Question about Black & Decker String Trimmer Cordless 12" 18V
Change string on grasshog trimmer - Black & Decker String Trimmer Cordless 12" 18V
  • 1 more comment
  • Anonymous Jun 26, 2008
    I want directions for rewinding the spool on a \\\\\\\\\\\\\\\\\\\grass Hog corded Trimmer
  • greewing Jul 21, 2008
    I recently took the head off the grass hog to advance the line but could not put it all back together correctly. Comnpounding that difficulty, I can't find the instructions or diagrams, etc. It has 2 separate lines going in two directions seemingly. How do I get it to work so it get's into the correct slots and then advances as needed? Many thanks, Rosie
  • zorro69 Aug 30, 2008
    Self fed will not stop. Pulls all the string out. How do I stop this.
    Thanks
    MTH
    Champion:
  • 313 Answers
There should be arrow direction in the spool itself
Posted on Jun 27, 2008
How do you rewind the string on the black and deckder grasshog
It's annoying I know, but there should be a little notch in the spool, wind the string evenly round one groove. notch it, then do the same on the other groove but in the opposite direction. Hope this helps.
Jun 28, 2015 | Black and Decker USA BLACK&DECKER GH710...
Grasshog
When I had this problem I replaced that ratchet toggle part that the string drum sits over. Do you use replacement refills or do you refill them yourself. If you wind the string in the wrong direction it all affect the auto feed.
Jul 15, 2014 | Black and Decker USA BLACK & DECKER...
How to re string the weed eater line
Most string trimmers are very similar and once you learn how to do it, you'll be able to do pretty much any of them. Here's a link to a video showing you how to string a Husqvarna double string trimmer which I hope will get you started:
http://www.jackssmallengines.com/restring_a_string_trimmer.cfm
Jun 30, 2011 | Black & Decker Grasshog 12 Inch 18 Volt...
Need Replacement Battery for CST2000
243215-00 is the part number for the Grasshog's battery pack, but that part is now obsolete. However, you can get the internal battery (part #243213-00 )itself from Amazon for $35.99:
http://www.amazon.com/Black-Decker-243213-00-Replacement-Grasshog/dp/B0027Z7G94
Jun 28, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
HOW DO I SET THE B&D GRASSHOG FOR EDGING? IT
The lower unit will rotate 180 degrees from the handle and then lock, with the metal guide pointing down.
Apr 19, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
String will not advance on black and decker grass hog electric trimmer
Did you re-string it? If you did it is possible that you crossed the string over itself and it is stuck. Check that and good luck...Lee
Oct 20, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Describe your Black & Decker Grasshog
The push lock on the string feeder Is sticking. Pull it off, clean it out and put it back on.
good luck
Aug 07, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Only 1 string trimmer /// string keeps feeding when running
You have the string wound the wrong way on the spool.
Jim
Jun 17, 2009 | Black & Decker 14" Grass Hog Xp...
Black & Decker String Trimmer Cordless 12" 18V Logo
1,162 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
