Question about Mac-Audio Compact 220 Car Subwoofer
When i switched it back on it stopped working
HX-D7 DVD Compact Stereo Audio / Video System with 5 DVD Changer Shelf System: my jvc was working fine but all of a sudden it sto...
Hello
this could be a power fault, but first check the power plug if it is in contact with the power socket and if it is then you have to open the back cover of the system to check the fuses if blown resistor,capacitor and transistor with the use of a multimeter to check for back component and if bad replace faulty ones.
Then power on to confirm, if not on then take it to the manufacturer or a skilled personnel to handle it
May 17, 2010 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Honeywell compact refrigerator model # 88031not cooling.
Honeywell compact refrigerator model # 88031 making a clicking noise, not cooling, interior light blinks, and the fans in back are not working properly....seems as if it's not getting full power. worked fine for about a year and justed stopped.
Mar 18, 2010 | Refrigerators
Nakamichi compact 1 stopped working
yes!! if you know how to dis assemble the unit..
1.remove the cover
2.remove the system board
3. check it if wet put it in to the roof with the suns heat by 3 hours.. check again if its dry already assemble it back then power check it then go!!!!
GOD BLESS !!!
Apr 06, 2009 | Nakamichi RE-10 Receiver
I have 2 10inch spekers in a box that just stopped playing the bass! can anyone help? ive checked the fuzes!
If the fuses are good , this could still be a prob with amp, check spkrs with a ohmeter(cheap one from the Shack or anyplace) by touching both leads to spkr terminals, disconnect spkrs first.Have ohmeter set to ohms Rx1 and you Test amp out put by connecting two spkrs that you know are good. Good luck and please rate this answer,thanks.
Apr 06, 2009 | Mac-Audio Compact 220 Car Subwoofer
I have a jvc compact component system MX-C220 (old school, i know), and it wil shuffle through the different audio options without being prompted to do so. i don't have a remote and i keep having to run...
yeah i have the same stereo and i know what u are talking about. to fix this all u have 2 do is press the demo/fm mode button next 2 the power button. that turns off the demo which is y it switches through the different audio functions. but i have another problem with mine it works and everything but 4 sum reasons it has problems playing burned cds, it works pretty well with cds bought but burned cds usually never work or takes min or hours 2 work. any suggestions
Sep 01, 2008 | JVC Audio Players & Recorders
Stopped playing music
Since you have a MAC, your probably using ITUNES, ITUNES are MP4 format which this unit doesnt play, you have to make sure what your putting on is MP3 audio files:
Here is a guide on how to convert songs to MP3 on ITUNES:
http://www.wellesley.edu/Computing/Idocs/Itunes/convertMP3.html
Once you get the audio files converted, drag and drop on the drive from where they are saved on your computer.
To play the audio files:
hold the play button until red light comes on, then press Play again, light should blink which means its playing.
Jul 31, 2008 | Coby MP-C883 MP3 Player
Sony CDX CA720X in my boat
Mac, I had the same problem, it was the hard wired remote at the Stern. When I unplugged it from the radio, everything came back to life and the radio and CD player are working fine. I'll have to replace the other remote at some point.
Hope this works for you...
Brian
Jul 16, 2008 | Sony CDX-CA720X CD Player
BuSY
Sounds like a corrupt format on the Compact Flash card.
Take the bettery out, then the CF card. Put the battery back in but don't put the CF card in. Switch the camera on and see if you get a different error on the screen. If you get something like 'Missing card' then the camera is OK.
You will probably have to plug the CF card into a PC/Mac via a card reader to see if you can reformat it. If it doesn't work I'm afraid it will need replacing.
Nov 05, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Behringer stalls my mac
Yes, i'm surprised it hasent kernel paniked. Is the interface bus powered? What Macintosh/ OS are you running?
May 02, 2007 | Behringer F-CONTROL AUDIO FCA202 External...
Mac-Audio Compact 220 Car Subwoofer Logo
172 people viewed this question
Top Mac-Audio Car Audio & Video Experts
xxxxxx xxx
Are you a Mac-Audio Car Audio and Video Expert? Answer questions, earn points and help others
