I have an RCA model r52wh74 projection tv. I was told it has a problem with the tuner. The picture comes in on an ngle the same as these slash marks // but is only about 1 inch high by 8 inches long and repeats this picture across the entire screen several hundred times. Does this sound like the tuner board is bad and if so, any Idea on finding a part number?
I have not had the TV repaired. since the local repair shop gave me a quote of almost $700.00 to repair. I only paid a little more than that for the TV new. I will just purchase a new TV.
I did not follow through with my request to you because I found several web sites that suggested not to repair because it is just not worth it.
Thanks
Posted on Jun 25, 2008
My RCA R52WH74 chassis # ITC222A wont turn on. The green power light comes on for about 10 seconds then shuts off. No picture, no sound. How do I fix it? Buying a new TV just isn't in out budget!
That model is famous for having issues with the deflection board failing. Replacing the deflection board should solve the issue. You can get replacement deflection board for the ITC222A chassis from www.tvrepairworld.com under the RCA circuit boards catagory.
Aug 05, 2011 | RCA R52WH73 Projection Television
I see rainbow on my color screen tv rca model r52wh74 color issues.
The problem of your tv is the convergence try to adjust it manually in the setting of your tv. If still same or no effect the convergence IC is already defective. You can find it inside your tv it is connected to a large aluminum called the heat sink it has a marking of stk- followed with a number.Try to replace it.
Jun 07, 2011 | RCA R52WH73 Projection Television
RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
Apr 04, 2009 | RCA P52921 52" Rear Projection Television
Locating the ''flyback transformer '' on a rca mod #R52WH74
It is usually large and black. Its the one with the rather thick red wire coming out of it. The other end of that wire either connects directly to the picture tube or into a distribution block which distributes the high voltage to the 3 picture tubes (guns) in projection TV's. Be aware that this transformer produces high voltage and can store voltage even when the set is unplugged. I hope this helps.
Mar 10, 2009 | RCA Televison & Video
RCA R52WH74 Picture is sagging, looks 3d, and double picture
Go to menu then setup look for convergence if you do not see convergence then you have A open FUSE It will be on right side of FBT flyback transfomer there is 3 of them in a roll they are small brown rectrangler looking caps but ARE FUSES it will be the one in the middle. Replace it and you have a FIXYA.
Feb 19, 2009 | RCA R52WH73 Projection Television
Tv's green light comes on then off three times
On same Board that you replaced fuse Look at cp 150 if it is puffed up on top it is bad so replace cp150,114,120 one will be 2200u 16v
other 2 caps will be 220uf 35v With tv turned OFF Press and Hold Vol- and CH - at same Time on Front Panel board wait untill set comes on you should now be in Service mode Go to Convergence Try to aline convergence Do Auto converge
Feb 08, 2009 | RCA Televison & Video
RCA Model # R52WH74
ALL of you have a problem in power supply/deflection board 3 capacitors open located cp150 2200uf 16volt and two 220uf 35 volt, check them first then resolder around FBT other wise order new deflection board 125.00
Jul 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
