Question about Toshiba Satellite 5005-S504 Notebook
Toshiba Satellite 5005-S504 boots up sporadically
In May 2002, I purchased a Toshiba Satellite 5005-S504 notebook that has since deteriorated to the point where it typically fails to boot up. The notebook was the subject of a class-action lawsuit in 2005 surrounding problems stemming from overheating and sudden, repeated shutdowns. (This 2/28/2002 PCWorld.com article may be of interest: http://www.pcworld.com/news/article/0,aid,86965,00.asp.) In May 2006, after my laptop experienced these problems, I took it in for repair under warranty following this lawsuit and got the problem fixed. In recent weeks though, the computer has booted up sporadically and typically either shuts down unexpectedly after several minutes of me using it, or freezes up so that I can't use it. In either case, the computer will not turn on again for days.
Some technicians have advised that I simply buy a new computer. The machine runs Windows XP on an Intel Pentium III with 512MB of RAM.
What is your recommendation?
    Scholar:
  • 136 Answers
One of the problems I had was overheating, wich caused the same simptoms.
The ba***rd would not boot for about one hour or so after shutting down due to excess heat.
I downloaded the BIOS update from Toshiba, wich keeps the fan running almost at all times, but I also had to go cirurgical on it, since I had to disassemble the whole thing, extract the whole cooler, open it and clean the enormous amount of dust it had stuck inside. After that, never overheated again (well, once but I was using it in my bed, and the blanket was covering the air exit. I know... stupid thing to do).
If you decide to open the thingy, start by removing the cover just above the keyboard (a blunt knife will help), remove the two screws, lift the keyboard, dosconnect it from the board and disconnect all cables on sight.
- WARNING -
Make a schematic of it, or else it will be a little hard to reassemble.
Then, you can safely proceed to closing the lid, and removing the bottom screws. Also, take notice of the tiny marks besides the holes so you can replace the srews correctly.
Best of luck
Umbra
Posted on Oct 11, 2008
Hi, Sounds like the HDD is on its death march. I purchased the same Toshiha 507 from Ebay and after many Reloading attempts with Restoring to Factory System I deceived to purchase a NEW 80GB HDD from www.drivesolutions.com for 65.00usd. Now Laptop runs perfect.
God Luck on your Mission,
David Jensen
Posted on Jul 18, 2008
Muchas gracias por la oportunidad, es una Toshiba Satellite 5005-S504 de minguna manera entra a la Bios, Qué puedo hacer?
si puedes leer ingles este sitio te servira mucho. te dice como resetear el BIOS. y sitienes una password como resetearla en tu toshiba.
http://www.tech-faq.com/reset-bios-password.html
espero haberte ayudado en algo.
Dec 09, 2010 | Toshiba Satellite 5005-S504 Notebook
Toshiba satellite 5005-S504 boots over and over and over non stop
It sounds like the hard drive is dying. I had a computer do the same thing and it turned out to be the hard drive. You should still be able to access the bios though. Try hittind either delete or F1 as soon as your toshiba screen appears.
Jul 10, 2009 | Toshiba Satellite 5005-S504 Notebook
Getting memory error on front display immediately on power up
It is surely indicating issue with the memory.
Can try to reseat the memory (remove from slot and reinsert again) make sure to wipe the contact with soft tissue.
If still facing issue then replace the memory.
Apr 30, 2009 | Toshiba Satellite 5005-S504 Notebook
Toshiba satellite 5005-S504 Secure Digital Card Slot problem
Hi there
Take a close look inside the card slot (you may need a torch/flashlight) look to see if any of the brass pins are bent or out of position, if they are use a very small flat head screwdriver to gently push them back into place.
If all looks fine with the slot and there are no foreign objects inside your card maybe faulty.
Also i suggest the you check the drivers are installed, check this in device manager.
Good luck and thanks for using FixYa!!
Apr 03, 2009 | Toshiba Satellite 5005-S504 Notebook
My Toshiba 5005-s504 has motherboard problem.
Personally I would junk it those laptop models had bad overheating problems toshiba even lost a class action lawsuit over it.
Dec 19, 2008 | Toshiba Satellite 5005-S504 Notebook
Can't recover
Toshiba Laptops: - Toshiba Utility
Toshiba: - Press Esc during boot
Toshiba, Phoenix, late model PS/1 Value Point and 330s: - Press F1 during boot
Oct 24, 2008 | Toshiba Satellite 5005-S504 Notebook
Looking for Toshiba 5005 cd/dvd drivers
this link will take you to the support page
select portables, satelitte, click on archived models, then select 5005-S504-507-or 508 whichever it is.
once selected click on show results
click on drivers.
Apr 05, 2008 | Toshiba Satellite 5005-S504 Notebook
Toshiba 5005-S504 satelite
Check power adapter and your power cord. Your battery is not charging....
Mar 15, 2008 | Toshiba Satellite 5005-S504 Notebook
Toshiba Satellite 5005-S504 Notebook Logo
177 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
