Cars & Trucks Logo
Posted on Nov 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Would I be able to tow my 1,300 lb. tent trailer easily with my 1988 bronco II, 2.9 liter v6 automatic transmission?
Anonymous
Level 2:
Sergeant:
  • Expert 277 Answers
  • Posted on Nov 29, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
277
Questions
0
Helped
95782
Points
766
Yes.
Regards, David
Anonymous
Level 1:
  • Contributor 41 Answers
  • Posted on Feb 18, 2011
Anonymous
Contributor
Level 1:
Answers
41
Questions
0
Helped
10571
Points
53
Towing with a bronco 2 .. All bronco 2's may tow a class 1 trailer up to 800 pounds provided the gross combined weight rating is less than os equal to the gvwr shown on your vehicles scc label attached to the door..
Anonymous
Level 3:
Genius:
  • Master 1,340 Answers
Anonymous
Master
Level 3:
Genius:
Answers
1340
Questions
Helped
332906
Points
3726
2.9 liter isn't very large.You may have some troubles with hills.Your best bet would be to call a Ford dealer.They would know the limits much better.
Rick Hurd
Level 3:
  • Master 285 Answers
Rick Hurd
Master
Level 3:
Answers
285
Questions
0
Helped
126155
Points
1051
I would think yes, no problem. If you drive in hilly areas, keep an eye on your temperature gauge and be aware of the dangers of brake fading if you have to use the brakes alot. (downshift on long downhills rather than using excessive brakes.)
1helpful
Towing capacity of a a988-90 ford bronco II with auto transmission
Don't. Just don't. It's a French designed transmission and doesn't handle extra torque well. The 2.9L and 3.0L motors do have decent power but they are under supported by the automatics. If you are determined to try anyways, try and keep it below 1,200lbs and stray away from steep hills.
88 bronco 2 automatic v6 will sometimes not go in any gear but if I'm lucky it will kick in and go can anyone tell me the problem
the problem was changing that fluid! rarely happen, but it will happen when people change transmission fluid on older car then the car messed up. when you change the fluid you washed all the friction material on the clutch surface by putting in new fluid.
1988 Ford Bronco II How to change Distributor Pickup Coil
how do you remove the gear on the end of distributor shaft so the pickup coil can be replaced
11helpful
Firing order diagram for 88Ford Bronco II V6 2.9
For the 1988 Ford Bronco II 2.9L V6:
Firing Order:
1-4-2-5-3-6
Cylinders:
......(back)......
|..3..|......|..6..|
|..2..|......|..5..|
|..1..|......|..4..|
......(front)
Distributor:
....1.....4..(+)-screw
6......o.....2
(+)3.....5
Let me know if this helped or if you have additional information or questions. Feel Free to contact me at FixYa.com!
1helpful
I have an 1988 ford bronco 2 automatic V6 i pulled
There are shift solenoids in the transmission and apparently there's a problem them. I would get it to a trany shop and have it checked right away. If you continue to drive it you will ruin the transmission. Are sure you put the right computer in the vehicle? If you put a computer from a Bronco II with a manual trans in a vehicle with an automatic trans, the trans won't work right.
Is it possible to tow a small 8' tent trailer with the Nissan Rogue? I've heard conflicting stories about this. The trailer would weigh anywhere from 1200-1300lbs dry so we would also have to factor in...
Is it a Automatic or standard ??
No problem for a standard transmission, however an automatic you may like to add a transmission fluid cooler !
1989 bronco II, 2.9 V6 automatic transmission
My ATSG manual says to tighten the adjusting screw in to 10ft-lbs, then back it out exactly 2 turns. Holding the screw, tighten the lock nut to 35-45ft-lbs. The intermediate band is set the same way.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
