Need help Is there any ways I can cleared out the memory on SRAM.... or the IMC BOARD ?? thanks Inoke Valu Manager PRO-TEC SERVICES Vava'u Kingdom of Tonga
  • nokevalu Jun 26, 2008
    ok...
    I'll try disconnecting the battery from the DC and see if there's any difference,
    then I'll get back to you kk..
    cheers
  • 1,326 Answers
Sure, just disconect the battery on the DC controler. Or you can try to reset in service mode..... It all depends on the make and model of the copier.... they are all different
Posted on Jun 26, 2008
What is the full meaning of ptc, mfp, scu, pwb,LSU,LCC,SRAM,SUM,CPT
LSU - Print Head which houses the (LASER)
LCC - Large Capacity Cabinet (Holds a Lot of Paper, more than a normal tray)
SRAM - Static Random-Access Memory
CPT - Toner Cartridge Code
PTC - Primary Transfer Belt Cleaning Unit
MFP - Multi- Function Printer Control Board
SCU - Scanner Unit
PWB - Printed Wire Board (Circuit Board)
Hope that helps
Oct 16, 2015 | SHARP MX-3100N
I need a 2mb Pcmcia Sram Memory Card for TPS1100
I have never been used one for $350
amjad_assad@yahoo.com
Thanks.
Apr 12, 2013 | Leica 2mb Pcmcia Sram Memory Card
Solution for systen error E1 00
The error means a problem with the image memory board that is located at the back of the copier. Assuming you have already powered the copier off and on to try and reset the code, unplug the copier and remove the top cover or auto document feeder. The back cover comes off by removing 3 screws on the top of the cover, and a couple of screws on either side. As you are looking from the back of the copier, you will see two circuit boards on the left side, one on top of the other.. Remove the scews from the top board, pull it out slightly and push it back in making sure you have it seated against the board underneath it. Tighten the screws on the board, replace the rear cover and the document feeder. Plug the copier in and turn on the power switch. If you still have the error code, the IMC or Image memory board (the circuit board you just tried to reseat) is bad. You can call your local Sharp dealer for a replacement, but it will cost you a few hundred dollars. Add another hundred if you want them to replace it for you. If the board is bad, consider the cost of repair versus the cost of a new copier.
I have had these IMC boards go bad before, but sometimes just reseating the plug that connects the two boards together resolves the problem..
Aug 09, 2012 | Sharp AL-1655CS Copier
I have a workcentre pro 575 and am receiving the message, "memory full". Nothing will print, and I hope you can tell me how to get the stored memory to print out. Thanks.
You hopefully just need to clear memory, delete phone numbers or delete jobs.
If those don't work the Main Board might be bad 160K72560
Whit
Item, Inc
Aug 17, 2010 | Xerox WorkCentre Pro 575 Plain Paper Laser...
SRAM has been formatted dew to a problem with the SRAM messege that will not clear
This is almost always a problem with the Fax board in the machine. Not sure what your machine is, but on just about every machine there is one, sometimes two of the large 3-Volt Lithium-Ion batteries (looks like a large watch battery) for memory backup. If one of these goes dead, this can cause the error you getting.
Other options would be to try to re-seat the memory on the fax board, and also to try to re-seat the fax board itself.
Nov 11, 2009 | Ricoh Office Equipment & Supplies
Canon ir2020-seystm err e354 please tel me what ido tanvir gillani
E354
•When turning ON the power, inconsistency of the serial No. of
the serial number PCB and that of the controller PCB
(SRAM)/counter memory is detected.
•When turning ON the power, it is detected that no serial
numbers are assigned to the serial number PCB and the
controller PCB (SRAM)/ counter memory.are you trying to change the counter board this not possible bec the serial no of the machine is embedded on the counter board so no counter tampering allowed
Oct 01, 2009 | Canon imageCLASS D320 Digital Copier
Error code
fuser has oevr heated - needs resestting or replacing
Mar 29, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error messsage cal for service E1-88 from sharp AR-5127
Unplug the Machine, remove the board you installed, re-seat the board,
make sure everything is connected, turn machine back on..
This is what the Manual says:
IMC PWB communication trouble (Timeout)
Check the connectors of the IMC PWB
and MCU PWB.
Check the grounding of the copier.
If you need further help let me know..
Oct 26, 2008 | Sharp AR-5316 Advanced Digital Imager...
Eror code on sharp copier AR-M276
UNRELATED PROBLEMS.
H4 = MAIN HEATER LAMP ABNORMAL LOW TEMP. THE FINAL UNIT BEFORE PAPER EXITS. HAS TO BE HOT. LAMP OR THERMO-FUSE? CHECK CONTINUITY LAMP WIRE IN THROUGH WHOLE PATH TO OTHER LAMP WIRE OUT.
E1-15 = IMC board Page Memory error/SRAM
error. MEMORY FULL? Mfr. says "Print Buffer Page Memory or Work SRAM abnormality"
SORRY NO MORE.
Jun 24, 2008 | Office Equipment & Supplies
Sram error missing E
Better if you have other person to help you.
Turn off the printer, hold 0 3 5 6 7 buttons, turn on the printer, wait until the *s disapair.
Jun 07, 2007 | Xerox Phaser 7300DN Laser Printer
jasbo
jasbo
