Question about Motorola Mobility RAZR V3
No service after water damage
I set my razor in some water on the counter...oops! It actually appears to be working pretty normally after it dried out but now it says no service and reset the date and time. Is there anyway to fix it? It isn't a verizon problem but the phone. Help me please!
    Brigadier General:
  • 7,752 Answers
You should take the phone to a mobile service center and have it fully service
Posted on Jun 25, 2008
Water spilled keyboard
Hate to say it, but its pretty much trashed. Did you already try to turn it on? If you did,,its more than likely burnt up...If not try and dry it out in an oven, set temp as low as possiable and see if you can dry it out.
Feb 18, 2014 | Nokia Lands Phones
HOW TO REMOVE CRAZY GLUE FORM ARBORITE
I would try either:
a) a razor blade and hot soapy water
b) acetone (nail polish remover)
c) if there is alot of it and neither of the previous 2 solutions worked, you can buy superglue solvent
Dec 14, 2012 | Elmer's Instant Krazy Glue
HOW DO YOU CLEAN THE RAZOR
Good day!!!
if you wish or need to clean you razor you only have to do is to open the cover (unscrew) then use a paint brush to clean the your razor after that put some oil to lubricate the razor and that's it..
thanks for using fixya..
have a nice day!!!
Jun 30, 2011 | Philips Philishave Cool Skin HQ5620
"The ink absorber is almost full. Press printer's Start button to continue printing. Contact the service center." What does this mean?
This means that the counter related to the amount of ink these pads absorb during print head cleaning cycles and from edge to edge printing is nearly at the programmed limit. You can still print by pressing the Start button.
However, you can expect the printer to stop working soon. You can clean out the waste ink pads yourself. This is a bit messy so have plenty of newspaper around. Disassemble the printer from the top. The pads (rubber of some type) are below the cartridge carrier on the side. Pull them out and blot most of the ink off them. Then run under water until the water comes out clear. Allow to dry (you can speed up the drying process with a hair dryer).
Finally reset the waste ink counter in the service mode:
With the printer off but connected to power, Press and hold Set/Reset and then press the Power button. When the power light is lit, continue to hold the Power button and press Set/Reset twice. The light should be green.
Now press Set/Reset 4 times (the light will switch between orange and green at each press). Turn off the printer. The counter should be reset.
Do not reset the counter without cleaning or replacing the pads. You will get ink spreading all over the printer. Additionally, the waste ink counter is set to a value that should be reached near the printer's end of life with normal usage. Other parts may fail soon.
I hope this helps.
Oct 03, 2010 | Canon PIXMA MP160 All-In-One InkJet...
How to repair a wet ipod touch
there is no actual repair best thing you can do is to let it dry with the battery removed and a fan blowing on it for a few days. but since its an ipod you cant remove the battery which pretty much means something will be blown unless by fate it wasnt effected. if it doesnt work after that time then you have to determine exactly what is not working. But it would just be best to go to a store and see if it can be repaired under warranty however they do not cover water damage in the warranty.
Aug 17, 2010 | Apple iPod touch
Ink light and paper feed light are flashing alternatively, printer not responding at all !
I just had this same problem, and came here to figure out what to do about it. Turns out I had the CD/DVD tray in the out position, so all I had to do was flip the switch to stow it and the flashing lights stopped. Maybe it will work for you as well.
Aug 22, 2009 | Epson Stylus Photo R260 InkJet Printer
Epson R200 printer error, Parts inside your printer are at the end of their service life. See your printer documentation.
A Service Error where you get a message telling you that "Parts inside your printer at the end of their service life, contact your dealer for replacement", or "Parts inside your printer require maintenance or replacement, call your service company", is normally a Maintenance Request Error. The maintenance request error is actually a Waste Ink Ink Pad Error and usually your remedy is to replace the Waste Ink Pad/Pads with a new one/ones and then reset the Internal Waste Ink Pad Counter. If you just reset the counter and don't replace the pads, then your printers old pads will eventually overflow and normally start leaking ink out the bottom of your printer.Some people actually wash the ink out of the old pads, by holding them under running cold water. Then they simply dry them out and reinstall them back into their printer. The choice on what to actually do, is yours to make. I would at least recommend getting that Waste Ink Counter reset procedure and performing it first, to make sure your printer will then work.
Try this reset app
http://inkjetprinterhelp.us/sscserve.exe
Aug 15, 2009 | Computers & Internet
S900 Ink Pad location
that item your talking about is actually the purge unit. The ink pad is actually below that and usually requires a repair tech to service and replace the pad. Contact Canon for a repaiir center near you.
Jun 18, 2009 | Canon S900 InkJet Printer
Parts inside your printer require maintenance or replacement. Contact your dealer...... epson stylus c40ux both lights are flashing ... won't print
A service error where you get a message telling you that "Parts inside your printer at the end of their service life, contact your dealer for replacement", or "Parts inside your printer require maintenance or replacement, call your service company", is normally a Maintenance Request Error. The maintenance request error is actually a Waste Ink Ink Pad Error and usually your remedy is to replace the waste ink pad/pads with a new one/ones and then reset the Internal Waste Ink Pad Counter. If you just reset the counter and don't replace the pads, then your printers old pads will eventually overflow and normally start leaking ink out the bottom of your printer. You can see exploded parts diagrams for most epson ink jet printers and can also check on possible parts ordering, by Compass Micro Inc, at http://www.compassmicro.com/parts_select.cfm . Some people actually wash the ink out of the old pads, by holding them under running cold water. Then they simply dry them out and reinstall them back into their printer. The choice on what to actually do, is yours to make. I would at least recommend getting that waste ink counter reset procedure and performing it first, to make sure your printer will then work. There is an "Epson Stylus C60 Printer Information Page", that also includes the C40 & C42 series, that you can view at http://epsonhelp.freehttp.com/C60.html . It does have a section on the left side you can click-on, titled WASTE INK PAD SERVICING and also a section titled HOUSING REMOVAL, that will be of some help to you, if you want to try the needed servicing. However, you will still need to actually reset that Internal Waste Ink Counter, to clear the actual service error condition. You may be able to reset that waste ink counter, using the SSC SERVICE UTILITY available at http://inkjetprinterhelp.us/sscserve.exe . Unfortunatly, that utility only works using a windows operating system. You can check and see if your particular epson printer is compatible, by going to http://inkjetprinterhelp.us/epsonSSC.html ...Here's some previously posted info that may also help. To reset the error download this utility: http://inkjetprinterhelp.us/epsonSSC.html . Once installed run the program and configure it, closing the main window and right clicking the icon in the tray area, from there choose Configure and select your printers model. After configuration, select Protection counter -> Reset protection counter, it should be able to clear the error message. If that does not actually work, then the only suggestion I can give is to perform a soft-reset before resetting counter. Remove also the Epson status agent, it detects errors and it may hinder communication with the printer, then reboot your pc. As profile choose the one sscservice didn't use after autoconfiguration, check for printer response. Remember that you should also clean the waste ink pads located at the printer bottom. For a more in-depth procedure go to his site at http://myprinter.altervista.org/simplefaq/mysimplefaq.html#counter "....Unfortunately, that ssc service utility may not actually work on all epson printers and not on all operating systems, so you will have to check it out for yourself. Just in case that source does not work: You may then need to go on-line to try and locate the actual reset procedure, to buy and download to actually reset that waste ink counter
Mar 12, 2009 | Epson Stylus C40UX InkJet Printer
Razr v3 water damage lcd
take the phone to a professional mobile service center and have them fully service the phone and replace any damage parts to have the phone up and running correctly
May 15, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
85 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
