Question about Amana ATB1836AR Top Freezer Refrigerator
TOO Warm....fresh food
Temp suddenly rose from 40F to 60F....last three days....with temp setting buried on 7....freezer compartment temp is perfect....whats up?...I was told I have a no clean condenser unit so I 'm assuming the coils are fine! fridge is 9 months old! We have had humid weather...but that should not alter fresh food temps so drastically!
    Genius:
  • 1,122 Answers
IT SOUNDS LIKE THE AIR DUCT TO THE FRIG. MIGHT BE STARTING TO FREEZE UP,CHECK THIS FIRST ALSO MAKE SURE TEMP THERMOSTAT IS ON INITIAL SETTING,LET ME KNOW-MIKE
Posted on Jun 25, 2008
Bottom of fridge not cooling
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment. Something is restricting that air flow which causes your fresh food compartment to stay warm.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
If the panel is restricted from moving (stuck closed, for example), the freezer will get VERY cold while the fresh food compartment will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is restricting air flow from the freezer to the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Hope this was helpful. Good Luck.
Aug 29, 2009 | Estate Model: TT16DKXSQ Top Freezer...
Maytag bottom freezer Model MBF2254HEB not blowing cold air into freezer or fridge, blows warm air if blowing at all, starts and stops. Any suggestions? Possibly a reset button somewhere? Thanks - Kurt
Aug 29, 2009 | Refrigerators
Fridg is not working right
Aug 28, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Have Sub zero side by side 561 Why does the temperature control not increase the cooling of the refrigerator? The milk and vegetables are spoiling.
Aug 28, 2009 | Refrigerators
Working fridge, warm freezer.
In your case, the door must be stuck all the way open, allowing all the cold air to be diverted into the fresh food compartment. The compressor cycle is controlled by the thermostat in the fresh food compartment and thus 'short cycles' because the fresh food compartment acheives normal temperature while the freezer is relativel warm.
If the panel is restricted from moving (stuck in the extreme open position, for example), the fresh food compartment will get VERY cold while the freezer will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is diverting all the cold air from the freezer into the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel/door/flap itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Aug 28, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Fridge doesnt stay cold
Aug 28, 2009 | Maytag MZD2766GES Side by Side...
Coils keep freezing up its 4 years old
Iced-over evaporator coils, accompanied by a non-chilled fresh food compartment, happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side got warmer as well.
The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall between compartments which opens when the fresh food side needs cooling. If no air is moving in the freezer compartment, temps in the fresh food compartment climb.
I replaced the temp sensor in the fresh food side and solved the problem for a while.
I bough a pair of thermometers at a kitchen store and put one in the freezer compartment and one in the fresh food compartment so that I could occasionally check to see if it made sense for the compressor to be running (ie, was it really necessary to be trying to cool either compartment, or were they already cold enough).
About six months later I had the coil icing problem again. This time the fresh food side seemed cool enough (according to the thermometer as well as the fact that the flapper door would close, indicating that the computer knew to not try to additionally cool the fresh food side).
The thermometer indicated that the temp in the freezer compartment was cold enough, but the system computer continued to run the compressor. So I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
Use a website like www.partselect.com to look up a parts diagram for your fridge and see if you can order just the temp sensors. Other websites (www.repairclinic.com and www.appliancepartsworldwide.com) may also be helpful. I have no affiliation with any of the sites I just mentioned - I'm just posting them as resources.
Jul 30, 2009 | GE GSS20IEP Side by Side Refrigerator
Top refrigerator not cooling--freezer icy
This has happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side continued to climb. (The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall, so if no air is moving in the freezer compartment, temps in the fresh food compartment climb.)
I replaced the temp sensor in the fresh food side and solved the problem for a while. About six months later I had the same problem again, so I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
Jul 28, 2009 | Refrigerators
Turbo cool will not turn off in GE side-by-side refrigerator. Replaced circuit board...still stays on
There are three temp sensors in my GE side-by-side model GSS20IEMDWW (two in the freezer and one in the fresh food side). Replacing the temp sensor in the fresh food side was enough to allow the compressor to finally turn off.
For me, the problem manifested with an iced-over evaporator coil inside the freezer compartment. Since the compressor never cycled off (presumably because the temp sensor was providing faulty data about the temp inside the fresh food side, thus causing it to continually attempt to cool), the coils were constantly chilled. Eventually the ice on the coils would block the air flow and the freezer side could no longer freeze
I purchased a pair of inexpensive thermometers from a kitchen store and put one in the freeze and one in the fresh food side so I could occasionally look at the temps to see if it made sense for the compressor to be running - ie, was it really a warm-enough temp for cooling to be required, or was the computer reading faulty sensor data.
Six months later I also needed to replace both temp sensors in the freezer compartment. My refrigerator is about seven years old. I would recommend replacing all of the temp sensors just to rule that out.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=GSS20IEMDWW&mfgModelNum=&fkMfgID=2
Your model may be different, but this will give you an idea of part numbers and relative locations of the parts.
Jul 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Amana ATB1836AR Top Freezer Refrigerator Logo
222 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
