Question about Dryers
Whirlpool Cabrio Electric Dryer with Steam option
If I don't plug the water hose to a faucet (i.e. not use the steam option), can I still use the other drying features that don't require the water hose?
    Genius:
  • 1,028 Answers
Yes the steam dryer is basic dryer with spray nozzle in rear wall to inject a fine mist of water..to be honest don't believe the stem option is all that great ..just take clothes and sprinke at kitchen faucet probably would have same effect
Posted on Jun 25, 2008
Why is my Whirlpool cabrio platinum dryer leaking water, and taking over an hour to dry clothes?
Is this an older dryer? Long drying times are often caused by lack of good heating or poor air movement through the drum. Air movement depends on a properly turning fan and a clear exit of hot moist air to the outside vent. Check and see if you get a strong blast of air from your outside vent. If you don't, you may have a fan problem, plugged vent, or kinked vent tube. The water leaking could be because you don't have any drying going on due to the aforementioned problems.
Feb 05, 2016 | Whirlpool Cabrio Platinum High Efficiency...
My Whirlpool Cabrio dryer has water leaking in it. How do I fix this or what's causing it?
This model has steam support, so it should have a cold water connection to it. Check for leaks where the hose connects to the rear of the dryer. If you do not use the steam feature, you can shut off the water and that will probably end your problem.
Jul 06, 2015 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool cabrio dryer
Could be many things. Thermistor, water valve, steam generator, UI board. Need a model number to be further asisstance
Jan 27, 2014 | Dryers
Whirlpool duet dryer stuck on steam cycle
one trick to stop the steam is to remove the water hose connected to the dryer
Nov 20, 2013 | Whirlpool WED9500T Electric Dryer
How hot does a whirlpool cabrio dryer get
It can because it has a water line coming from washer line it causes steam for you dryer.
Dec 15, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My Whirlpool electric steam dryer accumulates an unusual amount of water in the exhaust vent (to the degree that it overflows the hose). Suggestions?
That can happen when the vent hose is clogged. Usually a birds nest or just an accumulation of lint out the outlet point.
Aug 25, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
NEW Electric Whirlpool Cabrio Steam Dryer; NO HEAT
Check temperature sensor.  Check to see if heating element is OK.
May 29, 2009 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
288 people viewed this question
Top Dryers Experts
