Question about HP vs15 15"LCD Flat Panel Monitor
Built in speakers will not play any sound
Buit in speakers won't play ........keyboard volume control doesn't work!
  • 6 more comments
  • Anonymous Aug 01, 2008
    no volume from monitor speakers. i tried installing things but i doesnt work. it says i need to install a new mixer or a new audio device. none o it never works.
  • MELJOSHMATT Nov 18, 2008
    MY SPEAKERS JUST STOPPED PALYING. THEY ARE BUILT INOT MY MONITOR AND I DODNT THINK I DID ANYTHING TO MAKE THEM STOP. ITS A FAIRLY NEW MONITOR
  • Anonymous Dec 07, 2008
    Speaker does not play
  • Anonymous Dec 12, 2008
    the speakers are built in the monitor. there are plugs
  • Anonymous Dec 15, 2008
    ive recently rebooted my laptop from vista to xp but when i tried to listen to my music the built in speakers wouldnt work. is there anything i can do to get them to work? or is there a download i can get? i hope you can help ;) thank you
  • Anonymous Mar 23, 2009
    my laptop was renewed and ever since sound will not play out of the built in speakers as they did before
    i've tried through control panel and system sound but nothing works, can anyone advise anything?
  • Anonymous Mar 31, 2009
    my inbuilt speaker doesn't work properly but headphone nd external speakers works properly
  • Anonymous Apr 24, 2009
    My sound won't work at all on my HPvs15 with Xp. Nothing is muted, all the drivers seem to be working correctly.. I have no external sound card. HELP PLEASE!
  • 550 Answers
Going to seem a dumb Q,
but is the audio cable plugged in, next to vga hp have a separate audio socket, the cable(supplied- 1/8 inch stereo plugs each end) fits between sound card speaker out, and monitor.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00307478&lc=en&cc=us&product=459838&dlc=
Posted on Jun 24, 2008
No sound from built in speakers.
The bleep cold be just a bleep device separate from the speakers. It looks like a round piece of aluminum with a large dot of white solid past on it with a wire attached.
1st. make sure the volume is up all the way.
Then try using a headphone just to make sure the sound card is working.
If the headphones work then it should be a setting somewhere.
Sometime the switch that turns off the speakers when headphones are plugged in gets stuck, try plunging them in and unplugging them out while music is playing.
If they don't work the sound card may be blown but it is still possible it is not.
Also, try Keyboard shortcuts for mute and UN-mute.
Try going to control panel and bring up the sound app and try different options in there for mono and or what ever it has, you may find the answer there.
If the headphones work but nothing else works you can always plug external speakers in the headphone plug.
Sep 28, 2017 | Toshiba Tecra M4-S435 Tablet PC
Tip
How to Troubleshoot a Mac Computer With No Sound
When troubleshooting sound problems on Macs, you can find thefix quickly if you isolate the possible problems first. Regardless of youroperating system, it will make things easier if you can narrow down thepossible points of failure by momentarily unplugging any sound devices.Following simple change of sound settings and testing internal sound alerts canfix the problem.Instructions<br />1.<span> </span>GeneralTroubleshooting<br /> <ol> <ul> <li>1 </li></ul></ol> Launch iTunes or another media player applicationand have it play continuously to start troubleshooting. Make sure the volume isnot muted or disabled. Move the volume slider on the menu bar up and down. Youcan also use the keyboard's Increase and Decrease volume buttons (usually F4 todecrease and F5 to increase the volume). <ol> <ul> <li>2 </li></ul></ol> Unplug any headphones that might be connected toyour computer's headphones port. If your <a href="http://www.ehow.com/computers/">computer</a> has internal speakers,unplug any external speaker plugged to the audio port to isolate the problem.Check if sound is working properly through the internal speakers. <ol> <ul> <li>3 </li></ul></ol> Go to System Preferences on your Mac menu. Clickon the ''Sound'' icon, under the Hardware section. The Sound settings pagedisplays three main buttons: ''Sound Effects," ''Output" and''Input." Click on the ''Output'' tab. Select the ''Internal Speakers,Built-in Output'' option, and raise the ''Output Volume'' at the bottom of thatwindow. Check if sound is working properly. <ol> <ul> <li>4 </li></ul></ol> Go to the ''Sound Effects'' tab, and make sure the''Alert'' and ''Output'' volumes are up and not muted. Select ''InternalSpeakers'' from the ''Play alerts and sound effects through'' drop-down menu.Click on any of the Alert Sounds in the left column and test to see if theysound as you change from one to the other. Check if sound is working properly.2.<span> </span>GaragebandTroubleshooting<br /> <ol> <ul> <li>1 </li></ul></ol> Launch GarageBand. A default piano track willappear. If it doesn't appear, click on the ''Track'' Menu and select ''NewTrack''. Choose a Software Instrument from the dialog box, and then choose aPiano from the selection of Instruments. <ol> <ul> <li>2 </li></ul></ol> Click on "Menu." Select ''Preferences''and click on the Audio/MIDI tab. For Audio Output, and Input select thecorresponding ''Built-In Output'' and ''Built-In Input'' from the drop-downmenus. Confirm the action. <ol> <ul> <li>3 </li></ul></ol> Click on the Piano track. Under the ''Windows''menu bar, select the ''Keyboard'' option, or press [ Command + K ]. A keyboarddisplays. Click on any of the keyboard keys. You should hear sound coming outof your internal speakers.<br />Make sure there is no headphone jack inserted in the computer. If sound doesnot work, try quitting the application and launching it again. <ol> <ul> <li>4 </li></ul></ol> If any of the previous steps do not fix the soundproblem, reboot and try again. <br />If you see a Disabled Volume alert when you try to raise the volume, alsoreboot. This is a known bug in Macs
on Jan 21, 2011 | Computers & Internet
I can't hear any sound
There area number of different reasons why your computer may no longer give sound. Ifyou have this problem, read on to learn how to diagnose the problem and resolveyour PC's loss of sound.
