Question about Onkyo Audio Players & Recorders
I have a TX-DS696 reciever. Problem: No sound from any listening mode except direct mode. Zone 2 works fine in all modes.
  • stevendeb294 Jun 25, 2008
    my receiver just started this problem. no changes in wiring were made.
    Genius:
  • 1,226 Answers
if you can open and self tech your unit you will find out the connection lessen, resoldered all the connection. however, if the fault is not visible you can do a series of testing because parts in it get busted specifically in the audio output. BUt some instance can be solve by hard reset. remove the battery and take a while and fix battery back and start and test.
melnavz
Posted on Jun 25, 2008
    Brigadier General:
  • 3,614 Answers
Did your wirings was correct..?
Message states the power to zone 2 is not activated when trying to listen to zone 2 speakers. Nothing in my manual about this message. How do I activate power to zone 2 on a tx-sr601
Page 77:
"Not available in Zone 2 mode" Setting not allowed because the Zone 2 mode is turned on.
"Zone 2 is not On" Will not work because the Zone 2 has not been turned on.
TURN ZONE 2 ON.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR601-Receivers-manual/id/365ag212/t/2/
Page 55 shows the prerequisite settings for using the surround back terminals for Zone 2.
Page 60 describes USING Zone 2 and points out that only analog sources can be used with Zone 2. Are you trying to use digital sources? Read the notes regarding REC OUT.
Jul 07, 2011 | Onkyo TX-SR601 Receiver
Two problem don't know if they're related. I'll sometimes get the dreaded loud POP and then no sound when playing from our cable box or Ipod, I'll lose sound on the speakers in the main room but I still...
I have the same two problems! "Zone 2" works, but the main amp will make a noise and then stop working. Sometimes when I change the listening modes around it will start working. Lately, though, "zone 1" has gone out altogether.
Jan 12, 2011 | Onkyo TX-SR603X Receiver
Onkyo TX-DS696. No right channel speaker sound
hello there 2 transistor 1 for the right channel and 1 for the left first thing 2 do is a visual check in good light check for any burn't part or any bulging capacitors if everythink looks ok then check underneath the board for dry joints if then you will need a mulitmeter to start testing components
regards
shasun
May 15, 2010 | Onkyo TX-DS696 Receiver
No sound in listening modes except pure audio and direct. Was working fine and just stopped one day. Connections are all good. Surround sound seems to be broken?
Check the input mode on the reciever so that they are set for dual, rather than just digital or analog. It might be set for analog and your using a digital optical in cable. Also make sure DTS mode is turned off, unless your watching a DVD that is dts enabled.
Aug 06, 2009 | Onkyo TX-SR804 7.1 Channels Receiver
No sound when dvd input is selected on onkio tx-ds696
Make sure your DVD setting is looking at the right audio inputs. Usually there is a menu option or a button to toggle from analog or digital input. Usually when no-sound but video ok, you have the wrong input-type selected. If you are using 2 RCS's (red/white) then you want ANALOG input mode. If you are usung a single RCA (orange) or a fiber optic input for audio, you want DIGITAL input selected. If digital os selected, make sure you plug into the correct digital input to hear. If it does not work at first, mofe the jack/fiber around into the different inputs untill you hear sound, then you will know which port is associated with the DVD setting. Unless it is self evident feom the menu.
Jun 12, 2009 | Onkyo TX-DS696 Receiver
Onkyo TX-SR705 - No Audio - Flashing HDMI
The posabilities is power amplifier on your reciever is bad,
replays reciever or repair it.More likely this is IC amplifier located on the main board of the reciever
Apr 15, 2009 | Onkyo TX-SR705 Receiver
Have to jar the unit to power on and only works with sound modes
You have a soft ware problem saw this a couple of times, return the amp to your dealer to send back to ONKYO for repair.
CABLE GUY.
Feb 24, 2009 | Onkyo TX-DS696 Receiver
Onkyo receiver TX-DS696
If you get sound on direct mode say from dvd but no sound when you go to dolby make sure you have the right input selected by pressing the digitat input button on the front of the amp,ie if dvd optical out is pluged into amp optical input 1 select this on amp then set audio to prologic2.DVDs through this input will decode to dolby digital/dts.
hope this helps.
CABLE GUY.
Jun 25, 2008 | Audio Players & Recorders
Onkyo 605 Reciever no sound from zone 2 RCAs
did the AS amp ever work properly from the RCA's?
Dec 05, 2007 | Onkyo TX-NR801 Receiver
74 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Dennis McCollum
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
