Question about Aspire Digital AD-8091 DVD Recorder
PSCAN I BELIEVE I PUT IT INTO PSCAN MODE, LOST VIDEO INPUT TO TV. HOW DO I GET IT OUT, WITHOUT VIDEO SCREEN?
  • cville55 Jun 25, 2008
    THANK YOU VERY MUCH! IT WORKED, AFTER I STARTED A DVD, AND THEN RAN THE SEQUENCE.
    Sergeant:
  • 243 Answers
Try unplugging it overnight.
Thanks,
Lee
Posted on Jun 24, 2008
    Genius:
  • 3,422 Answers
HI,
If you lose video because you have advertently pressed PSCAN, press Source, press Pscan , Press Enter.
You may have to this a few times until you have proper Source.
    Sergeant:
  • 260 Answers
On the back of the dvd player there is a switch to cut the progressive scan on and off.
Whenever I try to watch a DVD the screen splits and a message reads "PSCAN"
You need to do one of two things:
1) Look at the back of the DVD player for a switch that is labeled with " PROGRESSIVE SCAN', you need to set it to OFF (since you are using Composite Video jack (Yellow RCA jack) output of the DVD to feed your TV, but the DVD player is set to PROGRESSIVE scan mode, taht is why you are seeing "PSCAN).
2) Use the component video input/output instead by using 5-wire cable set (Red, Blue, Green for video, and White and RED for audio).
Sep 03, 2011 | Sanyo Televison & Video
How can I get ride of the pscan split screen view on my memerex vcr-dvd player without the remote control and no manual
I'm not sure what is model number of your VCR-DVD combo so providing you general info to turn off pscan.
Put disc in player, press play to have distorted picture then press stop button to stop playback.
Now press and hold Stop button on unit for 6 seconds that will turn off pscan mode.
Or let me know exact model number of your player to find out solution.
Thanks.
May 28, 2010 | Memorex MVD-2045 DVD Player
I've had a number of vcrs and vcr/dvd players over the years. But for some reason, I cannot set up this machine. I set up all of the cables exactly like I always have and the way that is instructed, but I...
These days the video input channel depends on the TV and any other equipment in the sequence. I've seen component video come in as Line, Channel 3/4 (with a switch on the video device), Aux1, Ex1, AV1, Channel 60 (I think that may be specific to satellite dish receivers). If the remote has an input button, try that (alternatively, look in the menu for source options). One thing to try: press the PSCAN button on the DVD remote (to toggle off the Progressive scan).
On some TVs the channel for the video is reached by going down from Channel 2 (this works when no channels are programmed into memory and the intervening channels are skipped).
What TV are you connecting to the DVD/VCR player? (If it is an older TV and any external device was connected to either channel 3 or 4, check that the TV works with any input device. I had a 19 year old TV (coax in only) that was damaged and no external device worked.)
I wish that I could be of more help.
Apr 26, 2010 | RCA DRC8335
Devide the tv screen in 2 and have PSCAN written
Pscan is progressive scan, go into the menu and turn PSCAN off
Mar 21, 2010 | Televison & Video
I set the video output to PSCAN and lost the screen image completely. I didn't realize my TV had to support Pscan to use this setting. Now I'm really stuck because i have no onscreen display. Help would...
Hi and welcome to FixYa,
Initially, postback with the brands and model numbers of the DVD unit and the TV.
Good luck and thank you for asking FixYa.
Jan 17, 2010 | Televison & Video
How to get the pscan and split screen go off
press video mode or pscan button on remote
Jul 11, 2009 | Televison & Video
I can't switch to aux/video without my remote.
not really sure about this but if you put a disk in then run auto scan for your channels,long shot but worth a try.
May 11, 2009 | Sanyo DS19310 19" TV
PSCAN Message Displayed
you please use dvd remotby press mode button
Jan 15, 2009 | Sanyo DS31520 31" TV
Pscan mode
I had the same problem. Here's what I did to reset the progressive mishap...
  1. Turn on the player (without a disc inserted)
  2. Wait for the "no disc" message
  3. Press 1, 6, 7, 1, 9 slowly
  4. A menu comes up
  5. Select "Configuraton"
  6. Select region (0 = codefree)
Feb 26, 2008 | Oritron DAV3101 PROGRESSIVE SCAN DVD
How Do I Get a DVD to Work with This TV?
Make sure to switch the TV's tuner mode to Video or Aux mode.
You can change the mode using the original TV remote or directly from the TV's control panel.
Again, tuner mode picks up all live broadcast airwaves and Video or Auxillary mode displays what is inputed into the TV via second device..
Good Luck!
Feb 16, 2008 | RCA G32665 32" TV
Aspire Digital AD-8091 DVD Recorder Logo
285 people viewed this question
Top Aspire Digital Televison & Video Experts
Josh Whitehead
Josh Whitehead
Demonic-2011
Demonic-2011
Are you an Aspire Digital Televison and Video Expert? Answer questions, earn points and help others
