Question about Saeco Incanto Classic Espresso Machine
Gears out of sync - Saeco Incanto Classic Espresso Machine
  • dan collins Jul 10, 2008
    Solved: I apparently turned it off mid-cycle. The upper-left portion of the brew group stopped higher than it should have. I had to force the brew group out, breaking a small plastic cover in the process. I don't think that part's too important. Then I observed the orientation of the gears and visualized what orientation they needed to be in to re-install the brew group. I pressed all the sensors to trick the machine into thinking the brew group was installed and started the brew process. I released the sensors once the gears were in the necessary orientation. I re-installed the brew group and was back in buisiness.
  • 515 Answers
Next time get in this trouble.
Look inside the brewing unit (on the left side if it´s in your machine) you will see a little screw that holds the little plastic that goes into the machine. If you get stuck you only have to loosen this screw and then you can pull out the brewing unit:-)
Posted on Jul 11, 2008
  • Mirko Blas
    Mirko Blas Jul 11, 2008
    I forget to say you have to put in dregdraw and drip tray, then youhave to power on the machine and let it do the selftest.
Why aren't gears in sync with chain?
You have to set up sync. I could write it here but go to shimano.com and there are brilliant videos that talk you through gear sync. Very user friendly. No prior knowledge needed.
Mar 15, 2016 | Dynacraft Boys Magna 20" Invader Bmx Bike
Canon MX360 shows code 6000. Have switched of printer and computer and the error is still there. What do i need to do?
sounds like the gearing is out of sync. When you remove debris did you force any of the geared rods? some times if a printer has been jammed by debris i.e. your paper clip, the gearing gets out of sync as gears jump teeth. In the past I've rectified this problem by rotating gearing manually. Its a hit and miss method. try it " WITH NO POWER " to the printer. Put a sheet of paper in tray and rotate gearing by hand and watch closely all movement, pick up rollers, paper feed, head movement path etc. you'll get a feel for it .
once you get paper feeding manually try it with power.
good luck.
Nov 25, 2014 | Canon Pixma MX360 Printer
I can't get my 1997 camaro to go into first gear. All other gears work fine. Can you provide me any guidance on how to fix this?
Can you put it into first gear at all? when your stopped or when youre coasting? If you can then probably your sync rings are chewed up. the sync ring can just be replaced if there not too much damage. if you cant put it into 1st gear at all maybe something with your shift lever or the linkage might need adjusting.
May 02, 2011 | 1997 Chevrolet Camaro
My rio won't go in reverse is there something I'm not doing right to get it in reverse? It's a 5 speed
The transmission is out of sync. There is a part in your transmission that keeps the gears in sync, so when you shift, the teeth of the gears match up and don't grind. Take it to a repair shop,
Jun 09, 2010 | Cars & Trucks
How to download songs on gogear mix?
Download The Music Syncing software of your go gear from internet and the sync the songs which you like to sync.
Thankyou.
Jan 28, 2010 | Philips SA1MXX04P/02 GoGear Mix MP3 Player
Push the play button, machine shuts down. what's up ?
Could be a belt has broke or come off. Some vcr's are gear drive, and the gears get out of sync. You can try to un plug the unit for about 2 to 4 min. then plug it back in and it will reset the processor and it will play If the gears are out of sync,thats another story. Hope this is helpful.
Oct 24, 2009 | Emerson Televison & Video
How many types of gears ?
Shift fork, dog gear, reciever gear, slider gear and some bike have sync gears
Oct 13, 2009 | 2008 Qlink Legacy 250
Singer 2210/replaced gear/now needle bobbing cam out of sync
look here:
http://www.vacsew.com/repair/singer-600-timing.html
Apr 24, 2009 | Singer Sewing Machines
Garage door won't shut after changing gears
if you changed gears, you may have chain out of sync. read instructions with gear kit on how to sync chain.
Jan 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Help!! My gogo gear keep deleteing by music oof
Disable auto-sync in Windows Media Player to solve the problem.
Disable Auto-Sync in Windows Media Player 11 – go to Microsoft's website for pictorial demonstration
Major Symptom: The Mp3 player is adding (or deleting) songs that I don’t want onto the player
Major Solution:
Open Windows Media Player WITH the mp3 player connected
Move the mouse cursor over to the Sync tab
Click on the tiny black arrow underneath the word “Sync” to bring down a drop-down menu
Select Set Up Sync (this option will not appear if your mp3 player is not connected to the computer)
Uncheck box that says "automatically sync files to device"
Click OK to finish
Voila! You are now set up for manual sync instead of auto-sync.
-Tha Mp3 Doctor
Nov 13, 2008 | Philips SA5125/37 MP3 Player
Saeco Incanto Classic Espresso Machine Logo
158 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
