I have a Sharp LED TV (LE810E).
When connecting the headphones the speakers sound is automatically muted. I want to leave my headphones connected and still be able to hear the speakers.
Tried all relevant settings but it seems there is no way around it.
Anyone knows how can I solve this ?
Normally , you would expect the TV sound to stop when headphones are plugged in. Obviously not in this case. If you have a set of headphones, try them and see if the TV still has speakers on. If it does, then there may be a setting on the setup of the TV to get headphones to work. If the TV speakers stop, then I would think that the Logitech are not compatible with the TV. The only other thing would be is to get into the TV and disconnect the TV,s own speakers. If the wires are soldered on and not terminal connected, carefully cut 1 of the wires off near the speaker. If 1 wire is cut, the speaker wont work. Make sure both the TV and the additional speakers (If they have their own power supply) you are using are unplugged from the power before you go doing this...!
Normally, when headphones are plugged in, the TV speaker is automatically muted. To use the headphones, leave the TV volume at a normal level, and the speaker sound should stop when the headphones are plugged in.
With a RCA (F/F) to 3.5 mm (M) adapter, you may be able to connect the headphone audio out to your sound bar directly. This is an example: http://www.cyberguys.com/product-details/?productid=4730 . I'm not sure if this will automatically disable the TV speakers.
The other option is to get a digital audio to analog audio converter. One of these is http://www.amazon.com/Digital-Audio-Analog-Converter/dp/B0013LWK3A . You'll also need the optical digital cable in addition to the RCA audio cable that you have. With this you'll have to follow the manual for turning on the digital audio output on the TV (under the Sound menu) and turn off the TV speakers.
What type of TV, IE: Make and Model. If you have a SCART socket, then you can probably use the audio output connections on the SCART cable to connect to your stereo.
One thing to check is that your TV isn't muted! I know it sounds silly, but lots of people have inadvertently muted their TV's and not realized it.
Hello
If picture is OK and there is no sound output from your tv, means either its speaker or the Sound output Ic is not working. The case of speaker fault can be easly detected without opening the TV. You just place your ear very near to the speaker side and switch on the TV by AC mains [not with remote control]. You may hear a "thumb" SOUND OR A "HUM" sound from it. If any one is there the internal speaker is working fine. The fault lies in audio output Ic stage. If there is no sound said above, speaker can be suspected. Befor confirming that the speaker is faulty, if your TV has an earphone or headphone jack in front, insert the earphone or headphone socket into it, and check whether there is any sound heard from it. If there is sound from headphone, means that the headphone socket is faulty, it does not bypass the sound to the speaker. When head phone is connected, the connection to the speaker will automatically cut of. When it is pulled out from the socket, the speaker connection will resume. If the changeover switch inside the earphone socket also show this kind of trouble. If the speaker inside is found faulty, unscrew it out of place after opening the TV, go for a same type and number, impedence and shape.
If there comes the above said "HUM" sound from the speaker, surely the Sound Output Ic is faulty. Replacing it will solve the probelm. Before replacing it, check it soldering points for any loose contact. It is best to resolder all suspected point is sound section before replacing the ic.
Note: In modern TVs there will be any trace of sound, without a video signal. Without video, sound is muted. ok.
This information was found on the Dynex website: (http://www.dynexproducts.com/pc-680-23-dynex-32-720p-flat-panel-lcd-hdtv-matte-black.aspx) in the frequently asked question section on page 7. If the solution below dos not work for you. You can either go to the website by copying the web address and putting it in your address bar. Once there you can use the e-mail function to talk to customer support. You can also use the Dynex customer support telephone number 1-800-305-2204 between the hours of 7am and 12 am CST. Give them the model number of your television and the problem you are having with the use of the headphones. I hope this information helps you solve your problem. How do I get headphones to work with my TV?
o
Connect the headphone cable to the headphone jack on the side of your TV.
o
The sound will be heard through both the headphones and on the TV speakers.
o
Press Mute to hear sound only through the headphones.
o
Use the volume buttons on the remote to adjust the volume level.
o
You must remember to press mute again to hear sound through speakers. It will not automatically come on when you unplug the headphones.
