Question about Apple iPhone Smartphone
Wifi problems i have an iphone version 1.1.4..but i couldn't use the wifi..the menu is in grey mode where i couldn't tap on it at all..could u give me some suggestion to this problem?
  • 282 Answers
Have you checked on settings if its off? try to reset network settings or reset all
Posted on Jun 24, 2008
Sensor to connet to WIFI and Bluetooth is locked, which part of the Iphone 4s should be change ?
Begin troubleshooting with these steps first:
  1. Check that you are in range of the Bluetooth accessory with which you are trying to pair your iPhone, iPad, or iPod touch. Most Bluetooth accessories have a range of approximately 30 feet.
  2. On your iOS device, tap Settings > Bluetooth and find your device in the list. If your device says Not Connected, tap the name of your accessory to attempt to connect it.
  3. Tap Settings > Bluetooth and turn Bluetooth off and then on again.
  4. Make sure that your Bluetooth accessory is turned on and fully charged or connected to power.
  5. Make sure that your Bluetooth accessory is in pairing mode.1
  6. Restart your iOS device.
  7. Tap Settings > Bluetooth and locate the Bluetooth accessory you are currently connected to or attempting to connect to. Then tap [img width="23" height="22" alt="" src="http://km.support.apple.com/library/APPLE/APPLECARE_ALLGEOS/TS4562/TS4562--i-01.png" data-hires="true"> and . Try to pair your Bluetooth accessory again.
    • Note: You may need to re-enter your Bluetooth accessory PIN if your accessory requires one. Some common PINs are 0000, 1111, and 1234.
  8. Restart your Bluetooth accessory by turning it off and then on again1.
  9. Update your device to the latest version of software. See how to update your iPhone, iPad, or iPod touch.
  10. If your Bluetooth accessory has upgradable firmware, check to see that you have the latest version
Thanks,
Apple Support
May 26, 2014 | Apple MC922LL iPhone 4S 16GB AT&T...
Tip
How to Fix iPhone 6/6 Plus Show WiFi Problems
"Anyone experiencing really slow WiFi on their new iPhone 6 Plus? Mine is super slow. When I switch off WiFi, LTE works perfectly and very snappy. I didn't have any issues with my 5s and not having issues with my iPad Air. I doubt it's an iOS 8 issue because the 5s and iPad Air are running iOS 8. WiFi also works fine on my 13" MacBook Pro Retina. It's not a router issue. Any ideas??" asked by Mikef91 on the Apple's office discussions.
As one of the leading wholesale cell phone parts supplier online, DBXStore find some solution for you to fix the show wifi problem on your iphone 6/ 6 plus.
Greyed-out, slow or no Wi-Fi signal at all are among the top three biggest Wi-Fi headaches. Even though the iPhone 6 and iPhone 6 Plus came with iOS 8, Wi-Fi problems are still not completely avoidable. Before searching for solutions to Wi-Fi related problems, always update your device to the newest version of iOS. If that doesn't work, then it is time to dig deeper.
1. Reset Network Settings
Settings > General > Reset > Reset Network Settings.
This is a solution suggested by Apple Service. Resetting your network settings including Bluetooth pairing records, Wi-Fi passwords, VPNs, and APN settings; which flushes cache and clears DHCP settings and other networking related information.
2. Disable Wifi Network Services
Settings > Privacy > Location Services > System Services.
This only relates to your location being used for network and not the Wi-Fi itself.
3. Switch DNS To Google
Often times, if your ISPs DNS servers are having problems, you can switch to Google DNS by going to Settings > Wi-Fi then tap the "i" icon next to your router, scroll down to DNS and tap the numbers, then enter "8.8.8.8". Restart your device and check if it works.
4. Change The Routers Broadcasting Band
Change the routers Wi-Fi broadcast from an N network to a G network, or from 2.4GHz to 5GHz - this depends on your individual router hardware.
5. Factory Reset
Settings > General > Reset > Erase all Content and Settings > Erase iPhone.
Last but not least, restore your iPhone and set it up as a new device.
Other tricks like placing the iPhone 6/6 Plus in a refrigerator, freezer it for 15 minutes, or the opposite using a hair dryer to heat up the device might also be of help.
However, if all these software related tricks don't help, it could possibly be a hardware problem with the Wi-Fi antenna. Then the only fix is to replace your antenna with a new Wi-Fi antenna replacement. Here are links to the parts and tutorial guides' for reference.
on Jul 23, 2015 | Apple iPhone 6
I phone 5
What Type/Brand of router ?????
Apple's iPhone is a multimedia connectivity tool.
As such, the iPhone employs a sophisticated system to keep you connected to the web via WiFi signals so that you can stay up to date with email, mapping and media.
To use the iPhone's WiFi feature just follow these steps.
Tap a network.
If you have not yet used your iPhone's WiFi or if you're in a new WiFi area, the iPhone will show you a list of available networks.
Tap the network that you want to connect to in order to connect.
If there is a password required a little lock icon appears.
Enter the password to connect to locked networks and continue to surf the web.
Monitor your signal.
As you use your iPhone, especially if you're moving around, you should take a look at the signal strength of the connection.
The strength is indicated by a small, black broadcast symbol that stacks arches, or rounded bars, on top of one another.
The more bars there are the better the signal.
Make connecting to WiFi automatic or manual.
The iPhone is equipped to automatically search for available networks and connect you to one.
