Question about Nikon Cameras
I'm getting an FEE symbol on the window when I turn the camera on and ready to take a picure.Nothing happens. No click. This an N65 Nikon not a digital
  • 1 more comment
  • colettekm Jun 24, 2008
    the battery is half full. Ican change it. I have taken 23 pictures. I have the dial set at auto
    The solution given did not work Please send the ploblem to another expert.
  • colettekm Jun 27, 2008
    Thank you very much. I took out the film/ changed the batteries.The error sign did not go away. I then went to Best Buy store that carry Nikon camera and asked for help. A young seller in the store readjusted the lense and took care of my problem. Thank for your help
  • 3,037 Answers
You need to push the aperture lens all of the way down and this should fix your problem. If it won't go down by pushing then you can remove your lens, turn the aperture ring all the way down to the smallest stop, which is the largest number on that ring. The ring should be next to the camera, right where the lens meets the camera.
Reattach the lens, and that should fix it.
Let me know if you need any more help
Posted on Jun 24, 2008
    Genius:
  • 1,226 Answers
Most likely camera got error through it mechanical disallignment or low battery. or maybe the film inside misplace. try to align the film and then change battery with the specified one.
melnavz
  • 2,071 Answers
Try this take out the battery for about 10 minutes put it back and press the power on 15 seconds,.this problem of yours is to need to reset your camera,go to menu and find factory default setting..
  • LORETO LACARON
    LORETO LACARON Jun 25, 2008
    If you take the battery its okey there nothing happens to your 23 pictures it remained in the memory card and if you doubt it transfer it to your pc for safety. Then do the procedure ive said above by taking the battery.Start the camera without a memory card inside and go to view picture ,see if the FEE still there..
    Genius:
  • 1,847 Answers
Set the lens aperture ring to the minimum aperture (usually f22) and lock it there. The "fEE" error message should disappear and the shutter should "unlock".
    Guru:
  • 859 Answers
You will need to go into more detail.
Do you have film loaded and how many shots have you taken.
Is this equipped with a motor drive? Are the batteries fresh?
Please be specific and detailed.
Thanks,
Worldvet
Nikon N65 won't take a picture
If you have the lens set to the lowest number, you should be seeing a FEE error on the display. The lens needs to be set to the highest number, typically 16 or 22.
Feb 13, 2013 | Nikon N65 35mm SLR Camera
How can i turn the flash off of my nikon n65 camera?
In the PSAM modes the flash won't pop up on its own. In the AUTO and vari-program modes, you can set the flash mode by turning the command dial while pressing the flash sync mode button (marked with a lightning bolt symbol). Select Flash Cancel (lightning bolt in a circle with a slash through it).
If you need a manual, you can download one at
http://butkus.org/chinon/nikon/nikon_n65/nikon_n65.htm
Dec 22, 2010 | Nikon N65 35mm SLR Camera
What does fee mean ?
It means that you have fitted a lens which has a manual aperture control and have not turned the aperture ring to the smallest setting (highest number). The F65/N65 controls the aperture from the camera body instead, via the command wheel.
If this is not the answer, then the tiny switch at about the 7 o'clock position (as you look at the front of the body lens mount) which senses that the aperture has been set to minimum has either failed or has sheared off completely. If so, your camera is totally uneconomic to repair as it's easy enough to get perfectly good N65/N75 and similar models for nothing via your local Freecycle and Freegle groups.
Sep 20, 2010 | Nikon N65 35mm SLR Camera
Nikon N65 won't take picture
The problem is, that you have a lens witch has an aparture ring on it and some exposure modes needs it to be fixed on the smallest aparture (e. f22). When its done the camera should not say fEE no longer.
May 15, 2009 | Nikon N65 35mm SLR Camera
Flash
You might not have your lens set to the minimum aperture setting (the largest number) if it is a non-G lens.
Nov 29, 2008 | Nikon N65 35mm SLR Camera
Nikon n65 will not take pictures
nachbor,
Not knowing if you are shooting in auto or have recently switched from manual to auto shooting you may have adjusted your f-stop on the lens, make sure you adjust the ring to align with the auto setting (the f-22 in red letters) with the dot on the lens) then the camera will be allowed to open for enough light to take the shot.
randy320sgi
Jul 17, 2008 | Nikon N65 35mm SLR Camera
I have a Nikon N65 camera not digital.
If you take the battery its okey there nothing happens to your 23 pictures it remained in the memory card and if you doubt it transfer it to your PC for safety .Then do the the procedure ive said above by taking the battery .Start the camera without a memory card inside and go to view picture ,see if the FEE still there ..
please rate the solution as FIXYA if this helps you solving your problem...
Jun 24, 2008 | Cameras
Nikon N65 Unable to take picture
Hey colettekm,
What this message should mean is that a non G-type Nikon lens is being used and its aperture is not set to smallest aperture which would be the largest number on the aperture ring on the lens. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 24, 2008 | Nikon N65 35mm SLR Camera
FEE reading on n65 camera
Make sure your lens has the aperture ring to the minimum f-stop number, i.e. (f-22, f-32, largest number) and the focus switch set to 'S' or 'C'
May 24, 2008 | Nikon N65 35mm SLR Camera
Nikon N65 broken status window pane
kumar1177,
It won't affect you pictures and it is more an aestheric thing so if you can live with it do so. If you want it repaced a reputable camera shop or Nikon can replace the cracked viewfinder, get an estimate first since that work will most likely have to be done by the shop or Nikon.
randy320sgi
Aug 18, 2007 | Nikon N65 35mm SLR Camera
Cameras Logo
70 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
