SOURCE: memory full error
If this is for a Verizon phone:
Menu -> Messaging -> Settings -> All Msg -> Auto Erase
Set it to on and select OK.
If you go back in and set it back to off, you should now be able to send text messages!
SOURCE: texting problem
menu->messaging->settings->All msg->turn on auto erase->ok->turn it off and it should work
SOURCE: Not able to send message
I work at o2 in Bury, if you goto nokias website you can do a firmware upgrade for both handsets free of charge. You do need the USB data cable (DKU-2, DKU-5 or CKU5 cables) that came in the box
Support site is here, http://www.nokia.co.uk/get-support-and-software/download-software/device-software-update if there is an availiable update it will reformat your handset with that.
If you want to see if its done this, before you update key in * # 0 0 0 0 # and take note of the Version then do the same once finished. If all else fails, so long as your phone is still under manufacturers warranty you should be able to have it repaired at a Nokia Service Centre located around the UK, you'll find these here!
http://www.nokia.co.uk/get-support-and-software/repair
Hope this helps
Alen Boardman
SOURCE: my nokia n76 cannot send text messages
Yes I can help! You need to clear some memory. Delete all of your messages. Delete some pictures or videos, delete some wallpaper, etc. and your problem will go away.
Please take a moment to rate me if I helped you!
SOURCE: When I try to send
sir just follow the steps
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
kindly make a backup of contacts.
kindly rate my answer too
Testimonial: "Thank you so much that completely fixed my texting problem!!!!! Just make sure you save your contacts a directed."
That didnt work
