Question about Garmin GPSMAP 295 GPS Receiver
No lighting I bought a 295 on EBAY,pluged it in lighter socket and it worked fine,drove to gas station and shut off car{no batteries in unit} and GPS shut down and would not start up again.Opened case and found top left screw in top half loose bounced around in case.Reinstalled screw and found that GPS is actually working but with no lighting,you have to have sunlight shining at an angle to faintly see the display. any sugestions? Keith MacIntosh kmacintosh@ns.sympatico.ca
    Problem Solver:
  • 15 Answers
Your unit has lighting, it's just that it's set so low that you can barely see it (or not at all in bright sunlight). If it wasn't working at all then you wouldn't be able to see anything.
When the unit is on, press the power/lighting button (the red one) briefly and repeat. You will see it cycle through the highest, lowest, and user pre-sets. Stop on any of those and use the arrow up/down key to choose your own level. Press enter when finished. You can do this even when the unit appears black in bright sunlight.
Posted on May 05, 2010
Battery low signal, then shuts off.
Make sure the car charger and adapter is working (has power), is the Green light on? If not, use a 12 volt test light available from any auto parts store for about $4.00 and check to see that the lighter outlet is hot, the light should light up when you probe the centwer of the lighter socket. If the lighter is ok then replace the car charger for the GPS about $50.00 from Ebay.
Please rate my help for Fixya, it helps to improve my standing on the site. Thanks
Jan 17, 2012 | Garmin Nuvi 760 Car GPS Receiver
No battery status in the screen of Garmin 255. I just bought a new Garmin 255, before charging, it can not on, meaning, the battrey is empty, that is fine. Pluging the car charger, the unit can turn...
The battery status only shows up when the satnav is disconnected from the charger. Your first charge should be a continuous charge until the battery is full. This can be done by connecting it to your computer for 8 hours approximately or 4 hours to your car cigarette lighter socket or 4 hours to an, optional extra, mains charger.
May 20, 2011 | Garmin Nuvi 255 GPS Receiver
Turns off with pressure applied to top of unit
I have discovered an intermittent problem on my 10 year old 295 when powered by batteries.
It appears that the chrome plating is de-laminating from the battery contacts that are either side of the back panel attachment hole. At first glance it looks perfect but if you run a fingernail or other small item across the face of the contact you will see and hear a movement as if there a a loose layer of foil over it. This is causing all manner of faults including 'external power lost, shut-down in 30 seconds' when the external power was not even connected at all!
Jun 08, 2009 | Garmin GPSMAP 295 GPS Receiver
Garmin 205 will not turn on or charge.
Have you tried to plug the unit into another car lighter socket? The battery may be dead in the unit and the charge cable could have a blown fuse or the cigarette light socket may not be working. Try plugging something else into the car and see if it works. If it does then try to plug the gps cord and gps into another car to see if it works. If not you may have a blown fuse in the plug. Unscrew the tip of the plug and change the fuse. Good luck.
Apr 03, 2009 | Garmin nuvi 205W GPS Receiver
GARMIN KEEPS SHUTTING OFF
Check the fuse for the cigarette lighter socket. Chech that power is getting to the socket. Try plugging something else into the lighter socket to see if it delivers power.
HTH
Peter
Feb 24, 2009 | Garmin StreetPilot C330 GPS Receiver
No juice for gps
Have you tried a cigarette lighter or other device to make sure the socket works ?
Jan 10, 2009 | Garmin GPS
Auto shut down screen does appear when ignition is turned off
This is telling me that your cigarette lighter socket has +12VDC applied to it all the time EVEN when the ignition is turned OFF. This is not the fault of your Nuvi. On some cars, like Hondas, the cigarette lighter socket powers off when your ignition is turned off.
If you want it to turn off with the ignition, then you will have to power it from a +12VDC source that is controlled by the ignition.
- Jim
Nov 28, 2008 | Garmin Nuvi 660 GPS Receiver
Charging
"unit turns on and off with the ignition switch, sometimes."
There is something wrong with your power cord or the connection to the cigarette lighter. Your unit should turn on and off with the ignition switch. If the unit is on and doesn't turn off with the ignition switch then your unit is running on battery. If your unit doesn't turn on with the ignition switch then the unit is not getting power from the cigarette lighter.
Dec 28, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin GPSMAP 295 GPS Receiver Logo
56 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
