Question about Panasonic CT-34WX54 34" TV
TV won't turn on
I'm pretty sure that my house was hit by lightning, or at least a near miss. My TV will not turn on. Is there a fuse in this TV that may need to be replaced?
  • dparlato2 Jun 25, 2008
    Both the VCR and the TV were the only things hooked up to my antenna on top of the house. These were the only 2 electronics that stopped working. I didn't even blow a fuse in the house.
    I was hoping that this model of TV has some type of internal surge protection that I could check before I called the repair man.
  • sjk1991 Aug 06, 2008
    I have a similar problem. Paused a DVD, came back and the red power light was flashing with the TV off. Only way to stop the flash was to unplug the TV. Plugged it back in and pressed the power button. Started to boot up then shut down before any image displayed on the screen. Red power light continued to flash. Can't find anything about this in the owner's manual. Any advice? The cable was also out but now that is back on.
  • Panasonic Master
  • 5,568 Answers
It may be too late for this advice, but if you live in a lightning prone area, you should consider having a 'whole house surge protector' installed.
The cost should be well under $300 (a lot less if you install it) and with the included insurance (most often for $25,000) it is a good investment.
If your house was struck, I'm surprised you don't have a list of things that no longer work.
It could just be an expired TV.
Posted on Jun 24, 2008
  • Steve Allison
    Steve Allison Jun 25, 2008
    Those two items along with PCs are among the most sensitive.
    If either of the failed items had any protection, it would be a cheap part intended to protect only against very short, low energy spikes on the power line and even those get tired after a few hits.
    If they were internally fused, the fuse may have died too late to protect much of anything or even as a result of other component failures.
    Fuses in general, in AC operated gear, protect mostly against setting fire to your home.
    They don't do much for the equipment in which they are installed.
Had lightning hit near by and tv will not do anything. could it be the cord or is there a reset button?
it may have blown the shock diode on the power board check that and change it. it stops the tv from blowing up in a lightning strike. if it has worked it wil have just blown that and the fuse inside the tv and nothing els.
Sep 21, 2013 | Philips 42PFL3603D/27 42 in. LCD TV
Can't find a fuse replacement...
We can't predict which components have been damaged due to lightning. Sometimes, a fuse only, otherwise more other components might have damaged. Anyway, if fuse should blow out, surely there will be any more reason. You should find it out first, before replacing the fuse. If not, more damage can be occur. Check for any shorted components, diodes, capacitors etc: at its main power supply regulator board. Be sure that there is no other defect occurred.
May 02, 2013 | Sanyo DP37647 37 in. LCD TV
Daughter's TV was on during bad electrical storm. Screen went black and made high pitched sound. cable, internet and telephones all digital through Time Warner Cable. Now TV will not even turn on;...
Ur Main Fuses in the circuits breaker box must be to be restart it back.Turn off/on all the fuses on the main circuits breaker box to all the fuses in the box of the box to restart.All ur electical power outlets should work again.If not those power plug in outlets are shorted and dead must have to be replaced.
Aug 22, 2011 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Lightning hit near house tv will not power on can it be repaired
Many things can happen when a power surge comes into your home. In the best cases, the fuse in the TV may be the only thing to replace. And in other cases the surge can travel inside of the TV to literally explode transistors, varistors , and bulge capacitors. In some cases the internal TV will look fine (still not power up). This is why you take your TV to a service center for a diagnostic check. Thanks for asking and show all hands of support!
Aug 13, 2011 | JVC HD-52G886 52" Rear Projection HDTV
Panasonic micro wave stopped working after a lightning bolt hit near the house
If you remove the cover assy you will see a fuse somewhere. It is pbobably blown. Be careful with microwaves as they can give off quite a shock even when unpluged. If you keep your hands away from the magnatron you shouldn't have a problem. If you just change the fuse you won't have a problem. The hi voltage cage is toward the back
Aug 03, 2011 | Ovens
Hello, I have a Toshiba 40rv525rz (2008). We just had a bad storm, the power went out and lightning likely hit the transformer across the street. Now the power is back on and the TV won't turn on and...
hi,
As it is a fault caused by the lightning it is better to consult some one experienced rather than doin it by Yourself. Its powers supply have problem. If you are able to do the same then remove the back cover. then check the input fuse in the power supply. If you find the fuse faulty then check the MOV (Componet used for High voltage sure protection, MOV have a voltage range, if voltage above its rating occurs it will get shorted and blows the fuse preventing from further damage to the power supply.). It will be near to fuse. It will be placed in Paralel to the Phase and Neutral track after fuse. You can check the same is it faulty very easly. Insert the new fuse in position, using multimeter (in ohms range) check the ohms between the two pins in the power cord. if its shows a low ohms ( bellow 1K) then the MOV is faulty. After replacing the MOV you have to check the ohms Again. if then also it shows low ohms. then you have to replace the bridge rectifier. first of all check the fuse and MOV. picture of MOV is added below.
Jul 19, 2011 | Toshiba 40RV525R 40 in. HDTV
We had a lightning strike which hit the house phone wire and knocked it out. the tv and dvd player didn't get hit. we turn the dvd player on it plays but no picture. the input button on remote won't switch...
Check the TV internal fuse. If fuse is OK check the SMPS. Lightning damage could harm any part and step by step only it can be found.
If you have insurance for your TV and other appliances, you can claim.
Better contact the authorised service provider for assitance.
Aug 27, 2010 | Zenith DVB712
Lightning strike
Hello bkindle.....not a boat anchor YET!!!! Had similar problem with WS-55513 and it turned out to be a faulty DM board. There are 4 capacitors on the board that may have blown. If yo can solder, it is a pretty easy repair. I purchased a PDF manual for mine online to get familiar with the model.
Otherwise, you can expect to pay between 275.00 for a repaired board OR between 350.00 and 450.00 for a replacement board from Sears or Mitsubishi.
Hope this helps. I know it is frustrating but be patient.
Good Luck - Richard (MetalDad)
email: PentiumDreams@aol.com
Jun 12, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Panasonic CT-34WX54 34" TV Logo
273 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
