Back to:
Tags:
JVC BR-DV3000U DV/Mini DV VCR
TC output from FCP
By Horner - usenet poster
I just got a JVC BR-DV3000U DV deck to use with my Final Cut Pro system. One
of the first things I had to use it for was copying some timelines with Time
Code to DV tapes (the JVC deck allows TC to be set via the incoming signal
on the Firewire). It worked fine - BUT the TC is off (behind) on the dubbed
tapes by 31 frames????? I tried dubbing direct from a camera via a 4 pin to
4 pin firewire cable and it worked fine (identical TCs).
Anyone else experienced this?
Doug Knutson
Windswept Productions
w @reach.net
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 28, 2007
Not Rated (0)
tsvservice
Rank:Guru Guru
Rating: 87%, 75 votes
Not likely a deck problem; the time code is digitally encoded with the video rather than being recorded on a separate track. In the days of VHS and SVHS, time code problems sometimes arose when the pinch roller became worn or the tape stretched.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on TC output from FCP:
I don't want to Accept this solution
Solution #2
posted on Aug 11, 2005
Not Rated (0)
2Pansy
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I will be very interested to know if this turns out to be a deck problem, as
I ma considering this deck as well.
Steve
Thank You!
Can you Help with these VCRs problems?
VCRs
I have connect my SD-V394 Toshiba DVD/VCR combo to my Sony...
When I plug in the dc plug the fan starts for second then...
When I insert a mini dv tape into the 3000, it plays it...
I was logging some unmarked miniDV tapes, and one of them...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
