Question about Intel Motherboard
Disabling Raid Utility
My raid utility is not listed in the bios and i need to disable it. i installed a 750gb sata drive and the raid utility keeps trying to set up a raid array using 2 drives as one drive. and since there is only 1 drive the thing keeps looking and looking for a second sata drive and my computer is frozen untill i reboot.
  • 4 more comments
  • gorathtar Jun 25, 2008
    its an asus A7N8X-B DELUX
  • gorathtar Jun 30, 2008
    my mobo was made in around 2002 when satas were still mainly used in raid so there was no feature put on it for disabling raid the newest update for bios for that mobo is for the A7N8X Delux model and my mobo is the A7N8X-B Delux model i am worried that if i install the only bios update offered for that sieres that i will end up loosing my mobo for good.
    My raid util offeres 2 types of raid (Raid 0 and Raid 1) but by default its set to do raid 0 using 2 raid drives as if they were 1. and it wont let me change anything untill it finds the second sata and since it cant it is stuck in a never ending search.... untill i force reboot. and if i dont have a sata drive plugged in i am unable to enter the raid util to change raids.
  • gorathtar Jul 03, 2008
    after looking around on the net it doesnt look like asus put a way to disable raid in the early models of my mobo. if the option to turn off raid is not in the bios is there another way to turn off raid without going through bios?
  • Anonymous Aug 14, 2008
    This is just a quick addition to mention that thanks to this brilliant answer I got my computer working.
    Same problem: Previously a RAID setup but after an upgrade I needed to rewipe everything and start with a single HDD. After failing so many times I found this post and found a setting hidden away under the BIOS to disable the RAID. It then worked. Thank you thank you.
    Using ABIT AV8 motherboard (taken from the print on the motherboard).
    BIOS was under the onboard components setting.
    thanks again
  • Anonymous Mar 12, 2009
    I am not computer wise, how do I stop the RAID Utility, in simple spesk please
    Problem Solver:
Hi under Advanced in your bios is there anything like Raid Rom if so try disableing it then your pc wont look for raid devices and u should be able to boot strieght to your HDD u have installed
Posted on Jun 27, 2008
Enable RAID system
use this guide, this is fo the embedded sata raid controller that comes standar with the ml150 g5.
Enabling SATA RAID functionality in the BIOS Setup Utility: 1.Boot the server, and then press F10 to enter the ROM-Based Setup Utility (RBSU).
2.Go to the advanced tab.
3.Enter the IDE configuration or hard disk configuration.
4.Change the ATA/IDE configuration to enhanced or SATA controller 2 enhanced (if not available then use enabled mode).
5.Configure SATA as RAID or configure controller 1 as RAID.
6.F10 to save and exit.
7.Reboot the server.
8.During post f8 will now show up for the embedded SATA set up.
•Creating the RAID volume.
1.Enter the embedded SATA setup by pressing f8 during post.
2.Enter the array configuration utility.
3.Enter create array.
4.Create the raid volume as desired.
5.Save and exit.
i hope it helps you!!!
Aug 11, 2010 | HP ProLiant ML150 G5 Server
How to install windows 7 on Satellite A205-S5880
To install Windows 7 no need for RAID driver. If you face issues in installing Windows 7 disable RAID in BIOS, install Windows 7 and then install RAID driver.
How To Manually Upgrade from Vista to Windows 7 - Satellite A200/205:
http://cdgenp01.csd.toshiba.com/content/support/downloads/PSAF3U-PSAF6U-Win7UpgradeInstructions.pdf
Windows 7 Drivers page:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2060003&rpn=PSAE3U&modelFilter=A205-S5880&selCategory=3&selFamily=1073768663
Dec 31, 2009 | Toshiba Satellite A205-S5880 Notebook
When I boot up i am prompted to press cntl e or f4 for raid utility. I am trying to clone my ide c drive onto a new seagate sata
Some older mainboards only allow you to use SATA after you have declared your disk through the raid utility. Watch out when you do so that you select the right configuration (Raid 0)
Aug 10, 2009 | Seagate Barracuda 7200.10 320 GB SATA Hard...
Need to boot from SATA drive
If you only have one SATA drive, you do not need to have the RAID setting turned on in CMOS. RAID is only for 2 or more SATA or SCSI drives. Shut that off and try again.
Mar 14, 2009 | Computers & Internet
Setup raid configuration
Just keep pressing F2 on startup to go to bios. In bios go to advanced screen and highlight "show raid" option. Hit enter and highlight show raid. Then save changes and exit. Press Ctrl + I when booting and you will open raid configuration utility. Make sure you backup all your files and create RDVDs before making any changes to raid.After pressing ctrl+i you will get raid configration utility. From there "delete raid" -> create new raid volume and select raid type as raid 0. Then boot from RDVDs and install operating system.Let me know if there is any trouble with that
Dec 19, 2008 | Sony VAIO VGN-AR630E Notebook
Remove raid to allow installation of sata
REset your Bios setting ..and then boot your computer to safe mode and then remove the raid installation from the add/remove programs....do not boot your computer from the utility disk.
melnavz
Oct 20, 2008 | Computers & Internet
Sata raid config
first check your bios & see what raid chips are enabled,usually there's 2. Your main raid is on the first 4 sata connectors, the other chipset probably controlls the remaining sata ports. So if there's an option to disable one raid chip,disable one,just not the one that you're using. I don't know what your bios screen looks like,so this is just a general view based on my experences with various boards,mainly asus.
Jul 13, 2008 | Abit AW9D-MAX Motherboard
RAID 1 not installing with WinXP32
Did you run the RAID configuration utility?
Jan 20, 2008 | Intel D875PBZ Motherboard
Biostar P4M800-M7A Motherboard SATA RaiD Mirror Array As C boot Disk
hi, you need not have to upgrade the BIOS,, set the SATA HD on the IDE channel in the BIOS, or what options r avilable for SATA controller, if it is set to RAID, you will need a raid utility to format the SATA, or it wont shoe in windows, let ,e know
Dec 17, 2007 | Biostar P4M800-M7A Motherboard
Raid JMB363 RAID BIOS UTILITY
The P5K motherboard has a four port vanilla ICH9. There
Is no RAID on the Intel, when the chip has only four ports?
So S1, S2, S3, S4 are not RAID.
In the P5K manual, the RAID function exists on the Jmicron
Controller. One drive connector is internal (SATA_E2, on the
Left of the motherboard picture in the manual), and one
Drive connector is external (F_ESATA on the back I/O area).
This is not convenient for building a RAID0. (The intent is
To allow making RAID1 backup disks.) You'll have to snake
The SATA cable back into the computer, if you hope to use
It with two internal SATA disks.
The manual has full instructions for setting up RAID on the
Jmicron JMB363. The manual says to set the Jmicron to RAID
Mode in the BIOS. Two disks must be connected, in order to
Be able to press <control-J> at the start of the BIOS, to
Enter the Jmicron RAID setup in the BIOS. At that point, you
Can declare an array in the BIOS setup.
Then, when Windows is installing from the Microsoft install CD,
You’ll need to press F6 and offer the Jmicron RAID driver.
Section 5.5 of the Asus manual, describes how to make
A RAID driver floppy. The application in the mother board cd is available for make drivers disk
Dec 07, 2007 | Intel D101GGC Motherboard
Intel Motherboard Logo
1,088 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
