Question about Breadman TR2200C Ultimate Bread Maker
Agitator jammed. Agitator is very jam.Does not move/rotate at all.
  • 25 Answers
See my the posts on how to free the actuator
Posted on Jul 24, 2008
Ice maker tray will not rotate and dump ice. It tries to, but only moves very little. What can I do?
I am a retired service technician. There is a strong possibility that you have a jam. Often ice makers become jammed with cubes that have not dumped. I have also found a plastic sandwich bag that has jammed the ice maker. So, first inspect for a jam.
If there is no jam then the plastic gearing is broken in the motor module.
Hopefully it is just a simple jam.
Oct 26, 2014 | Refrigerators
Traction control light is on d car is making loud noice wont move
The traction control will signal when there is a difference in speed of wheel rotation from one side to the other. Sometimes an Emergency brake can come apart inside the drum and jam a wheel.
A worse case condition would be a stripped differential gear on the axle shaft. The wheel sensors may pick up the difference in rotation of the remaining shattered parts.
Only a few things to do to see how bad stuff is. Elevate both rear wheels, put transmission in neutral and try to move rear wheels. If 1 does not move, it is either jammed inside the differential or jammed
out in the brake drum.
Try getting jammed side brake drum off. If still jammed, the differential cover needs to come off.
Feb 17, 2014 | 2008 Mercury Mountaineer
Elna SU purchased in 1977 jammed; rotating wheel is unable to move forward
it sounds like the machine needs to be serviced at a sewing machine
May 05, 2012 | Elna Sewing Machines
Have 2000 explorer with power seat. the wife move the seat all the way forward and now it is jammed. the motor works the right side og the gears starts to move but the left gear is jamed. I have removed...
Try rotating the gear by hand(screwdriver), and make sure the moving frame is not cocked. You may have to un-jam the frame with a some force. Once un-jammed, if you can rotate one gear, and the other does not move right along with it, the drive cable is loose or broken.
Try plugging the seat back in and raising it up all the way to see if it will move back and forth. That will also give more room to see whats wrong with the drive system.
Aug 28, 2011 | 2000 Ford Explorer
GE WDSR2080D4WW top load washer agitator - Is there a cog type thing in the agitator that could be jammed & if so, how can the agitator be removed? I think whatever connects the agitator to the motor...
pull out the agitator. this may be difficult because soap gets built up underneath and250 acts almost like a glue. use a leather belt and put it under the agitator and pull straight up. once you get it off you will see a bolt holding down a coupling. take the bolt out and replace the coupling with a new one. this should solve your problem with the machine not agitating. the part # for the bell coupling is: WH43X10009.
Oct 24, 2009 | GE WBSR3140DW Top Load Washer
Vacuum roller will not spin. Reset button does not workl
The warranty should cover you for a year unless something you inadvertently sucked up caused a jam, whihc you may be able to determine or fix yourself. See if the agitator is easy to turn - if not, something is probably jamming it; if it turns in one direction, but not the other, something may be wrapped around it. If it turns easily, it's possible the motor either died early due to a defect or a broken wire.
Jul 03, 2009 | Kenmore 31913 Progressive Direct Drive...
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Jammed agitator
Some further checking indicated a bad transmission. As the unit is 15 years old, I decided the best solution was a new machine! ..
Dec 03, 2008 | Washing Machines
Make noise during wash cycle, has no agitator action and no spin during spin cycle/drain cycle
Looks like the bearings may have failed. TURN OFF the POWER and try and rotate the agitator/tub by hand. If it is jammed you should investigate why. Possibly caused by bearing failure or something wound around spindle.
Take care and do not attempt to investigate the problem without first disconnecting from the mains!
Apr 16, 2008 | GE WBSR3140DW Top Load Washer
Broken vacuum
check the belt it may have broke or stretched out
Dec 31, 2007 | Kenmore 23613 Progressive PowerMate Bagged...
Breadman TR2200C Ultimate Bread Maker Logo
94 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
