Not booting up for 1st time?
We have just bought a new laptop and its not booting up for the 1st time! we have plugged it in to the mains and turned it on, like the manual says but its not doing anything!
  • 113 Answers
Get it back to the shop right away
Posted on Jun 25, 2008
Acer aspire 4339 wont turn on with new battery
That means the laptop is not detecting the battery as authentic or full enough to boot the laptop. Most batteries are now smart batteries, so the battery you bought may be an aftermarket battery not supported by the laptop. Return it and cite the issue.
Mar 03, 2014 | Acer Aspire AS43392618 PC Notebook
It was working good all of sudden screen became black and the PXE E61
It seems to have lost communication with the hard drive. Check physically (pop out and then back in) and in BIOS. Make sure its the 1st boot option.
Also disable PXE boot in BIOS or remove from 1st boot option. This is a LAN (network) boot option.
Sep 30, 2012 | Acer Computers & Internet
I have a IBM Thinkpad T20 Laptop. I need to install a new hard drive and I am not to sure how to do it. cAN YOU HELP?
you will need.
a philips or cross screw driver
the new HDD (hard drive)
and an instalation disk either XP, vista or linux.
uplug from the mains and remove the battery on the bottom of the comp you will see two large panels remove the you will find the hdd under one of them.
remove it the hdd will be held in a bracket type thing we call a caddy remove it and put it onto the new hdd insert it into the comp screw the panels back on replace the battery turn it over plug into the mains.
start the computer go into the BIOS push F2 i think go to boot and select the 1st boot from cd open the cd draw place in the cd close it push F10 it wil ask if you wish to save and exit push yes.
the computer will now shutdown and restart you will get a message in the top right screen push ant key to boot fron cd.
now folow the on screen prompts and ya done.
Oct 07, 2010 | Computers & Internet
I have internal battery 601 problem need new battery message. when i turn on it boots up then before i can check the external battery level it switches off. So i start again with mains plugged in and the...
This is the bios battery which back up the clock and settings and it is normally found on the main motherboard accessable from the rear of the laptop from the memory card opening.
so remove and fix the 3 volt battery into the slot.
Sep 28, 2010 | Computers & Internet
My daughter recently purchased a 5551 laptop. It worked fine for a couple of weeks. The laptop is not now charging with the supplied transformer. The battery is completely flat and will not allow her to...
This is one of the most common issues with Laptops. In fact the problem is with the Charging Component (socket/plug) on the laptop, when charger is plugged in and plugged out very frequently, this happens as the charging interface is being moved time and again and become loose. From your side, you can try cleaning the interface :
You can use a cleaning brush dipped in alcohol or acetone or similar cleaning solution to clean the socket.
If this isn't not successful and it boots up using a charged battery, then you are likely be necessary to replace the charging socket:
Good luck.
Thanks for using FixYa.
Aug 16, 2010 | Computers & Internet
My new HP notebook won't turn on. I've had it for one month. There is a light on the side where it is plugged in, but it won't turn on
Unplug the AC adaptor. Remove the battery. Hold down the start button for 1 minute. Replace the battery and plug in the AC adapter. The computer should reboot.
Jan 07, 2010 | HP Pavilion dv6000z Notebook
you ll have to reinstall windows using a external cd drive plugged into a usb port and set it up in bios to boot external drive 1st also ur hd may be faulty but unlikly being so new unless u have slammed it down/dropped it or have caused it to overheat or simply being playing about in bios and turned it off maybee
Oct 02, 2009 | Acer Aspire One PC Notebook
No normal boot up, screen stays greyish white with lines.
if its booting up and yopu are not able to see the line then its most probably the display problem you better contact service centre bfore trying anything or use a external display to check its running
Aug 03, 2009 | HP Pavilion dv6000z Notebook
My dell inspirion won't start-up, I just replaced the Cmos battery, and I also bought a new battery[kd476, 85w] If I try to boot with or without the battery, same thing happens. After pressing the power...
Display could be bad, try plugging in an external PC display to verify it.
Other than that it may be the main board is bad.
Some older laptops and PC's had issues with capacitors going bad and would fail to boot.
There was a recall but I'm sure that expired now.
If it's new and under warranty contact to get an RMA to send it in.
Aug 02, 2009 | Dell Computers & Internet
Need XP Professional password for Dell Latitude D600
Assuming Windows XP.
Boot into safe mode. Do so by pressing 'F8' a few times just as the computer begins to boot up (right before the Windows screen)
Once in safe mode, click on administrator (or type it in as the username if it doesn't come up with the welcome screen). It shouldn't, by default, have a password if it is XP Home.
Once logged in as administrator, go to control panel and users and change the password on the account you want or create a new one.
Dec 20, 2007 | Dell Latitude D600 Notebook
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
