Question about JVC Televison & Video
Connection to Dish service
I have a JVC TV with an aerial port instead of the tradtional coax male connector (model # AV-29VS24). I have the adaptor for the coax cable, but I can get no satellite (Dish) signal/programming when I connect it to the TV.
What I've tried: Signal is perfectly received when using another TV with traditional coax male connector. JVC TV works perfectly when connected to a traditional VCR via RCA jack, but cannot get satellite reception. Changing the input makes no difference. Changing VCR/TV makes no difference. Help.
  • 24 Answers
Your t.v is having only RFin , and if you connecting dish receiver , normaly their are two o/p for receiver one is RF and two is for audio out and video out. if your connecting direct RFout to t.v RF in then you have to tune the t.v in all bands. if your receiver do not having RFout facility, then you have to connect AV out to converter and then RFin of t.v. if you having a vcr, then connect AVout of dish receiver to vcr AVin and then vcr RFout to t.v again tune the t.v and pwer on the vcr.
Posted on Jun 25, 2008
I have a sony EX4|40 with built in Freeview. However, the port on the tv is a UHF (?) port (Im not technically minded, my port names may be wrong so I hope you know what I mean), The cable which runs from...
xtreamz_69,
It sounds like you connected the coax cable to your TV. What channel is the TV set on when you have the Freeview connected? Because you are using a coax cable, the TV should be set to either channel 3 or 4 (normally channel 3). Check to make sure your TV is on one of those channels. Also verify your receiver is on. Your TV has the several other type ports (HDMI, component, composite) as alternatives to pick up your picture. If you have any other questions, please post to this site.
Ray Calo
DISH Network
Jan 19, 2011 | DISH Network IR Remote Control
I HAVE A MAGNAVOX TV MODEL 255102-OODD, A MOTOROLLA (VERIZON) SET TOP BOX MODEL QIP2400/1006 AND A JVC DVD MODEL DR-MV150BJ. I HAVE TRIED ALL THE HOOK-UPS SUGGESTED BY JVC AND STILL CONNOT GET A PICTURE. ...
ok, The issue will be in the sequence you have things connected. The connections sequence is going to be controlled by what connections are available. I assume the Set Top controller is connection to your Antennea connection on the TV. Your TV should be on channel 3 or 4. The next step depends on what type of connectors you are using for the JVC DVD. I have an Antennea output on mine so I connected them in series. If you don't have an Antennea output from teh DVD player you will need to connect the DVD using Audio/Video cables which means you will need to connect to the TV alternate Source connector and to watch DVD's you will need to change to that source. Much like you would switch between regular TV and VCR tape on a VCR player connected to the Antennea connector.
Sep 23, 2009 | Televison & Video
How do i replace the vhf/uhf connector so i can hook up the cable?
You can get a cable box that has coaxil and RCA or HDMI cables. You can run cable to box and RCA's to tv. Or use a vcr or converter box instead.
Or you can dismantle the tv, take a soldering iron and heat up the old solder joints. Then insert new connection and re-solder it in..
Sep 21, 2009 | JVC AV-32F485 32" TV
Speaker wire to coaxial cable
Yes ! all you have to do is go to radio shack and tell them you want a coaxil to RCA adapter (screw coaxial into wallplate and plug RCA end into sub and your all set!)
Please rate answers and help keep this site FREE!
Thank You
Dec 28, 2008 | JVC SP-PW100 Subwoofer
How do I hook up my Dish Satelite to it?
should go from your satellite to dish box might say sat on bck of box then the next [connection think says tv that should go to tv itsself or dvd vcr whatever ur hooking up to it then from that point hook it to ur tv
Oct 23, 2008 | JVC AV-56WP74 56" Rear Projection...
I have a phillips 26pf5520d/10 model number, ive connected a dvi cable and hdmi cable to my playstation 3 and tv, but i have no sound, please any ideas. many thanks steph
I'm assuming you mean you have HDMI coming out of the PS3 and going in to the DVI port on the back of the TV, via an adaptor or cable with a different connector on either end.
I have the same TV, you need a separate audio connection between ps3 and tv. HDMI can transmit audio and video but DVI (which is what the TV has) can only do video.
You'll need a 2 x phono female to 3.5mm jack male adaptor cable. like this one to make the audio connection.
you could also try this adaptor but its a bit big and therefore may not fit into the space available.
after getting an adaptor do this (keep your original setup the same)
1. Put the ps3 AV cable into the back of the ps3. 2. then connect the red and white plugs (ignore the yellow) from the ps3 AV into the adaptor (discussed above). 3. then connect the 3.5mm jack (from the adaptor) into the small audio port right next to the DVI port on the back of the TV (I believe its called 'DVI Audio')
I've not tried this and I don't have a ps3, yet, but in theory it should work, as long as the ps3 will send audio to the av output at the same time as to the hdmi output.
if it works, then post a response, i'd like to know for the future.
good luck
Aug 01, 2008 | Televison & Video
Short on satellite lead
You should check the coax cable between the receiver and the LNB on the dish. Assuming that you can get to the dish, disconnect from the LNB - the connection will probably be covered with tape. Disconnect the cable from the receiver end. Examine both connectors and make sure that there are no stray bit of copper causing the short. With a meter, test the resistance between the centre pin and the outer screwed sleeve. The resistance should be very high. > 100Kohm. If it is a short or only a few ohms, you will probably need to replace the cable. If it varies the cable may be water logged. Damaged cable is not worth repairing even if you can find the problem area. Where I live, a bit further south than you - squirrels like to eat the insulation - and finding the damage is a waste of time. You can probably use the original couplings but don't forget to cover them with self amalgamating tape after you have checked your repair.
Hope this helps. If you are unsure or not happy about ladders then leave it to an aerial rigger.
Apr 30, 2008 | JVC AV-27230 27" TV
Coaxle cable (from aerial on roof to TV)
Go purchase a coax male f connector, and the crimpers. Cut off 1/2 inch of rubber sleeving and fold the metal shielding back. Now cut the with part a quarter from the end but not all the way. You want the center piece to poke out. Now slide the f connector on and crimp.
Mar 05, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
103 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
