Question about RCA D52W19 52" Rear Projection Television
Turning on tv
My RCA 61 in. tv.
tv won't turn on when I push the button,it'll just blink off and on, after a few trys it will come on.
  • RCA Master
  • 8,617 Answers
Try resoldering the flyback, they are famous for bad solder connections as well as bad flybacks.
Posted on Jun 24, 2008
Red Light Won't Stay On
1. Remove batteries from remote to "zero" it, then reinsert batteries
2. Turn on TV (RCA?)
3. Press and hold CODE SEARCH button until indicator lights
4. Press and release TV button. Indicator will blink and remain on
5. Enter code from list in instructions
6. Point remote at TV and press on-off button. TV should turn off
7. Use remote to turn TV on again and press CH+. If TV responds you're all set; if not, repeat the process with the next code
Nov 19, 2012 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
Power switch doesnt work. It blinks for a few seconds then turns power button goes off all together. Tv wont turn on at all.
Hi jenna;
We need a little more info like Brand, Model # and how many times the light blinks.
Good luck
Buck
Nov 14, 2009 | RCA D61W20 61" Rear Projection Television
The power button on my tv pushed in
The board is fine, unless u cracked it. You need to change the buttons only. Shouldn't be hard to find. Look for RCA microswitches.
Apr 08, 2009 | RCA P61927 61" Rear Projection Television
Tv wont power up
if you can not turn on TV set with the power button on the TV its not astandby problem as this would by pass the standby. Theres most protec,on a set of this age, top have a poiwer regulator,vertical,horzontal/chcroma problem and is goingto need a trained tech to assist you in this repair. www.afiata.com
Aug 01, 2008 | RCA D61W20 61" Rear Projection Television
50 inch 1999 TheatreView Television
#1 When I turn on the TV the power button comes on then blinks 6 times then goes off for a few seconds then repeats the cycle. I have sound over my surround system during this time but no picture.
#2 My sound would crackle and pop every once and a while until now it does nothing. I have to watch it with the surround sound on.
Nov 26, 2007 | RCA HD52W59 HDTV Projection Television
RCA projection televeion problem.
take your tv to a tech for repairs the tv power supply or related circuit is defected.good luck
May 14, 2007 | RCA D61W20 61" Rear Projection Television
TV has a mind of its own
The front panel buttons are your trouble,you can disconnect these,first unplug the unit and remove the back cover,just below the top screws you can look under and see the top of the pictures tubes,in front of the middle tube is a small board,unplug the top right cable,this will disconnect the front buttons and you can use your remote to control the set,hope this helps
Mar 17, 2007 | RCA P61960 61" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
43 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
