Question about Frigidaire ATF6000ES Front Load Washer
Water leak Water is running from under the machine during the wash and rinse cycles. There is no sign of a leak at the fill hose connections, and the drain is not overflowing. How can I find the exact source of the leak? Is it, possibly, something that I can repair myself? Sue Pape papebeans@verizon.net
  • papebeans Jun 28, 2008
    It was a broken hose inside the machine. I've got one ordered. Thanks.
    Sergeant:
    Champion:
  • 330 Answers
Did you check the drain hose?
Posted on Jun 25, 2008
Washer is leaking during rinse/spin cycle
What is the model number of your unit?
Nov 23, 2012 | Washing Machines
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
Not getting enough water during rinse cycle
In the rinse cycle it will use cold only to rinse with.
You need to see how fast the water is going into the machine on rinse
Things that can effect slow fill, low water pressure, Faulty cold valve
water hose & valve filters clogged, Kinked hose
Feb 21, 2012 | Fisher and Paykel IWL12 Top Load Washer
During the wash cycle of the 24" combo washer dryer, it leaked
A hose inside the washer is your most likely culprit. On older whirlpool washers they used a plastic hose to run from the pump to the back case of the machine that was pretty susceptible to cracking.
Jun 28, 2010 | Whirlpool LTE6234D Top Load Stacked...
Puddling on floor during high speed spin cycle
you have a leak in your outlet hose normally caused by rubbing on the drum barrel / repair with tape or replace whole hose but this brand of wASHER ITS VERY HARD TO REPLACE IF DONT KNOW HOW TO
Apr 27, 2010 | Fisher and Paykel GWL11 Top Load Washer
When my machine goes through the rinse cycle it will only fill with hot water. It fills with warm water during the wash cycle.
Your hoses are reversed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 30, 2009 | Washing Machines
Water barely trickles out for rinse cycle
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
Thanks
Jan 10, 2009 | Kenmore 24032\24036 Top Load Washer
Just a trickle of water during rinse cycle
HI thanks for your question. the cold water valve either has a clogged screen or a faulty water valve. remove the cold water hose and clean out the screen, try again. could be all you have to do. if its acting the same. replace the water valve. thanks the appliance doc. please rate my answer. thanks.
Oct 12, 2008 | Kenmore 24902 Top Load Washer
Washing machine
If water is leaking only during the times when it is supposed to be coming in , then the first places to check are at the hose connections and the hoses themselves. If it continues to leak after the water stops coming in , then you have to look at the drain connection and finally at the drum seal.
Nov 22, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
114 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
