Question about Acer AL1711 17" LCD Monitor
Acer tft AL 1711 doesn't stay on...
It takes many times switching on this monitor until it stays on. As soon as is turned on, it stays on for hours. What do you think is the problem?
  • kiki12345678 Sep 18, 2008
    I think I did send a post saying that I resolved the issue by accident... I pressed the Menu button and played with the functions, while it was connected with my laptop. Finally I pressed for Reset and I did Auto Config as well. The screen hasn't played up since. Turns on first time I press the "On" button. The only problem is that I kept it plugged on my laptop and every now and then the laptop sreen was black or grey. The issue was resolved by unplugging the screen when not needed and plugged when needed with a restart of the laptop in order to find the new monitor... I only need the extra monitor twice a week and this is a small inconvenience... Somebody explained to me that because the laptop is of a different resolution, it tries to get even with the extra monitor and blacks out. Another solution to this problem would be to have both laptop and monitor on at all times, but as I said I need it only twice a week. It was a very good bargain as we bought it for £15!!!
  • Acer Master
  • 5,568 Answers
Has your problem remained stable since you posted this in June or is it now completely dead?
Posted on Sep 17, 2008
  • Steve Allison
    Steve Allison Sep 18, 2008
    That was a bargain; did the guy have any other stolen goods for sale?? ;-)
    You might check eBay (or other cheap source) for a two-port video transfer switch; I used one in my service shop years ago (somewhere in a box now) and it saved a lot of wear and tear on connectors and at that time was about $20 US.
    You can just leave it connected to both unless you are actually dragging your bargain around with you.
My acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
my acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
Nov 27, 2010 | Acer AL1711 17" LCD Monitor
I have an Acer AL1711 monitor and its got a blankscreen
Sounds like bad caps in the power supply. C6 & c22 often need replacing. Check also R1, 10 ohns.
Monitor Mike
Apr 14, 2010 | Acer AL1715 17" LCD Monitor
Acer monitor only display for about 3 to 4 second
Sounds like a busted syncing circuit, probably due to a condenser. It takes about that time to heat or overcharge, at which point a safety feature will turn off the display.
You just MIGHT get some more life hours out of the monitor by tuning it to a lower resolution, but it will buy you a month even in the best hypothesis.
I'm afraid the monitor is in for a repair/replacement.
Oct 30, 2009 | Acer AL1716 F Monitor
Dell monitor will come on but will not stay on. stays on 5sec
5 seconds? Hmm, too long for inverter driver turning into protection caused by bad lamps. Also too long for PWM controller in the switching power supply.
Rather looks like overheating of the FETs in the inverter, they are driving HV-transformers. Open the monitor, remove metal lid and observe inverter board. If PCB under and around these FETs is darkened, replace them.
These Dells hard to open. Take the foot off and unscrew plastic cover. Then using flat screwdriver with wide blade separate plastic halves of the case, starting from bottom edge and moving to opposite. It might be sweaty.
Sep 13, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
When I start my computer my Dell S199WFP Flat Panel Monitor does not go on and stay on. It comes on for about two seconds or and switches off. I have to turn it on about 20-30 before it will stay on. While...
Hello
You have capacitors on the monitors power supply that have changed value. Soon they will keep the monitor from turning on at all. Send it to a company like mine or take it to a local repair person.
Aug 02, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
I turn the monitor on, then it turns itself off.
It may be the problem with the power on/off switch.The problem can be solved by replacing it.Contact you authorised technician..
Jul 01, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Acer 1711 monitor won't power up
power supply of the monitor is the culprit.Generally defective electrolytics in primary section of Power supply.
Feb 18, 2008 | Gateway FPD2275W LCD Monitor
Acer 1711, entering sleepingmode in few seconds
same prob on mine gues its the inverter board but not tried yet
Jan 13, 2008 | Acer AL1711 17" LCD Monitor
Acer Al 1711 Monitor
Turn the monitor ON and continue to hold the power button for a few seconds.
Worked for me :)
Nov 09, 2007 | Acer AL1711 17" LCD Monitor
Acer AL1711 17" LCD Monitor Logo
159 people viewed this question
Brian Sullivan
Brian Sullivan
