Question about Apple iPod nano 3rd Generation
Resetting I-pod how do i reset my i-pod back to the factory settings?
  • Apple Master
  • 2,794 Answers
Plug your IPod into your computer. Once Itues loads up select your ipode and press the restore button. That will reset your IPod back to factory settings.
Posted on Jun 25, 2008
My sceen won work with out a external mouse after i factory reset
When you reset it to the factory settings, that made everything like it was when it was taken out of the box. At that time you had an external mouse, so now after resetting, it's looking for the external. If you were not using the external before resetting, you will need to change the setting back like it was before resetting.
Nov 30, 2017 | Computers & Internet
IPOD CLASSIC 160MB IS FLASHING AND WILL NOT CHARGE UP.
please leave the unit for one night with out any charge
and then try giving full charge and use the unit
Aug 28, 2008 | Audio Players & Recorders
How to delete previous owner WiFi data and security code
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Mar 26, 2015 | HP LaserJet 4500 Printer
I have an I-Pod touch and all off a sudden CCS stopped sync with my facebook acc ,i have checked both fb + i-pod settings which both enable access for each other but it doesnt help , how can i fix this ?
try updating your I-pod on the iTunes software on your computer if that doesn't work back up your I-pod on the iTunes and then reset your I-pod to factory settings. now if you backed your I-pod up properly then log back into your I-pod with your iTunes account and plug it into your computer, it should automatically restore all your apps and music ect. then you should be able to sync what ever u want again the problembeing is u probanlypicked up a virus or something on your I-pod
Jul 31, 2013 | Audio Players & Recorders
I need to reset my i pod touch
I'm posting two links for you: one for unlocking a your ipod, and the other for resetting your device to factory settings.
Good luck Forgot passcode for your iPhone iPad or iPod touch or your device is... Restoring iPod to factory settings
Sep 03, 2012 | Apple iPod touch Second Gen (8 GB,...
Sound becomes distorted after changing channel requiring pushing mute button and back to sound again to restore proper sound
Tries tv unplug,replug it back like about an hour.By letting the tv by resetting itself back to the factory setting.Now goto the tv menu goto Audio Setting,go down to do resetting,so resetting the tv Tuner board for resetting sound,setting back to factory setting.This should solved ur sound problems.
Jan 30, 2011 | Vizio M370VT 37 in. LCD TV
I need the reset code to preform a factory reset
soft resetting :
-Back to factory settings: This should maintain your data (contacts/messages/calendar/notes etc), just returning your N97 back to all previous settings
From menu:
Settings> Phone>Phone Management>Factory Settings
hard resetting:
The traditional method won't work as the N97 doesn't have the old keypad. After you've backed up your data onto memory card/pc/ovi, turn your phone off and simultaneously press these four buttons circled in red.
  • Caps shift
  • Space bar
  • Delete button
  • On button
You'll know it's worked when you see the initial set up screen, asking country of origin.
Nov 08, 2010 | Nokia N97 Cell Phone
Itouch wifi connection is greyed out-how do i fix it?
i had the same problem. the wifi button was grayed out and i couldn't select it. resetting the i pod to factory settings solved the problem.
go to general settings, than reset, than select erase all content and settings it put it back to factory settings and takes about an hour.
Dec 28, 2008 | Apple iPod touch
İpod nano not seen at explorer and itunes
- check the cable - check the connections on the bottom of the ipod for bent pins, or dirt - make sure ipod battery is fully charged - if you have all your library backed up, reset ipod to factory. You will lost all settings etc. though. - check usb ports are working properly with no conflicts or driver issues (control panel\system\hardware\device manager) - uninstall usb ports on pc, let pc redetect them
Aug 25, 2007 | Apple iPod nano
Apple iPod nano 3rd Generation Logo
217 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