If you do not want the phone to search for networks, select the "WiFi" option on the phone's menu.
Then select either the on or off option of the "Ask To Join Networks."
Turning this option off requires that you find networks manually.
Forget a network.
Once you connect to a WiFi network once the iPhone automatically remembers the network and connects you to it at a later opportunity.
To forget a network so you don't get automatically connected choose the "WiFi" option on the menu.
Then tap the right arrow button next to one of the networks that the iPhone already remembers. Then tap "Forget This Network" to erase the phone's memory of the network.
Troubleshoot Wi-Fi Connection Problems on an iPhone
If you experience Wi-Fi connectivity issues on your iPhone, you may need to reset the Wi-Fi connection.
Your connectivity issues could be caused by the wrong password if you are having trouble logging into the Wi-Fi network or from a problem in your iPhone's settings.
By resetting the Wi-Fi connection, you are clearing out the previous settings created when you first connected to the network.
Tap the Settings icon on the iPhone's home screen, and tap the Wi-Fi tab.
Swipe the switch on the Wi-Fi tab to ensure Wi-Fi is enabled on your iPhone.
Tap the blue arrow button on the network tab you are connected to in the network list, and tap "Forget this Network."
Tap the "Forget Network" button that appears on the pop-up menu to confirm the action.
Tap the Wi-Fi Networks tab in the upper-left corner to return to the previous screen, and tap the network's tab in the network list to re-join it.
Press the Home button on the iPhone, and tap the Safari icon on the home screen to test the Wi-Fi connection.
Tap the blue arrow icon on the network's tab if the connectivity problem persists, and tap the "Renew Lease" button at the bottom of the network's window.
Tap the "Renew Lease" button on the pop-up box to confirm the action.
Tap the Home button on the iPhone, and tap the Safari icon on the home screen to test the network connection.
Nov 11, 2013 | Computers & Internet
Can u please tell me all the diffrent ways how to reboot the IPhone 3G as my phone is frozen only when I go to make a call but my problem is my grey button on top off my phone Isn
if your iphone is jailbroken, try sbsettings(download it via wifi) then slide from left-to-right at the top most of your screen then hit respring. or try downgrading the firmware version(backup first).
Jul 17, 2011 | iPhone Apps
How do ii conect to my wifi?with a iphone 3g?
Go into the settings program (the icon with the gears). The second menu option should be WiFi. Tap it and turn on the WiFi by tapping the rectangular button on the top right. Your network should show up in the list, just tap to join.
Mar 01, 2011 | Cell Phones
I recently found an Apple iPhone 4 16GB in the mall parking lot. I was just wondering, since it has Wi-Fi capabilitys, would I be tracked by the network provider (Bell) if I was to use the internet on the...
ha ha !!!!!,I don't think so.
First of all what the Apple iPhone was made for in the first place was not for you network provider to be tracking you where ever you go, it's for your own use alone. Network providers just gives you access to operate the phone by providing network for your access your Apple iPhone.
How does Wi-Fi work on a Apple iPhone ?
Apple's iPhone is a multimedia connectivity tool. As such, the iPhone employs a sophisticated system to keep you connected to the web via WiFi signals so that you can stay up to date with email, mapping and media. To use the iPhone's WiFi feature just follow these steps.
Instructions on how to use Wi-Fi on your iPhone.........
Tap a network. If you have not yet used your iPhone's WiFi or if you're in a new WiFi area, the iPhone will show you a list of available networks. Tap the network that you want to connect to in order to connect. If there is a password required a little lock icon appears. Enter the password to connect to locked networks and continue to surf the web.
Monitor your signal. As you use your iPhone, especially if you're moving around, you should take a look at the signal strength of the connection. The strength is indicated by a small, black broadcast symbol that stacks arches, or rounded bars, on top of one another. The more bars there are the better the signal.
Make connecting to WiFi automatic or manual. The iPhone is equipped to automatically search for available networks and connect you to one. If you do not want the phone to search for networks, select the "WiFi" option on the phone's menu. Then select either the on or off option of the "Ask To Join Networks." Turning this option off requires that you find networks manually.
Forget a network. Once you connect to a WiFi network once the iPhone automatically remembers the network and connects you to it at a later opportunity. To forget a network so you don't get automatically connected choose the "WiFi" option on the menu. Then tap the right arrow button next to one of the networks that the iPhone already remembers. Then tap "Forget This Network" to erase the phone's memory of the network. That all, Very easy to use too.
Hope that helps.
Thanks for using fixya.....
Jan 05, 2011 | Apple iPhone 4 Black Smartphone
Wifi grey area
Here is a way that solved the problem for me.
Downgrade the ipod touch to firmware 1.1.4. You have to put your ipod into DFU mode ('not recovery mode) and you have to have an itunes version that supports this old firmware. 7.5 oder 7.7 i think.
to load your own firmware you simply hold the shift-button while you push the restore button.
After you have firmware 1.1.4 on your ipod touch, download the jailbreaker "Ziphone". This programm has the option to fix the "no Wifi" problem. Look in the advanced options.
In my case, this was the only thing that solved the problem. I tried restoring it often but nothing worked.
After Ziphone fixed your Problem, you can update the Touch to the latest firmware. Wifi was still working, at least for me
Jul 11, 2009 | Apple iPod touch
Apple iPhone Smartphone Logo
265 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
