Samsung PN42A400 42 in. Plasma TV Logo
Posted on Nov 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung plasma tv pn42a400c2dxza. when i try to turn it on it starts making clicking sound than it starts buzzing. i unpluged everything from the power supply and the buzzing sound stopped. but when i plug the X or Y -Main the sounds come back
Chi Chu
Level 3:
  • Samsung Master 8,457 Answers
  • Posted on Nov 29, 2010
Chi Chu
Samsung Master
Level 3:
Answers
8457
Questions
0
Helped
2820374
Points
26282
This problems is the power supply board is causes and the problems.Try website like Ebay.com buy a whole refurbish power supply board for the replacement,will solved this problems.
I have a samsung 50 plasma tv that will not turn on now. If I unplug it and plug it back in it makes a clicking sound 4 or 5 times then nothing happens.
Probably bad capacitors. Samsung TVs are famous for this. Relative easy fix for a technician that knows how to do board level repairing
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Humming sound
Samsung states - A buzzing sound from your plasma TV is normal. It is caused by the electrical charges used to create the images on the screen. The buzzing, however, should not be so loud that you can hear it when the volume on the TV is set at normal levels.It is also important to determine the type of buzzing sound. A sound like a ground hum is completely normal. This buzzing can originate near the power cord connection or from the SMPS board position on the upper back of the TV. The buzz will be more audible as contrast increases on the screen, most notably when displaying an all white screen. If the buzzing sound is loud, you may have the Contrast set too high. Lower the contrast to reduce or eliminate the buzzing.You may also have loud buzzing if the rear of your Plasma TV is too close to a wall or other hard surface. Try moving your TV away from the wall until the buzzing is minimized. [1]
If the buzzing is at a higher frequency and resembles a crackling sound (like the sound of Velcro being pulled apart), and originates from the upper middle back of the TV, you likely have a failing SMPS board. Place a support call with Samsung to have the SMPS board replaced.FP-T5084 Have a known buzzing problem with a very simple fix.If the buzzing is coming from the left or right sides of the rear and the volume can be changed by pressing lightly on those locations, you are probably hearing the vibration of the grounding springs on the back panel. Call Samsung (or whoever) and have a technician confirm the problem. The easiest fix is to insulate the offending spring by applying some felt tape.
Plasma will not turn on
i plug it back in and let it do its clicking and with in 2 min tv was working agian
My turtle beach is buzzing!!! PLEASE HELP!!!!
The X3 uses infra-red (IR) wireless, which is at the same frequency as interference from many plasma TV sets. Do you have a plasma screen TV?
My tv wont turn on now
sounds like you fried your digital board or power supply not sure need more info on what tv is doing
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
