Question about Sony KV-20FV12 20" TV
Sony KV-20FV12 channel will not change
Lightning strike last night and channel is stuck. Will not change. the number changes on screen but picture doesn't change. Is it worth fixing?
  • wabbitt1958 Jun 25, 2008
    Thanks "freetek". I lost several low voltage/transformed items. ie. doorbell, cordless and base for same. It didn't hit the house. It hit a tree about five feet from house and went into a storage shed through a light on the tree and blew a couple breakers. No major harm to house though. I figured the TV was toast when I turned it on though. Most of my other high dollar items are all on surge protection. Thanks again for the post.
  • wabbitt1958 Jun 27, 2008
    Thanks "hansonsux" for the replacement advice. I really don't think anything was effected except the transformed things mentioned. I was on the computer and the Sony was on right next to me and nothing even blinked. Not sure how it works exactly but I don't beleive anything else was effected. It looks like it went down the tree, into the little outhouse/storage building through the wire running from the light, blew that breaker and anything close to it and went out through an extention cord that I had plugged into my camper. Very lucky that the camper wasn't effected either. Not really sure how or why but everything except the TV in the bedroom looks AOK. Actually, the wire for the light wasn't even hot. I had disconnected that several years ago because the light made a loud humming noise because it grew into the tree. I think I will cut that wire away so there is no connection to the electric. Thanks Again for the advice.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 62 Answers
I want to point out the surge protectors are not generally meant to protect against lightning. Sometimes they can protect though as long as it's a very indirect strike. Perhaps since it went into the breaker box, most of the energy went to ground.
Posted on Jun 25, 2008
  • hansonsux Jun 25, 2008
    Any sort of surge will degrade any surge protector. They can take so many little "hits". Since this was a rather large hit no matter how much went to ground, this was still from lightning so this would have surely degraded the effectivness greatly.
    So it is very advisable to replace your surge protectors.
  • Sony Master
  • 5,568 Answers
Pasted from another message I just posted-
It may be too late for this advice, but if you live in a lightning prone area, you should consider having a 'whole house surge protector' installed.
The cost should be well under $300 (a lot less if you install it) and with the included insurance (most often for $25,000) it is a good investment.
If your house was struck, I'm surprised you don't have a list of things that no longer work.
No, I don't think it is worth the cost of a repair, if you can even find someone to do it for you.
Most of us are retired-
Posted on Jun 24, 2008
Sony KV- 20FV12 get no signal on screen. Same cable outlet works on other TV as a test. Cable ON in menu. Auto Set search produces search but still no signal.
Hello
If auto search is going on smoothly, and there is no stations on air is memorized, and display no signal, there are tow possibilities. The first one is antenna is not connected properly. Check the antenna connection for firm. The second one is tuner fault. If the tuner inside the tV is faulty, or it does not gets proper voltage to work, this type of fault land display will see on screen. Check if proper voltages are comming to the tuner section in circuit board. If voltages are ok, and still there is no signal display, just check it with external video input. That is, connect it to any dvd or cd with AV connector, and set the TV to AV mode and play a disc. If there is picture, the video side of your TV is OK. If not, Video-chroma-RF jungle IC is faulty, and not the tuner. OK.
Feb 03, 2011 | Sony KV-20FV12 20" TV
Have sound but no picture. Turned TV off last night and when I turned the TV on this morning there was good sound on all channels, but there is no picture. Just a black screen
is hv circuit problem a power transistor to 25KV transformer maybe dead, check the HV Circuit, or 1XXV output from Mains transformer the fuse maybe dead
Mar 11, 2010 | Sony KV-36XBR450 36" TV
Picture goes on and on constantly
I have the same problem. Picture cuts out completely then back on. When I first turn it on, it does this constantly for about 15-20 mins, then about once every 30 mins or so. The sound is fine, but the picture just flashes on and off.
The color is also starting to shift a lot and cannot be fixed by adjusting COLOR-BRIGHTNESS-PICTURE in the video control menu system. Nothing seems to correct this. I've even unplugged the TV over night to see if it needed some sort of reset. Model = KV-20FV12. Purchased in 2004
My connection is a direct cable connection - Comcast cable. Same problem persist while showing a DVD as well.
Dec 18, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Lightning hit sony kv29xbr85
If it was me...I would first check the series of fuses on you main circuit board. Look for any burned components.
Dec 16, 2007 | Sony KP-46WT500 46" Rear Projection...
No picture but sound works.....
  • adjust brightness setting when playing tv.
  • adjust screen control located on flyback transformer.
  • hope this will help.
Oct 23, 2007 | Sony KV-36FS16 36" TV
Channnel keeps flicking like your changing channels with remote
when you say flickering??? are you saying the screen goes black and comes back on?? does the sound go out at the same time and comes bag on with the pic ? Is the sound there when this happens but is distorted. Is the pic blacked out or is it greying out with lines and twisting?? Need more info please as if its blacking out and the sound goes with it it may be going into shutdown. If the pic is getting kinda greyish with it twisting and the sound is there and ditorted then the tuner could be bad
Mar 25, 2006 | Sony KV-32S26 32" TV
Sony KV-20FV12 20" TV Logo
80 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
