Question about Zanussi Dishwashers
Hi I've inherited a Zanussi DA6142 Dishwasher from a recent house move. It was treated quite poorly by students who I suspect ran it without the filters in place. I've used a dishwasher cleaner and was able to pull out the lower spray arm and rinse out all the crud that was blocking it (small stones, food, plastic, pieces of glass, paper, etc) but I cannot for the life of me work out how to get the upper spray arm out. The PDF manual I've downloaded for this model says DO NOT remove upper spray arm. I've poked the holes with a straightened paperclip but after every wash they are blocked again and it's frustrating not being able to flush it out like I did the lower one.
IFIXALL
  • 868 Answers
SOURCE: Not washing properly
This D/W should have been re- called ,toooo many flaws.Sorry!
Posted on Jun 05, 2008
  • 2920 Answers
SOURCE: Kitchenaid dishwasher - small pieces
you need to clear the filter on the dishwasher so food particles can pass...also try using jet dry in the wash mode it really helps
Posted on Sep 11, 2008
SOURCE: Maytag dishwasher filter (?)always clogging
How do I take apart and clean the filter, I've gotten the screws out but to do now?
Posted on Sep 18, 2009
MNfisherman
  • 11896 Answers
SOURCE: upper spray arm on dishwasher does not move
you most likely have gunk inside the arm or holes not allowing the water to spray out and turn the arm. Otherwise, the arm bearing may be stuck and will need a gentle push to loosen up.
Posted on Sep 22, 2009
  • 2501 Answers
SOURCE: lower spray arm siemens aquastop dishwasher doesn't rotate
Sprayers require water to pass through the jets to provide motion to the arms.
Suggestion;
Remove the sprayer from the machine and look for blockages. (Removal should be easy, at it is expected that the user will need to clean the jets occasionally; If you have any problems removing it, consult your manual).
Posted on Dec 14, 2009
Testimonial: "Thanks for a speedy and v helpful reply. Sounded obvious, but I hadn't checked the water inlet(which was calcified)just the jets on the arm itself! "
My zanussi dishwasher has a black membraine at the back. Smell of burning and found part of the black membraine scorched and soft to touch. Plugged out immediately. Any ideas?????
This is isolation for avoid condensation on outside stainless steel housing.
Why is this happend? I belive because too high temperature, poor quality, very old dishwasher....etc.
Dado
May 08, 2015 | Zanussi Dishwashers
Zanussi TC7114W Tumble Dryer manual
Just click here for the direct download from PDF : TUMBLE DRYER TC 7114 W TC 7114 S
No websites or forwarding, that is just the manual from factory support website.
Vote the solution if this is what you are looking for
Sep 22, 2008 | Zanussi TC7114W Electric Dryer
. Hi.Have a Zanussi DI720
This is a guess but try gently moving it through the cycles by hand a few times, it may just be that the timer mechanism is stuck a bit from age and or disuse. Turning it may help to loosen it up.Be gentle though.
Jun 05, 2011 | Dishwashers
Where is the heater located in a zanussi zdt6255 dishwasher
Hi its in the rear bottom quite hard to get to, Is that the issue? you van test with ohm meter should be about 30ohms
Sep 29, 2010 | Zanussi 23 in. ZDT6255 Built-In Dishwasher
Zanussi ZFC 45/30 SS is hot at front between the doors..
This is normal. This is a defroster to keep moisture from condensation from freezing the doors shut.
Jun 30, 2009 | Refrigerators
New dishwasher no water
make sure water supply on if ok check water solenoid
Dec 23, 2017 | Zanussi 24 in. DE6965 Built-in Dishwasher
Zanussi dishwasher
hi there sounds like a possible dry joint on the pcb repair and try first
Nov 26, 2007 | Zanussi ZT485 Built-in Dishwasher
Smeg dishwasher
Hi, You can download SMEG dishwasher manuals from here: http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN Al.
Feb 02, 2007 | Smeg CSU2001 Built-in Dishwasher
Dishwashers Logo
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
