SOUND LIKE COOLANT LEVEL LOW.CHECK ANTIFREEZE LEVEL ADD MORE COOLANT TO RADIATOR IF LOW IF YOUR VECHICLE DONT HAVE RADIATOR CAP. POUR ANTIFREEZE IN THE OVER FLOW RESERVOIR DONT FILL PASS THE COLD MARK ON COOLANT RESERVOIR. MAKE SURE YOU DID USE THE RIGHT TEMPERATURE THERMOSTAT WHICH IS 195 DEGREES.
Sounds to be a faulty thermostat did your car over heat my vehicle does the same thing its the thermostat when its cold out your vehicle loses all its engine temperature and blows cold air make sure you use 50/50 antifreeze
