
Jan 23, 2014 | Sharp AR-M355N Grayscale Copier
I got an error code L3-00 on my Sharp AR-M237 can help you. dalmircfranck@hotmail.com
The L3-00 means that the scanner is not in home position. You can try turning off the machine and unplug it for a minute or so and then turn it on. If that doesn't work you can take off the glass and cleaning the rails the the scanner slides on and then put a slight and I mean slight layer of lubrication on the rails like ATF.
Oct 15, 2011 | Sharp AR-M237 Copier
I have a AR-287 with a L3-00 code and need to reset to see if it is fixed. No service in this area.
L3-00 means that the copy lamp assembly underneath the glass is not moving properly. 2 possible causes. The motor that drives it is burned out (very common) or some of the white pulleys that the lamp assembly is driven by have gone bad (also common, check for small ball bearings in the area under the glass) The reset code is : "P",interupt,"C", interupt, 1,4, start button, 1 or "yes", then press the "ca" button.
Mar 04, 2011 | Office Equipment & Supplies
The L6 code is flashing on my copier
No you can't, it is the polygon motor not rotating. It is inside of the Laser unit. You should replace the polygon motor. The part code is RMOTN0028QSZZ. It will cost you about US$ 80
Jun 04, 2009 | Sharp AR-160 Copier
I have a sharp ar-287 error l3 - 00 how to fix?
Hello sir; Try to make a copy without the cover then you may see the mirrow not moving out, you open the glass to serch the factor it cause this problem.
Jun 04, 2009 | Sharp AR-507 Copier
Sharp AR 507 has a code L3-00 Scanner will not retun home in time
I turned the copier off completely, then turned it back on -- it seemed to resolve the L3-00 issue.
Apr 30, 2009 | Sharp AR-507 Copier
I have an error code of L3-00 on my Sharp AR 168D. Can you help.
L3-00 indicates scan carriage motor trouble. The carriage with all the mirors on it is not moving at all (scanning) or is not moving at the required speed so it does not reach its "home" position. If restarting the copier does resolve the issue....
A few things to check... When you turn copier on does carriage move at all? if not then the motor could be bound up (not turning) - also make sure the cables pulling the carriage are properly wound. remove the main glass and make sure there are no obstructions in the way of the carriage (a loose cable maybe or dirt) can you move the cable by hand freely? if the motor locks up it could be really hard to move the carriage.
The carriage seems to be moving freely (by hand and when you turn the copier on) it could possibly be the "home position" sensor that is faulty and not reading the correct position of the carriage.
You can the copier in test mode to check either the motor or sensor. press the following keys one after the other # * C * then press start/enter , press 1 and start/enter again, sub code 1 will test the motor and sub code 2 will test the sensor.
So it could be a bad motor or sensor or the MCU board that drives the motor (or may just need a good cleaning).
Good Luck.
Mar 25, 2009 | Sharp AR-168D Black and White Copier
It could be the Mirror Home Position Sensor malfunction, it's located at the upper left section of the upper frame, if the copy lamp is in its home position, there's a lever/part of the copy lamp that actuated this photo sensor. Try clean that tiny gap with a hand blower, if L3 still occur then you should change it.
Mar 11, 2009 | Sharp AR-507 Copier
Sharp AR-M160 Laser Printer Logo
103 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
