Question about Motorola Mobility RAZR V3xx Cellular Phone
Motorola razr keypad not working
My cellphone the keypad is not working , can sombody help me!!
Generally, the keypad does not need to be changed. Usually, one of the flex connectors in the flip (screen/camera) portion of the phone is loose, dirty and/or corroded (maybe from water, sweat, wear, trauma, etc). This is relatively easily fixed by a semi tech savy consumer. You will need a size T5 star driver (and possibly a T6) and a small screw driver, along with some rubbing (isopropyl) alcohol and some Q-tips.
For more information on servicing your phone, you should do an internte search for RAZR dissassembly http://www.google.com/search?sourceid=navclient&aq=t&ie=UTF-8&rls=GGLJ,GGLJ:2006 -45,GGLJ:en&q=razr+v3+disassembly and you'll get lots of hits including videos like this: http://video.google.com/videoplay?docid=-5120755491924318860#
When you have the top case dissassembled, the connector with the black patch on the top is likely loose. Clean the connections thoroughly with alcohol and a Q-Tip and reassemble. If it doesn't work, or only works partially, another cleaning may help (I had to go in twice).
http://www.celtnet.org.uk/mobile-phone/disassemble-motorola-v3-3.php
Posted on Jan 18, 2010
    Genius:
  • 1,673 Answers
Take the phone in to have the keypad changed. That is the fix.
Jerry G.
Posted on Jun 28, 2008
Keypad lights some off
Those bulbs that doesn't light up, i think it is damage. Better replace those bulbs with new one by asking professional help with a qualified cellphone technician.
Oct 15, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Keypad
you can source one online or take it to another repair store to hvae it fix.
Oct 08, 2008 | Motorola Mobility RAZR V3i Cellular Phone
RAZR PHONE KEYPAD NOT WORKING
I suggest you go to your nearest Cellphone Repair Shop. Your flexible cable has damage, it need to be replace.
br
Aug 06, 2008 | Motorola Mobility RAZR V3
Motorola v3x problem
The connection from your LCD to the systemboard might have a loose connection or might be disconnected.
If you have the skills, you can open up the phone (back part or keypad part) there should be a screw at the back and u must use a creditcard or any card similar to slide out the casing.
On the uppermost part of the board should be the flex which looks like a brown film and it has connectors that hooks up with the board. Just try to re seat it.
Hope this helps...
Jul 22, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Keypad
this is true, the flex cable for your keypad may be getting messed up, fortunately flex cables are often very cheap if you look int the right places, you will also need the cellphone screwdriver kit they have the special t3, t5, and t6 screwdrivers needed to disassemble the phone
May 07, 2008 | Motorola Mobility RAZR V3
Motorola razr keypad seems locked???
It seems your Keypad Flex is messed up. common issue on the v3 - we can fix this for you - $25+ shipping
http://horizonwirelessonline.com
Jan 21, 2008 | Motorola Mobility RAZR Cellular Phone
Motorola razr freezing
your phone problem is the keypad flex of your phone'
you can fix it by replacing the keypad flex'
motorola dealer has the keypad flex'
ask for a skilled cellular technician to re-place your keypad fle..
i hope it will helf to your prob...
Jan 07, 2008 | Motorola Mobility RAZR V3
No display screen
u must let your cellphone dry up b4 u turn it on,1st thing to do dismantle your cellphone case then u can use a hair blower to dry it up. then try to turn it on. if its not working maybe your cellphone suffers a shortcercuit
Dec 18, 2007 | Motorola Mobility RAZR V3
Cellphone freeze
one thing to do is loosen the screw on front screen near the volume buttons..remove the small rubber circles first so you can see the screw..
Nov 07, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3xx Cellular Phone Logo
735 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
