Question about Dryers
Need to replace belt in Asko dryer model t=701
I Need to replace belt in Asko dryer model t=701. I need instruction as to how to do it.
Also, how do I rewire dryer to match the existing wall outlet.
  • 12rtg Jun 24, 2008
    please email
    erbl@juno.com with answer.
    Asko dryer.
5 Suggested Answers
SOURCE: how to change dryer belt on Asko 7305 dryer
You have to pull the back off the dryer.Then you,ll be able to see how it comes off.Ussally its on two pulleys similar to a car.There may be a tensioner on it to to keep it from slipping.If there is one you,ll have to losen it to remove the belt & replace it,then tighten the tensioner back up.Ussally you keep about a 1/4" to 1/2" free play on the belt.You use a sraight edge on the two pulleys to measure it with the belt on,tighten belt tensioner till you have the recommended tighteness.
Posted on Feb 19, 2008
protek480
  • 1714 Answers
SOURCE: My belt is broken and I can't find a replacement
In your town, a appliance repair shop would have it, on line ...www.repairclinic.com
Posted on Aug 08, 2009
taran_2005
  • 10515 Answers
SOURCE: how do I replace the belt on my Asko T761 dryer?
How to install a belt on ASKO dryer
Belt Type: Flat belt with ribs
Installation Notes: Ribs go against drum
You could Refer to :-
http://fixitnow.com/wp/2006/05/08/asko-t700-dryer-wheel-drum-and-belt-replacement-instructions/
It would be a Generic one but would help you.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Mar 11, 2010
heatman101
  • 43501 Answers
SOURCE: Replace a belt on a ASKO T711 dryer
Here is a tip that will help you with the belt routing..
http://www.fixya.com/support/r4245827-dryer_belt_replacement_replace_dryer
heatman101
Posted on Apr 15, 2010
Macmarkus
  • 2605 Answers
SOURCE: Asko W/D. Power to 220 wall outlet and washer
Hello paulehni, welcome to Fixya.
First things first, have you checked the 15amp fuses which are located at the back of your Asko dryer ?
**Turn off your breaker at the home service panel, it should be a 30amp switch**
That is where I`d start and focus your attention. They are at the back as I said located next to where the power cord exit`s the unit. Look for 2 small round slotted caps ( these are the fuse holders/hubs ) either black or gray in color.
With a flat screwdriver fitted in the slot of the fuse hub, turn it a half turn counter clockwise an it should drop out...though it may need to be pulled out if it`s stuck in the holder part.
Replace with a 15amp "slow blow" ( the only difference is the slow blow are filled with sand and aren`t transparent glass tubes but rather gray or white in color ) if the fuse is blown. You can find these fuses at most brick & mortar appliance part stores or on-line parts vendors such as repairclinic.com, amresupply.com, reliableparts.ca etc. Part number is #8058140 and you should replace both. The number may substitue to an in-store number, it really depends on the vendor, just provide your model number and you should have no trouble.
Hope that is helpful. If so please rate the solution accordingly, if not let me know what you find or if you require further assitance.
Thank`s for visiting Fixya today and good luck.
macmarkus :)
Posted on May 16, 2010
I have a Asko 7305 dryer,can I have a regular 240volt dryer cord put on it, so I can use existing wall receptacle ?
I think you are asking if you can change the cord from 220 amp to 110 amp so you can use a 110 wall receptacle...NO you cannot not.It would also probably start a fire
May 13, 2015 | Asko Dryers
Tip
Dryer Belt Replacement Replace Dryer Belt Admiral Amana Asko Crosley ...
If you need to replace your dryer belt and need a diagram to see how it goes, check out these diagrams.
For Admiral all models will look like this
154ceff.gif Style: Flat with ribs
Installation Tips: Ribs against drum
For Amana all models will look like this
Installation Tips: Ribs face toward drum
For Asko all models will look like this
For Crosley all models will look like this
Fridgidaire
1970 – 1985
1985 – 1995
1995 – present
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
on Mar 02, 2010 | Dryers
How do I replace the belt on my Asko T761 dryer? Do I go in thru the front, the back? Are there instructions on-line for belt replacement?
Hope i helped you.
Mar 11, 2010 | Asko T761 Electric Dryer
Need to replace the belt on the asko t701 what is the difficulty level doyou have a diagram
NO DIFFICULTY- PUT THE BELT ON THE SMALL PULLY FIRST IN THE GROOVES AND ROLL THE LARGE PULLY AROUND A COUPLE OF TIMES TO POSITION THE BELT
Oct 04, 2009 | Asko T701 Electric Dryer
Asko Dryer model T-701
you need to replace the motor you can replace the rear half of the motor but you can only buy a complete motor.this isnt a common problem but i have had it before.it broke because you need to grease the pin every 5 years or so.
Oct 24, 2008 | Asko T711 Electric Dryer
Dryer not getting hot
what is the model number for asko t 701
Aug 17, 2008 | Asko T701 Electric Dryer
Asko Dryer won't spin...need to tighten belt
Does the Motor turn... We have had many motors with bad capacitors .. check the white capacitors for cracks or metal coming out of it...the motors will run with out a load on the but put a few clothes in the drum and they will just hummm..
Jul 19, 2008 | Asko T721 Electric Dryer
Noise
remove the drum and check the front rollers,and the jockey pulley/belt for wear.also grease the jockey pin,you need to know how to remove the back panels on these asko dryers so you may want to ring asko to do it.remove all outer screws, centre nut and three screws left side about 3 inches up from base.hope this helps.
Mar 16, 2008 | Asko T701 Electric Dryer
Dryers Logo
101 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
