Question about Hitachi 61SWX01W 61" Rear Projection Television
Need help my rear projection tvs red lense is fine at the top of the screen but half way down to bottom it shadows off to the right and when i look at the static screen on the magic focus it won't straighten out. what do i need
    An expert who has written 3 tips or uploaded 2 video tips.
  • 86 Answers
Sounds like convergence ics need to be replaced
Posted on May 05, 2010
We got a free hitachi projection tv that i believe has a bulb malfunction. on the left half of the screen has a red shadow we cant afford a hundred dollars for an estimate then whatever the price of the...
You might need to adjust the red screen drive control, turn the Red down and see if that clears it out. Sounds like the Red Tube is over driving the Green and blue Tube.
Find the Focus and screen control block there will be 3 controls on Top 3 right under them R-G-B they adjust the Focus to each tube and screen drive for each tube. also you need to clean the lenses off top of each tube they get dirty and dusty and it would help to clean the mirror
Sep 13, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Sony kdf-e50a12u rear projection lcd bravia. red shadows
This is due to you having a projection tv, some projection tvs are really bad for game playing and especially if you have a hdtv. even in the p23 manual it says that you shouldnt use with a projection tv cause it can damage your tv's screen permanently. I personally still play mine but, thats likly the problem.
Aug 11, 2007 | Sony KP-61HS10 61" Rear Projection...
I have a panasonic pt47wx49e rear projection television. On the bottom half of the screen there is a red shadowing effect that makes me think the convergence is off. Also there is a scratch on the outer...
I had the same problem with my tv. It is a convergence problem but if it has convergence settings in the menu and they don't fix it, you need to clean the lenses with alcohol and q-tips. I did it with the tv on so i could make sure it was clean by the absence of streaks on the lenses. The outer screen (if it is smooth) should be a protective screen (just plexiglass). You can get a replacement at a glass store be sure to keep the old one so they can cut a piece to size. It the screen you are talking about has little lines in it your freznel lens is scratch and it will be difficult to find a replacement. Good luck!
Mar 14, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Top half of picture is good but the bottom half has green and red shadows
needs new convergence chips, has 2, stk392-110, they need to be soldered in. probably need a tv repairman.
Sep 19, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Red, Green, and Blue shadowed lights
the lense red blue green is warped you will need to replace those lenses
Aug 13, 2009 | RCA HD52W56 52" Rear Projection HDTV
Picture shadow on rear projection Sony big screen TV
You have 2 distinct problems that should be addressed separately. Please repost the Samsung problem. I will address the Sony problem here.
If the "shadow" makes the picture seem somewhat of a 3D one, the problem is with the convergence circuit. This could be as simple as bad connections on the pins of the convergence ICs or defective ICs. If you can solder and would like to attempt the repair, update this and I'll provide more details and instructions.
Sep 25, 2008 | Samsung HCM4216W 42" Rear Projection...
LG rear projection
Hi, I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
If you are not able to adjust the convergence using the remote you will need to replace the convergence chips.
Typical Symptoms
1) Convergence menu does not work for one or more colors.
Such as: Red moves up,down, but left or right fails.
2) Screen is bowed looking.
If you have one or more of the problems above you need to replace the convergence chips. You can get a kit and instructions from
Hope this helps :)
Jul 30, 2008 | LG RU-44SZ51D 44" Rear Projection...
Red shadows around images on screen, setting convergence doesn't help
HELLO. it not in adjusting the len's it's in the convergance board. the IC'S ON THE BOARD NEED TO BE REPLACED."GOOD LUCK"
Jul 25, 2008 | Akai PTH5498 54" Rear Projection...
your having convergence circuit problems, you`ll need to change the convergence IC`s and any burnt resistors in the convergence circuit, if you have questions e-mail me back, good luck, BMW Rider
Jan 03, 2008 | Toshiba 53HX71 53" Rear Projection...
Green and red color problem on bottom left to a little past the middle of the bottom of screen
the convergence ic's are breaking down and require replacement should cost under $ 250 depending on your service shop.
Nov 18, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Hitachi 61SWX01W 61" Rear Projection Television Logo
59 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
