Question about Kenmore Oasis HE 27082 Top Load Washer
Loud tapping noise
During a wash cycle there is a very distict and LOUD tapping sound that occurs. Just started.
Perhaps something is trapped in the drian hose?
Any ideas?
  • 1 more comment
  • stacih12 Jun 27, 2008
    I accidently washed some pants with change in the pocket. The change somehow ended up in the pump and made a very loud tapping sound when the water drained. The change ended up making a hole in the hose connected to the pump and we had to change the whole thing which meant taking the entire machine apart.
  • Anonymous Jul 10, 2008
    I also got the same tapping sound, had a tech come out and he said that the tub bumps again a part in the machine, so he siled it down and I have not heard it since. He said they have gotten a few calls with this same problem, it seems to be a defect but like I said once it was filed down you will not hear it again.
  • Bumpkins Sep 30, 2008
    Took the adivce of "Guest" (tilt the washer and disconnect hose to pump) and found the noisemaker - a dime. We are now ten cents richer and we saved ourselves a service call!
I have the same problem. It happens because there is debris in the drain pump (change, bobby pins, barrets, etc.). With the power off, if you flip the washer up on its left side (looking forward at the washer) and rest it on a wall or something, you can see the pump at the back right side of the bottom. With the water drained, you can disconnect the hose where water flows into the pump from the wash bin and put your finger inside the pump and remove most items that are in there. Be prepared, though, because if there is anything "long" in there, like a bobby pin, it will not be easy at all to get out. If you can get everything out of there, the "tapping" will stop. Be forewarned, however, getting the clamp for the inlet hose on will not be an easy task. Make sure you have pliers and a strong pair of hands. Good luck, and stop trying to wash your barrets and bobby pins! This is a CLOTHES washer! HA HA
Posted on Jul 15, 2008
My whirlpool duet washer hammers very loud when it spins. The outside of the machine doesn't seem to vibrate much but it is very loud.
That is a common occurrence with dryers such as this one. Even though it sounds bad, it is harmless. If it really bothers, you can re-balance the load and it should reduce the vibration.
Jul 29, 2008 | Whirlpool Washing Machines
Whirlpool washing machine make loud noise after spin cycle quits. Noise continues until cycle winds down. Sounds like a machine gun being fired
Hello,have to tell you that most noises from a washing machine occur during the spin cycle. If you hear loud thumping noise during the spin, the load of cloth may have become unbalanced. Stop the washer and redistribute the cloths, then restart the machine. Repeat these steps if necessary.
Thanks
Jun 04, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Makes loud noise when on spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 09, 2010 | Amana 3.2 cu. ft. Top-Load Washer
Very loud rumbling noise during spinning
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Sep 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leaks water and is abnormally loud during spin cycle
Sounds like the bearings are broken. This is a serious issue and may be quite expensive. If your appliance still under warranty, contact the manufacturer for assistance. If not, don't be afraid to ask the customer service if they can provide some assistance to replace your washer (as the repair will be quite expensive), perhaps the manufacturer may be able to provide a rebate or something like that if they appreciate you as customer.
Good luck.
Aug 31, 2009 | Amana Washing Machines
Series 90 washer loud clicking during Slow wash cycles, Fast OK.
Turned out to be a loose electrical connector near the motor.  Plug was re-connected and secured with a zip tie to prevent another disconnect.
Apr 03, 2009 | Kenmore Washing Machines
Loud noise when aggitating code says motor not rotating properly
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
or something stuck up in spinning motor assembly.
thanks and plse do not forget to accept the solution.
Apr 02, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Loud noise
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
139 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
