Question about LG LRSC26940ST 36" Side-by-Side Refrigerator w/ 26 Cu. Ft. Capacity, OptiChill Crisper & Jet Freezin...
Ie tube freeze
Hi
I have LG LRSC26940ST refregirator and the tube that fill the water for the ice tray keep on freezing after few days. I have to cleared the ice that freez in the tube. Do you know why? Tank you for your help.
My lg freezer dont get cold!
Posted on Mar 26, 2009
  • LG Master
  • 5,568 Answers
You may need to balance the distribution of cold air between the freezer and refrigerator section.
The temperature setting influences both and there is normally a control that lets you divide the cooling between the two compartments.
If you don't have one, get an inexpensive (<$5 US) refrigerator thermometer, normally a simple dial-type, and monitor your refrigerator temperature (maybe somewhere in the middle) overnight when not often opened, set the main control to get the temperature between 40-45 degrees F.
Then check the freezer temp.; it should be <10 degrees F (0 is better), then swap back to the fridge to correct the main setting.
Go back and forth until you have both compartments close to the mentioned ranges.
Posted on Jun 24, 2008
I have a Sears Kenmore model 106.5002 refrigerator. The ice machine keeps building up blocks of ice. We have melted it with a blow dryer. It works and dispenses ice.
Suggest turning the ice maker off by elevating the shutoff lever arm. If ice continues to build after a few days the solenoid water valve is leaking and needs to be replaced.
If no ice build up it is likely that the fill tube is dirty and water is freezing in the tube disrupting the normal tray fill process.
26375967-eslp3us1ub1u3afrhtff0zvp-3-5.jpg Hope this helps?
Nov 28, 2016 | Kenmore Refrigerators
How do I stop my ice maker water filler hose from freezing - which stops water from filling the tray?
This problem is caused by a defective water control valve that does not stop leaking water like a dripping faucet. This causes water to freeze in the water fill tube thus blocking fill of ice tray. Replace water control valve.
Appliance 911 Sea Breeze
Sep 19, 2015 | LG Refrigerators
Ice maker spout starts to freeze up (6years old Viking side by side), is there a solution?
low water pressure or faulty valve
low water pressure the valves do not seal proper and slow drips freeze up in tube
are you on well/?
last time fridge filter was changed?
if all good faulty water valve
Mar 28, 2017 | Viking 48 in Built In Professional...
Ice cube tray does not fill up water feeding tube is frozen.
The problem you are having is caused by water leaking past the=> MJX42111401 Water Inlet Valve Change the MJX42111401 Water Inlet Valve and this will solve the water freezing between ice harvest. On most refrigerators this part can be found on the back of refrigerator and near floor, Let me know if you have other questions, Thanks Sea Breeze
May 24, 2012 | LG LSC27910 (265 cu ft) Side by Side...
WATER FREEZING IN ICE MAKER
check 2 things. Make sure the fill tube is going downwards to the cup inside. The second thing is when the valve shuts off make sure it closes right away. If it doesnt then replace the valve.
Jun 18, 2009 | U-Line BI-95
Ice maker doe's not fill up with water to make ice
just bought a brand new side by side with ice and water dispenser i have water coming out of the door dispenser but the ice maker tray is not filling up with water can someone help me
Jan 01, 2009 | LG LRSC26940ST 36" Side-by-Side...
Ice tray doe's not fill up with water to make ice
by chance what is the temperature in the freezer and also can you see the fill hose for the ice machine. sometimes they freeze solid and need to the=aw before they release any water. also the freezer compartment has to be around 0 for the ice maker to work
Water line in freezer for ice maker keeps freezing
I have had this happen to me before. What happens is the water fill valve
does not completely close and the tube will freeze shut as a small ammount of water will continuosly dribble into the tube when the valve shuts off causing the tube to freeze solid. I tried to clean the valve but that did not work so I replaced it and that ended the problem. A new valve is not expensive.
Oct 08, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice maker problem
Clear the Ice tray by pressing the button under the ice maker. The problem is that the ice is in the first couple of slots is not dumping and the tray tries to fill again and over flows. I pressed the button and cleared the tray of ice (This will tilt the tray and twist it to empty it) that was re-frozen several times without dumping. My ice maker works perfectly after I did the above. I think the problem arises if the door did not close completely. I stopped hanging the dish cloth on the door and on my LG Dish wisher. I hope this helps
Oct 03, 2008 | LG LRSC26940ST 36" Side-by-Side...
Water freezes before getting to ice tray
sounds as if your water inlet valve is not closing fast enough allowing a small amoutn of water to accummulate in fill tube freezing and eventually freezing solid, would try replacing water inlet valve, or even the water filter if this model is so equipped
Feb 18, 2008 | Refrigerators
LG LRSC26940ST 36" Side-by-Side Refrigerator w/ 26 Cu. Ft. Capacity, OptiChill Crisper & Jet Freezin... Logo
182 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
