Question about Cameras
I have a Nikon N65 camera not digital.
Unable to take a picture. does not ckick instead I have an FEE message on thescreen. I put new batteries. Have 23 pictures taken. Set on Auto.
  • 2,071 Answers
If you take the battery its okey there nothing happens to your 23 pictures it remained in the memory card and if you doubt it transfer it to your PC for safety .Then do the the procedure ive said above by taking the battery .Start the camera without a memory card inside and go to view picture ,see if the FEE still there ..
please rate the solution as FIXYA if this helps you solving your problem...
Posted on Jun 25, 2008
Hello! I have a normal NIKON N65 SLR camera. I am going to buy a digital SLR camara. Is it possible to use my old NIKON lences for my new NIKON digital SLR body? Thanks in advance! Adrian
Yes for the higher end cameras - not for the cheaper ones as they use a lens with a motor inside instead of the one in the camera body (you can use your lenses and focus manually)
Oct 23, 2013 | Photography
I'm getting an FEE symbol on the window when I turn the camera on and ready to take a picure.Nothing happens. No click. This an N65 Nikon not a digital
You will need to go into more detail.
Do you have film loaded and how many shots have you taken.
Is this equipped with a motor drive? Are the batteries fresh?
Please be specific and detailed.
Thanks,
Worldvet
Jun 24, 2008 | Nikon Cameras
Nikon N65 won't take a picture
If you have the lens set to the lowest number, you should be seeing a FEE error on the display. The lens needs to be set to the highest number, typically 16 or 22.
Feb 13, 2013 | Nikon N65 35mm SLR Camera
I bought new batteries for my N65 and my camera keeps blinking ERR.
The manual mentions only 2 conditions where the Err message appears. First if it is Err + E at the same time, the film has not completely wound and needs to be reloaded.
If it is Err alone, the manual states to fire the shutter and see if the message remains. If it does, to contact a Nikon Authorized Service Rep.
Jun 23, 2011 | Nikon N65 35mm SLR Camera
Nikon N65 won't take picture
The problem is, that you have a lens witch has an aparture ring on it and some exposure modes needs it to be fixed on the smallest aparture (e. f22). When its done the camera should not say fEE no longer.
May 15, 2009 | Nikon N65 35mm SLR Camera
Not advancing
Try Putting a new roll in.
Apr 17, 2009 | Nikon N65 35mm SLR Camera
Nikon N65 Unable to take picture
Hey colettekm,
What this message should mean is that a non G-type Nikon lens is being used and its aperture is not set to smallest aperture which would be the largest number on the aperture ring on the lens. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 24, 2008 | Nikon N65 35mm SLR Camera
FEE reading on n65 camera
Make sure your lens has the aperture ring to the minimum f-stop number, i.e. (f-22, f-32, largest number) and the focus switch set to 'S' or 'C'
May 24, 2008 | Nikon N65 35mm SLR Camera
FEE signal
You can only change the f-stop using the camera's controls. Trying to change it on the lens will not work with the N65
Mar 19, 2008 | Nikon N65 35mm SLR Camera
Fee to error
Remove the batteries for 5 or 10 minutes. Remove the lens from the body and replace it. Make sure the lens is on f22 before you put the batteries back in and turn on the camera. If this doesn't solve it, try rewinding the film you have in the camera and try a new roll. The other thing to check if none of the above works is to remove the lens and check the small tab just on the outside of the mount ring at about 7:00. The tab is spring loaded and you should be able to push it with your finger and it will snap back. If it doesn't, the tab plate will need repaired or replaced
Dec 25, 2007 | Nikon N55 35mm SLR Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
