This may not be a definite answer, but it may provide a hint what codes to try. Although the standard Cox cable box code for my Philips universal remote, 4200, worked for the 9865HDC, the standard code for my GE 24959, 0529, did not. Since Cisco acquired the Motorola cable box division a few years ago I tried all of those codes, but none worked. Then I noticed a single code 0506 for DVR under Motorola. It worked like a charm, even the dedicated DVR List button on the GE 24959. Hopefully you can find a Motorola DVR code for your universal remote.
Believe it or not, this could be a simple battery problem in your remote. When my battery is low in my remote, some buttons will work and some not. I'd try replacing the batteries in the remote first. If that doesn't work, I would guess that you need a new remote. Sounds like your DVR works fine manually, so chances are that's not the problem.
Hope this helps.
I called Comcast about this today and they had me turn off the TV, unplug the DVR, unplug the coaxle cable, wait a second, rescrew in the coaxle cable, replug in the DVR. It worked! The DVR is snappy like it used to be. Such a relief because it was soooo annoying. Good luck.
First the only way the 6.3 will work is if it has the green number 1 on the tab facing you. Assuming this is the case you will need a new remote. This primarily is the remote for the second room away from the receiver. Thanks for using Fix Ya.
Follow-up to the person who quoted from page 29 of the manual: Not sure if this will work w/the particular remote you have, but for the remote that ships w/RDR-VXD655 you can change the command mode in which it is operating by holding the Enter key on the remote and pressing the respective digit appearing in the LCD. In your case that means while holding the Enter key, press 1.
I have the 55 inch. try using 246. That works on mine. if not try 028,164,208,066 let me know if that works for ya ric another note, are you using the flash on the back of your cable box or do you have a sensor in front of the DVR box?
The answer depends whether its a Comcast DVR Remote or a regular one. The DVR codes are 4 digit -- the others are 5 digit. I got 0060 to work for my DVR remote.
