Purchased new phillips DVP5990 dvd player. I have watched two DVD's on it fine. tonight I tried watching a dvd, and all the colors are reversed- IE Blue is orange, black is white, etc. I have tried unplugging and starting over, changed DHMI jack, reset to factory settings, and obviuosly changed DVD. Nada Audio is crystal clear...
  • jrstech Jul 09, 2008
    I am having the same problem. I tried a new HDMI cable. I changed the resolution, like the Phillips site suggested. I then brought the player backand exchanged it. same problem.. I do not experience the problem with component cables though. But then I lose the upscaling capabilities, don't I? AND I had to buy an extra set of cables, besides the HDMI cable.
I found a solution. Check on Phillips website to see if there is a BIOS update available. Download it, burn it to a cd. Load it in the player and it will update. After I did that, no more strange colors.
Posted on Jul 21, 2008
My DVD Player will not play my movies
Try cleaning the lens with a DVD cleaning kit.
Jun 30, 2010 | Philips DVP5990 DVD Player
Colour distortion
Try a new video cable assembly..
Sounds like the other colors arent getting thru from the DVD player
Apr 20, 2010 | Philips DVP5990 DVD Player
Unable to read mkv and avi video files from usb drive on philips dvp5990 dvd player
what error does it give? mine reads avis fine, as long as theyre within resolution limits. same for windows media format. couldnt get the mkv files to work though. the usb drive has to be formatted fat32, ntfs does not seem to work. burning these files to dvd as a data disc is another option. lets you fit 10+ hours of video on the disc vs your standard 2 or 4 hour max limits.
Jan 27, 2010 | Philips DVP5990 DVD Player
Distorted color on hdmi output
If you haven't already stumbled across the fix: I just had the exact same problem after about eights months of casual use. Unplugging the DVD player for about 15 minutes and then plugging it back in "solved" the problem. Until next time it happens, anyway.
Apr 17, 2009 | Philips DVP5990 DVD Player
Dont work after upgrade
This is a problem with the command and control software. You will need to contact Phillips customer support at this telephone number. 1-888-744-5477. Tell them that you have tried to upgrade the software and now the unit fails to respond to any function and turns itself off. I hope this information helps you with your problem.
DVd audio sounds slow
Check you owners manual for the audio settings. Check these pages and note that the underline setting are the factory settings.Pages 37-41.These are the setting most likely changed. You can always reset the player to factory settings. This will most likely restore everything to normal. This procedure can be found on page 47. The reset function is call default. This is a factory reset function.The function is found in the settings menu under the preferences.If you do not have a copy of the owners manual handy, you can use this link and find a pdf copy on the philips website.http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=DVD_HOME_THEATER_CA&sct=DVD_PLAYERS_SU&session=200906 If you still cannot get the player working correctly, you can call the Phillips customer support at this telephone number 1-888-744-5477. Give them the model number of your dvd player and the problem you are having with the sound slowing down. They will be able to help you solve this problem. I hope this information help you solve your problem.
Mar 10, 2009 | Philips DVP5990 DVD Player
Spectroniq DVD Recorder SDR-205 Disks do not play with proper col
the remote control doesn't work with new batteries
Nov 16, 2008 | Spectroniq PDV-70X
Was given a dvd of my fathers recent trip to the Philipines and when i tried to watch it, the unknown disk message came up. Phillips hometheatre system HTS8100. please help
It is possible that the DVD is not in the correct format ie.R or RW or if whoever made the recording failed to finalise the disc so as to make it compatible with other DVD players
May 15, 2008 | Philips Televison & Video
Hitachi P42H401
Maryann,
You should have an RCA cable connector with your DVD player (three wire connector color coded yellow, red, white). If you plug one end of that into your DVD player (out) and into the input #1 in the back of your TV that should be sufficient. Then just select from the input menu on your Tv to watch that input. You do this by the buttons on the lower left of the TV. One is marked "input/exit". Pressing that button should bring-up your input menu then use "menu/select" button to select input 1 and try playing the DVD...
I do have the owner and service manual if you need it just let me know...
Bill
premtech@willapabay.org
Jan 27, 2008 | Hitachi P42H401 42 in. Plasma HDTV
No color when playing DVD
your player is set to the wrong format ie either ntsc if your in europe or pal if your in america, you need to go to the setup and make sure the dvd setup is for your region. pal in europe,ntsc in america..most dvd players automatically switch.but sometimes people change the settings without knowing.
Jul 01, 2007 | Bose Lifestyle 38 System
Televison & Video Logo
119 people viewed this question
Top Televison & Video Experts
