Question about Cooktops
Candy sprinter hello there I have a candy sprinter electric hob . The thing is I was cooking on it earlier and it just suddenly turned off , no spillages or anything . Its coming up with code error 3. Is this something I can fix myself or does it need someone to come out to look at it. May thanks Nina
  • just2cook Oct 06, 2008
    I have same problem.. was wondering how this got resolved?
    appreciate your help
Great.. finally. i manage find from solution from user guide.. L is Locked. below is the instruction. will check out tonight.
The locking function holds the current settings, or prevents anyone from starting the hob. It is also used for cleaning the control strip as the controls can be locked without the hob being on. To lock the hob : -Press the on/off button     . -Press simultaneously " - " button and " + " button of the front right zone (PVD 633 front left zone), and then press again on the " + " button of this zone. The hob is locked, the locking indicator " L " is displayed on all zones for 20 seconds. To unlock the hob : -Press the on/off button      . The locking indicator " L " is displayed on all zones. -Press simultaneously the " - " button and the " + " button of the front right zone (PVD 633 front left zone), and then press again on the " - " button of this zone. The hob is unlocked.
Posted on Oct 06, 2008
  • catherine lee Jan 01, 2012
    you have just solved my problem. Thank you for your clear instructions, I can start cooking again. Very grateful.
  • 59 Answers
Hi
Did you notice a flick of the lights in the house or room when you were cooking?? that may have been caused by a voltage jump
Try to unplug the stove for 10 minutes and plug back in, that might re-set the memory.
Hope this help you
Eddie Rentas
Tupper Lake NY
Posted on Jun 26, 2008
Child lock turn off
For the Candy CH642B cooktop:
LOCKING BUTTON OPERATION
The locking function prevents the children from starting the hob. It is also used for cleaning the control strip as the controls can be locked without the hob being on.
To lock the hob :
- Press the on/off button
- Press simultaneously " - " button and " + " button of the front right zone (CH 633 front left zone), and then press again on the " + " button of this zone.
When the hob is locked, the locking indicator " L " is displayed on all zones for 20 seconds.
To unlock the hob :
- Press the on/off button. The locking indicator " L " is displayed on all zones.
- Press simultaneously the " - " button and the " + " button of the front right zone (CH 633 front left zone), and then press again on the " - " button of this zone. The hob is unlocked.
Dec 05, 2015 | Cooktops
Hob light up.
I take it the two fuses you mention were the house fusebox and the fuse in the outlet in your kitchen? If you know the mains is getting to the hob and nothing at all is lighting up on the panel then this sounds like a job for the professionals. I can't find any mention of a reset button or user acessable fuse in the manual. The only thing left to do is check the main wire connection underneath the hob - if it is accessable. (switch off at the wall first!) Assuming you are in the UK Service force telephone number is 08705 929 929 Hope this helps.
Sep 29, 2007 | AEG 23 in. 67600KF-N Electric Cooktop
Tip
GAS KITCHEN APPLIANCE CLICKING SOUND
Good Day,<br /><br />Have you ever had that problem with your Gas Hob, Stove or Cooktop where you hear a clicking the whole time, coming from <span style="font-weight: bold;">the ignition switches?</span> Well, then today I will show you how to <span style="font-weight: bold;">resolve the problem.</span><br /><br />Why does this happen? <span style="font-weight: bold;">Moisture</span> on the ignition switches... Be it because of you cleaning it obsessively or, because you might have had a small water spillage - the causes could be quite a few things <span style="font-weight: bold;">related to water.</span><br /><br />Now for the solution (Please note: I will be using a General Electric Stove & Hotpoint Hob as demonstration, but this solution should work for <span style="font-weight: bold;">most ranges - if not all</span>)<br /><br /><span style="font-weight: bold;">Step 1 (Safety first)</span><br /><br />Turn the machine off, switch it off at the mains if it is powered by it, and if powered by another source - Turn this off!<br /><br /><span style="font-weight: bold;">Step 2</span><br /><br />Remove the knobs of the Hob/Stove:<br /> <br /><img src="jedemeyer1_31.JPG" /><br /><br />If they do not come out, try to pull them as far out as possible, without breaking them. If there is a seal beneath them, then take it off as well - in the case if the knob does not come off, leave them be... If any grime or fat deposits are present, remove them with a damp cloth and some toothpicks.<br /><br /><span style="font-weight: bold;">Step 3</span><br /><br />Get a hairdryer, or fan.<br /><br /><span style="font-weight: bold;">If using the hairdryer:</span> <span style="font-style: italic;">Dry each knob area for 3 to 5 minutes for each knob respectively.</span><br /><br /><span style="font-weight: bold;">If using a fan:</span> <span style="font-style: italic;">Put the fan facing all the knobs, and leave it there for 30 minutes.</span><br /><br style="font-weight: bold;" /><span style="font-weight: bold;">Step 4</span><br /><br />Leave the oven for <span style="font-style: italic;">about 20 minutes</span>, and then re-attach the knobs and seals and re-connect it to power.<br /><br />TEST, and viola! The problem is fixed.<br /><br />I have attached a video to this Tip, that shows a complete yet simple solution to this problem (Kindly provided by General Electric):<br /><br /><utube src="-vG9QQDiFCw"><br /><br />Now you can use your Hob/Cooktop/Stove with no more annoying clicking sounds.<br /><br />I hope this Tip has helped you, if it did - Please rate it.<br /><br />Kind Regards<br /><br />JEDEMEYER1<br />
on Aug 03, 2011 | Cooktops
Cleaned my gas hob but now when you turn the gas on the automatic ignition doesn't switch on. Model candy pl 40 ax. I have checked the fuse on the plug but that's ok is there another fuse I should kno
Is it pluged in. Check to see if the plug Still works behind the stove It might be on a GFI plug needs to be reset somewhere along the backsplash counter
Jul 19, 2013 | Cooktops
Candy hob is locked how can i unlock it
Please explain what is a candy hob. How does it lock?? Normally. Key, electrically, etc
Feb 28, 2012 | Cooktops
Want a narrow ceramic cook top / hob
Look at Baumatic 90cm Slimline 4 Hyperspeed Zone Ceramic Hob. Dimensions are 350mm x 880mm
Apr 26, 2010 | DeLonghi Cooktops
Was cooking fudge-hot sugary liquid boiled over onto glass cooktop. I tried to clean, but appears as if glass top has been ruined. It is rough. Tried scraping with razor, but does not help. Used cooktop...
Maybe try white vinegar - apparently you can clean glass hobs with it & it might help dissolve the fudge stuff if you pour it on that. I wouldn't use a razor as you might damage the hob more.
Dec 15, 2009 | Jenn-Air JED8430 Electric Cooktop
Aeg hob
It is child lock.
Turn cooker on, press two + at front of oven, this will then take it off for that cooking session.
To turn child lock off switch on hob, and touch - for 5 seconds.
Sep 29, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Hob not working
It is child lock.
Sep 16, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Cooktops Logo
4,153 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