Check the Speaker Connections and Volume Control Settings
  1. Verify that the lack of sound is not due to faulty speaker connections. A simple way to test it is to substitute the speaker connection with headphones and see if you get any sound
  2. Open the volume control window by clicking your "Start" button and then "All Programs." Click "Accessories," then "Entertainment," then "Volume Control." Alternatively, just click on the speaker icon that's in your System Tray.
  3. Check the volume and mute settings. If any of the mute check boxes have been checked, uncheck them. If this doesn't work, read on.
Perform a System Restore If Necessary
  1. If the sound has been audible from your computer's speakers and is suddenly lost, you may need to perform a System Restore. Click on the " Start" button and then "All Programs."
  2. Click on "Accessories," then "System Tools," then "System Restore."
  3. Complete the System Restore Wizard. If this doesn't work, read on.
Delete and Reinstall the Original Sound Drivers
  1. Deleting and reinstalling your sound driver may resolve the problem. Your sound driver may have been corrupted or may be missing. The result of this is that the restore utility menu won't be available. For Windows XP, follow these steps.
  2. Click on your "Start" button. Click on "Control Panel" and then "System." Next, click on "Hardware," then "Device Manager, then "Sound, Video and Game Controllers."
  3. Click on a sound device named in the Device Manager, and then press the Delete key on the keyboard. Click "OK" in the window that appears. Remove all the listed sound devices i this way EXCEPT Audio Codec and Legacy Audio Drivers.
  4. Restart your computer. Reinstall the deleted drivers using the Driver and Application Recovery CDs that came with your Windows XP system.
  5. Visit your computer manufacturer's official website. Check for any updated sound driver software for your sound card. If any, download them along with the installation instructions.
I hope this information will be helpful. Thank you for using FixYa!
Please vote if it helped you.
Jun 30, 2011 | HP Compaq dc7600 Small Form Factor PC...
Sound
check your speaker first..
in your control panel>sound and audio device driver.
or in the leftside of the sidebar, if you can see the speaker icon there click it, and make sure that it is not in mute.
Or maybe your Sound Device was broken.. update your sound device driver
or install your sound driver that is compatible with your motherboard..
Or if your sound device is built in, and not functioning
You need to install a sound card in your motherboard.. it works
Jun 27, 2011 | Microsoft Windows XP Professional
No audio device found
There are a number of different reasons why your computer may no longer give sound. If you have this problem, read on to learn how to diagnose the problem and resolve your PC's loss of sound.
Jun 13, 2011 | Computers & Internet
No sound after intalling widow 7
Jun 08, 2011 | Computers & Internet
Need more volume on computer speakers
Buy yourself some stand alone speakers, a base & two side speakers, they cheap these days, base speaker has buit in amplifier & plugs into mains, or get surround sound 5speakers & a base, again mains powered, loud enough to annoy neighbours on full. Built in monitor speakers are renowned feeble tinny sounds. Right click speaker icon, bottom right, on your desktop toolbar, open volume control, ensure volume sliders set to max.
Oct 02, 2009 | ViewSonic VX910 19" LCD Monitor
Roland keyboard. Extremely static-y speakers. Cuts out.
It sounds like your volume slider is dirty. Try carefully and judiciously spraying a good quality contact cleaner into the slider and working it. do not use a lot. It only takes a little. Also do not use WD40.
Mar 01, 2009 | Roland Juno-D
I want my music back!
Have you tried to raise the volume by double clicking on the speaker icon on your taskbar. This will open the play control panel where you can raise the volume.
If you do not see the speaker icon, go into your control panel and chose sounds and audio devices and raise the volume from that screen.
Mar 31, 2008 | Gateway 2520915 Keyboard
KN 7000 Keyboard. While playing a
speaker maybe busted tyr to change it.. or test it first before changing
Feb 29, 2008 | Sony STR-DE445 Receiver
HP vs15 15"LCD Flat Panel Monitor Logo
1,032 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
